View Poll Results: Where should I mount the lights?
Option 1 - Between the headlights 76 48.41%
Option 2 - on the sides 3 1.91%
Option 3 - on the roll bar 11 7.01%
Option 4 - on the windshield 9 5.73%
Option 5 - on the bull bar 39 24.84%
OPtion 6 - retain existing ones & add D shackles in the front 11 7.01%
Option 7 - none. upgrade existing lights 6 3.82%
Option 8 - Other. Please specify 2 1.27%
Voters: 157. You may not vote on this poll
Old 10th April 2010, 09:22   #46
jeepster's Avatar
Thanked: 1,047 Times
Originally Posted by saintsinner View Post
The 1010 & 1111 come with 50/55
the 1111 has an option of 100Watt bulb too. It is mentioned in their online catalog.
specify link for the online catalog , googled it but no luck.
jeepster is offline   Reply With Quote
Old 10th April 2010, 12:22   #47
Thanked: 54 Times
here you go Automotive Headlamps Manufacturer,Auto Head Lamps,Automotive Head Lamps,Auto Headlamps Manufacturer,Car Head Lamps,Automotive Headlamp Exporters
on the second page you have the 1010 , I have used a combination of two 1111 and two 1010 (1111 in the centre and 1010 on the ouside) the lights were good enough night driving. They aren't bad at all for the price you pay.
techn0l0gist is offline   Reply With Quote
Old 10th April 2010, 14:56   #48
exactly, though lightforce is the best ever. i would think twice before putting around 30K for the 240 blitz. importing them as checked baggage is a different story though
thanks for the link bro!
saintsinner is offline   Reply With Quote
Old 11th April 2010, 18:27   #49
jeepster's Avatar
thanks for the link.
that hella & light force delver the best light. but 30-40k is a big amount in India thus most offroaders will consider some serious mechanical upgrades or some repairs .
in 30k we can
  • overhaul a xd3p/xdp4.90.
  • gearbox overhaul /swap
  • new wiring, paint, top.
  • tyres
  • may be winch or lsd
  • axle repair or swap
jeepster is offline   (1) Thanks Reply With Quote
Old 18th April 2010, 06:41   #50
Sha
Sha's Avatar
Originally Posted by harjeev;1830054
@Sha
My gosh, just look at the beam go!!! Simply amazing.
I think that this must be a long exposure[B
LE[/b], if not then the lights are simply killer dude!
& if it was a LE then please share the exif data!
thanks
Its long exposure shot.
are these the blitz or the striker?
Its 170 Striker..
Sha is offline   Reply With Quote
Old 18th April 2010, 07:31   #51
arjunrudra's Avatar
Thanked: 13 Times
I have a set of lightforce lights and a pair of roo lights. The lightforce hae greater spread and the roo have a more penetrating effect. Totally love the lights.
I think they are simply the best.
Also got a set of filters for the same. Got blue for the lightforce and yellow for the roo lights.
arjunrudra is offline   Reply With Quote
Old 29th May 2010, 18:48   #52
karizma9292's Avatar
Thanked: 210 Times
hey guys , where can i get these kinda lights in Bangalore and how much would it cost ? . Im planning to put this on my Gypsy's roof .
karizma9292 is offline   Reply With Quote
Old 12th August 2010, 12:26   #53
Samurai's Avatar
Thanked: 15,968 Times
After the horrendous experience of fog+rain driving after the Sharavathy OTR, I wanted to upgrade my auxiliary lights.
Most fog lights we see or have are actually yellow spot lights. What you really need in fog driving is a wide beam of light illuminating the road just ahead. The long range spot lights just create a diffused light wall in front of you.
After some brainstorming, the following came highly recommended. A work light used in JCBs. They are very short range, and have a very wide beam. The model name is Neolite 714.
I picked up 6 numbers of it at Jann's marketing services JC road) at 390 per item. We needed more, but they ran out of stock. More expected next week. On the way back we found another similar model from Hilux for just 140 bucks. The datasheet given here: http://www.hiluxautoelectric.com/det...terex-9-43.htm
Samurai is offline   (1) Thanks Reply With Quote
Old 12th August 2010, 13:03   #54
sreejeshmp's Avatar
Thanked: 576 Times
You Did it! I am also searching for the same JCB Spot light in Calicut for My new Major(Still in Mahindra Factory) But I couldn't.Waiting for the review and pics.
sreejeshmp is offline   Reply With Quote
Old 12th August 2010, 13:05   #55
Tejas@perioimpl's Avatar
Thanked: 5,491 Times
Samurai, where are you planning to mount them and how many?
Tejas@perioimpl is offline   Reply With Quote
Old 12th August 2010, 15:49   #56
Gypsy-Boy's Avatar
Samurai - Hella has something similar known as farm lights.
They are also good for close-up lighting.
GB
Gypsy-Boy is offline   Reply With Quote
Old 12th August 2010, 16:01   #57
Samurai's Avatar
I will be replacing my current auxiliary lights with this one. Planning to mount only 4 of them, rest was for others who wanted it.
I'll keep the expensive ones for GV. The Jeep can manage with cheapo lights.
Old 13th August 2010, 08:31   #58
4x4addict's Avatar
Thanked: 2,681 Times
@samurai:
You are right about the different types of lights. Most Indian manufacturers and general consumers just refer to them as *fog lights*. There are many different categories based on the type of beam from the light.
As you correctly said the fog lights should throw a very low/wide beam which doesn't go out far otherwise the moisture particles will deflect the light back to your eyes. Fog lights are best placed low. In jeeps the bumper is ideal for them.
4x4addict is offline   Reply With Quote
Old 13th August 2010, 08:40   #59
It all depends on why do you want them. In India, you're right, all ancillary lights are referred to as fog lights.
Sharath needs them for applications in fog. Me and other friends use them more for night offroading applications where even the length of the beam is important. In such a case higher, the better.
Old 13th August 2010, 11:39   #60
4x4addict's Avatar
Agreed, but in this case fog lights are not the best lights for this. You should go for long range/driving lights.
Off-roading papps Street Experiences 15 26th August 2008 16:53
Off-Roading in Delhi JEEPs & Other 4WDs -04 Feb 2007 ex670c Indian Motorsport 7 5th February 2007 13:30
Zen goes off roading ... khaadu75 Street Experiences 17 26th December 2006 17:13
Off Roading with Kini,bikes,M800 & Wagon R kpzen Street Experiences 10 19th February 2006 16:38
