Old 17th March 2010, 19:25   #1
Tejas@perioimpl's Avatar
Thanked: 5,479 Times
Default Spare Wheel Cover - Do i really need it?
I'm going in for a tyre upgrade in my Mahindra Classic and the original tyre cover will not fit onto the new spare tyre and i will have to get a new one made.
Old: 215/75/15
New: 235/75/15
That got me thinking, is a spare wheel cover that important? Somebody has told me the spare tyre will deteriorate if not covered.
My tyres are directional, so rotation will be only one sided. Thus, not very practical. Otherwise rotating with the spare is the best thing to do.
A quick web search gave the following results:
So, are you going to buy covers to put on the other four wheels? Didn't think so, yet they are going to cop the same amount of sun, rain and God knows what as the tyre on the back (or underneath). So why aren't you worried about them?
The truth is that sunlight will deteriorate that tyre over time.
The tyres stored underneath copping mud etc are much more likely to be usable when you need it as a spare.
Tyre life is generallt recognised to be best used within 5 years of the date of manufacture, so if I where you I would be covering up.
Many blow outs occur due to a spare being fitte after years of sitting in the sun on the back of a vehicle.
The only advantage that I see in a cover is it may hide an expensive brand new tyre from some thieving ****'s eye sight. and make him do more work to remove the cover to steal the tyre.
the only advantage is that you can give a personalized look to your jeep
Put in your thoughts and insights...
Tejas@perioimpl is offline   Reply With Quote
Old 17th March 2010, 19:30   #2
Thanked: 420 Times
Depends how costly is spare wheel cover. On a Safari for instance the wheel cover is around 8K and it is more likely that cover will be stolen rather then tyre.
If you are going for 5 Tyre rotation I do not see any particular value in putting a spare wheel cover.
amitk26 is offline   Reply With Quote
Old 17th March 2010, 19:33   #3
Not costly. A cheap rexine one.
Can't do 5 tyre rotation due to directional tyres.
I'm looking for answers to the fact that does the spare wheel cover help protect the tyre?
Old 17th March 2010, 20:10   #4
Thanked: 23 Times
I would put a cover on even if only one of those cheap ones. Someone told me with the wheel hanging off the rear, the sun directly shining on it can lead to spares cracking etc in the long term.
If you have trouble getting one just ask your local car seat wala to make you a custom on out the material they use to make the roofs for jeeps. Should not take him more than an hour.
bigman is offline   Reply With Quote
Old 17th March 2010, 21:17   #5
Jaggu's Avatar
Thanked: 8,685 Times
I prefer not to cover it up, keep it cleaned and rotate every 5k kms, directional or not. As simple as that.
Old 17th March 2010, 22:02   #6
SS-Traveller's Avatar
Thanked: 11,627 Times
If this was Delhi, with over-50-degrees-C temperatures and less than 20% humidity, I'd say cover the tyre up - a cheap white/light-coloured rexine cover would do. Since you're in Mumbai, where the peak temperatures in summer are not that bad, and the ambient humidity is much higher, you can happily leave the spare wheel uncovered.
Old 18th March 2010, 04:52   #7
DirtyDan's Avatar
Thanked: 776 Times
When you have a puncture it is maddening to have to fool around with a lock that is full of dirt and dust and will not open to release the spare tyre. I suggest you at least find a way to cover the lock.
Old 19th March 2010, 10:28   #8
I got the new tyres. Thankfully the old cover fits the stepney. So problem solved.
However, i want to know if there is a disadvantage of not covering the spare!
Old 19th March 2010, 10:32   #9
Jaggu's Avatar
There will be no disadvantages if you plan to use it in regular intervals, which you should ie if you want to make the purchase VFM.
Old 19th March 2010, 10:36   #10
ashthedivx's Avatar
Thanked: 22 Times
Even I do not find any good reason which can be termed as disadvantage of not covering your spare wheel.. however, "the more you cover the more use" is always there..
Old 19th March 2010, 10:45   #11
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Post
Tejas, as you know tyre properties change and tyres degrade if not put to use, this is one reason why tyres (without wheel rims) are supposed to be stored in a cool dry place away from sunlight. You just need to rotate the tyre as per prescribed intervals. Also you should be careful while buying tyres which are more than 6 months old.
Spike
OT- IIRC "rubbers" also come with expiry dates, isn't it?
SPIKE ARRESTOR is offline   Reply With Quote
Old 19th March 2010, 10:53   #12
Originally Posted by SPIKE ARRESTOR View Post
Tejas, as you know tyre properties change and tyres degrade if not put to use, this is one reason why tyres (without wheel rims) are supposed to be stored in a cool dry place away from sunlight. You just need to rotate the tyre as per prescribed intervals. :
These are directional tyres. So rotation will be one sided only (left side in my case)
Can anybody put down what exactly happens to the tyre compound on exposure to sunlight, over age and when not used for a long time. Why does a tyre which is in use daily have a better life than the spare?
DIY : How to secure a Tata Safari Spare wheel cover from theft dadu DIY - Do it yourself 25 14th June 2010 12:19
Yellow board running with my stolen spare wheel cover - what to do next? HappyWheels Street Experiences 57 1st June 2010 16:34
Spare Wheel Cover for Ford Endeavour Berry Modifications & Accessories 3 24th April 2009 00:07
Spare wheel cover for my Bajaj Super abdriver2000 Motorbikes 10 21st April 2009 14:32
Rear View Mirror of 2.2 VTT DICOR and spare wheel cover clamp sunishsamuel Modifications & Accessories 5 20th March 2008 19:57
