Old 11th June 2012, 15:09   #121
KSM-Vtec's Avatar
Thanked: 439 Times
Default Re: Gypsy '09 Heating problems!
Originally Posted by scooby05 View Post
Finally, I have changed the set up. It is in line with what someone on this forum suggested. i.e. The heat exchanger has gone below the floor pan above the prop shaft with its own electric fan and a perforated sheet metal guard.....No Heating at low speeds because of the electric fan, and obviously no heating now at high rpms/speeds because of no hinderance to the air into the radiator. Hooray!
Scooby sir...any updates in the setup? hope you have not faced any over heating problems since then. looking forward to some pics of the setup. Will be really helpful.
Also has the AC cooling inside cabin been impacted due to the under-body location of the condenser?
Is there an electric fan between the under-body and condenser also?
KSM-Vtec is offline   Reply With Quote
Old 12th June 2012, 14:04   #122
Thanked: 87 Times
My car is in Khandala, so next time I go there shall take snaps and post here.
In the meanwhile, I face a problem without the AC on, as the electric fan outside the front radiator only comes on with the AC causing overheating on expressway hill climb. So need to change the circuit.
scooby05 is offline   (1) Thanks Reply With Quote
Old 12th June 2012, 14:32   #123
KSM-Vtec's Avatar
Thanked: 439 Times
That would be great!
But the problem you are facing now is only because you dont have the mechanical fan. Right? please correct me if i am wrong.
Under normal circumstances the mechanical fan would prevent the overheating when the AC is off.
Old 12th June 2012, 14:37   #124
Thanked: 87 Times
Yes I guess will revert to the mechanical fan up front. Lesser electronics and failure scope.
scooby05 is offline   Reply With Quote
Old 12th June 2012, 14:40   #125
KSM-Vtec's Avatar
Thanked: 439 Times
Well just changing the circuit should do the trick easily in that case. Not sure if reverting to the mechanical setup is worth the money.
Also do you have an additional electric fan between the under body and the condenser?
Old 12th June 2012, 14:41   #126
Thanked: 113 Times
So how does the mechanical fan work? Depend on wind pressure to rotate?
--R
Ragul is offline   Reply With Quote
Old 12th June 2012, 14:42   #127
KSM-Vtec's Avatar
Thanked: 439 Times
--R
It depends on the engine rpm, its connected with a pulley and a belt.
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
Heating & oil pressure problems on MM550 wayfarer 4x4 Technical 24 2nd October 2008 18:30
Power Steering and Over heating Problems In my Sierra sag_kv Technical Stuff 8 9th May 2008 12:42
