Old 4th March 2010, 12:32   #31
Red Liner's Avatar
Thanked: 1,178 Times
Originally Posted by Tejas@perioimpl View Post
@ Behram.
A Public Apology: I'm sorry for the public outburst on the forum; i know you are a busy man, but you try to understand my position. You were also to help me since a month for my electricals, obtaining parts, etc but nothing happened. Rather, say: "i can't do it" and that's fine with me; but keeping me hanging ticked me off. Sorry again.
Its happened to many of us here so we go back to our basics.
Hunt for a good FNG in Bombay...am sure you'll find someone. But the number of good FNG's in mumbai is horrible. I suffered in the early part of this century when I took my Yezdi there for a year. Horrible.
Tried reaching out to Allan?
Red Liner is offline   Reply With Quote
Old 2nd June 2012, 04:03   #32
ringoism's Avatar
Thanked: 1,250 Times
Default Re: Water Pump Failure - Why and How?
I worked for a company that remanufactured water pumps for all makes of cars, and can only conclude that there was a defective bearing involved in your case. Running a pump dry would only damage the seal, not the bearing. And since you saw no leakage, your seal was okay. An over-tight belt is not a good thing, but these bearings are very, very tough with extremely high radial load ratings, and it is pretty unlikely that one could fail in three months only because the belt was over-tight. Unless, maybe, one of your pulleys has a groove that's non-concentric to the shaft, and it's putting REALLY high and oscillating loads on it. But really, I suspect it's just a bad batch of pump bearings that maybe they left the grease out of or something.
ringoism is offline   Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 705 17th January 2018 13:43
Fuel Pump Failure rakowli Technical Stuff 54 23rd August 2016 20:52
Swift Service - Brakes and Water Pump Drive Belt Question carboy Technical Stuff 13 14th February 2011 14:01
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 11:16
palio 1.2 nv 'pressure sensor error and water pump issue' kapilsharma80 Technical Stuff 5 17th September 2007 17:58
