Old 13th March 2010, 17:14   #1
ladak.imran's Avatar
Default Grinding sound/sensation | Maruti Gypsy
Hi guys,
I need a little help.
Off late, I've started noticing a grinding sound/sensation coming from the passenger footwell of my gypsy.
When I sit on the passenger side, and someone else is driving the car, i can feel something grinding under my feet. Its like something is rotating, and grinding periodically.
I recently went to a MASS, and the guy there told me that the exhaust pipe is touching the body from underneath, which is why i can sense the grinding thingy..
I don't think he's right..
Any ideas as to what this could be?
Thanks..
ladak.imran is offline   Reply With Quote
Old 13th March 2010, 19:59   #2
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
I felt the same when the exhaust pipe of my classic got dented and touched during an OTR. So could be the reason. Also check the propellor shaft for play.
Tejas@perioimpl is offline   Reply With Quote
Old 13th March 2010, 22:28   #3
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
usually grinding noises originate from/near rotating members like crankshaft, bearings, propeller shafts etc
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 13th March 2010, 22:38   #4
DirtyDan's Avatar
Thanked: 776 Times
Spike
Front brake disc pad worn out? Brake Calipher stuck?
Old 13th March 2010, 22:45   #5
Thanked: 809 Times
The rotor still rotates isn't it?
Spike
Old 14th March 2010, 00:00   #6
DirtyDan's Avatar
Thanked: 776 Times
Spike
Most sticking caliphers only stick a little, allowing the wheel to turn, doesn't they?
Old 14th March 2010, 00:27   #7
Yes - the wheel turns, but i did feel that the vehicle was not rolling as freely as it should!
I'll get the prop shaft and exhaust checked out too, along with the brake calipers..
Also, these days, when i gently touch the breaks, a squeaking/squealing sound can be heard - only when i just start driving though - after say, 10 minutes of driving, the brakes dont make any noise...
Someone else had suggested i get the bearings checked as well! Thanks everyone for your help... i'll get these things checked out on monday...
I should be able to go for the OTR to lonavla tomorrow though, i think...
Old 14th March 2010, 07:07   #8
DirtyDan's Avatar
Thanked: 776 Times
Yeah, bearings are the most likely problem, then brakes, from what you describe.
Old 14th March 2010, 19:25   #9
Jaggu's Avatar
Thanked: 8,693 Times
Jack the axle up, turn it and figure out if its, brake, bearing, or if its axle
grinding when first gear engaged cheatingdeath Technical Stuff 14 28th June 2009 15:25
effect of grinding EGR valve in diesels reachbennym Technical Stuff 1 23rd December 2008 09:05
Grinding noise in gear-change! ramzsys Technical Stuff 3 1st October 2007 22:37
Burning sensation in eyes while in the car Sush Shifting gears 10 21st April 2005 22:31
