View Poll Results: Diff locks or Articulation, what do you choose?
Diff locks - I think they are more important than articulation 21 61.76%
Articulation - With excellent articulation, diff locks are not really needed 13 38.24%
Voters: 34. You may not vote on this poll
Old 23rd March 2010, 11:33   #16
Jeepy's Avatar
Just check this pic....
http://www.orkut.co.in/Main#AlbumZoo...=1263971089108
With excellent articulation, diff locks are not really needed ....as per my experience.
Last edited by Jaggu : 23rd March 2010 at 12:35. Reason: Back to back post, please EDIT the original post instead while editing within 15 mts. Thanks
Jeepy is offline   Reply With Quote
Old 23rd March 2010, 11:54   #17
Samurai's Avatar
Thanked: 15,775 Times
If only one wheel in each axle has traction, how is articulation going to help you?
Old 23rd March 2010, 11:56   #18
tsk1979's Avatar
Thanked: 16,422 Times
Exactly what if you are in a slush rut with two left wheels in slush, and 2 on dry ground. Even if your vehicle has the best articulation in the world, you are stuck.
Old 23rd March 2010, 12:04   #19
Jeepy's Avatar
Yes if ur tyres are good enough and if u have better articulation one wheel in each axle will do the job, pl check the snaps in the url mentioned above......
Old 23rd March 2010, 12:16   #20
Samurai's Avatar
You think you can get Arka to agree with this statement?
Old 23rd March 2010, 12:24   #21
ex670c's Avatar
Thanked: 1,821 Times
Default Tyres
Hi Sharath,
I partly agree to the statement. This will be true if the tyres are very grippy and there is sufficient weight on the mentioned wheels.
However, in such cases we tend to rev the vehicles (open diffs) resulting in strain and failure of the Tyre/ Steering knuckle/ Axle/ Prop-Shaft.
Arka
Old 23rd March 2010, 12:26   #22
tsk1979's Avatar
Well if the tires are grippy, then there is no case of losing traction. The question being asked is that if one tire on each axle loses traction(snow/slush etc.,) will an open diff vehicle move? Well it won't no matter how grippy is the tire retaining traction is. In that case a LSD will help, and diff lock will definitely do the trick.
Old 23rd March 2010, 12:36   #23
Samurai's Avatar
Originally Posted by ex670c View Post
Hi Sharath,
Arka, I specifically said no traction, that is in spite of grippy tyres or weight on the wheels.
Old 23rd March 2010, 12:45   #24
vinod_nookala's Avatar
Thanked: 416 Times
I did not take the poll because both are not mutually exclusive! Hence you cannot choose only one!
According to me an off roaders basic virtue is to have sufficient articulation, diff locks are an advantage over it.
A way to offset lack of differential locks is by providing articulation, but articulation alone will not take you every where. Diff lock is like feather on the cap. But cap in itself is necessary.
Just a small example where one can get away with articulation without diff locks. However if this trail was slippery, then diff locks would have been required if negotiated without sufficient momentum. Bolero struggled even on hard ground in slow speed to clear this stretch due to insufficient articulation and road tires. Diff locks here would have made it easier for the driver to over come the obstacle in single shot
vinod_nookala is offline   Reply With Quote
Old 23rd March 2010, 12:45   #25
Jaggu's Avatar
Thanked: 8,693 Times
"I would go" for difflock, from a very different angle To improve articulation it takes a hell lot of work, diff lock in comparison is easier to achieve the results.
Whats the point of articulation when the darn axles cant put the power down to move the vehicle?
Old 23rd March 2010, 13:02   #26
ex670c's Avatar
Default Articulations
Hi Jaggu,
That's hell of a think to say, especially from a JEEPer.
Arka
PS - If you think Articulation = SPOA, then you are right.
Old 23rd March 2010, 13:13   #27
adc
adc's Avatar
Thanked: 2,103 Times
Hi ADC,
Diff-Lock will be needed more with Leaf-Spring, as Solid Axle Coil Spring offers better articulation.
However the Solid Axle Coil Spring suffer from a slight axle wrap under acceleration, which does not happen in Solid Axle Leaf Spring.
Arka
Thank much Arka, Another query would be like -
If there is IFS [as Thar], bad articulation and all, a front locker with IFS and LSD/MLD rear with leaf springs - the best possible combination [scenario] with the Thar?
adc is offline   Reply With Quote
Old 23rd March 2010, 13:44   #28
ex670c's Avatar
Originally Posted by adc View Post
If there is IFS [read Thar], bad articulation and all, a front locker with IFS and LSD/MLD rear with leaf springs - the best possible combination with the Thar?
Hi ADC
Sounds like a Force Gurkha to me.
Manufacturers rarely give Front and Rear Diff-Locks on Light 4x4s
i.e 1953 Delahaye VLR
1979 MB G-Wagen
2003 JEEP Wrangler Rubicon
In the 1990s Diff-Locks became the Buzz-Word and everyone (OEM) started fitting one on the Rear Differential.
Auto-Locker and M&M MLD are similar in purpose - Locked in Straight Lines, Opens on Turns.
I don't know of any other manufacturer fitting Auto-Lockers/MLD as OEM.
LSD is OEM since the 1960s for many Car & 4x4 manufacturer.
An LSD/MLD/Auto Locker up front (Diff) can cause serious steering issues, with out a Free-Wheeling Hub so Don't Expect them OEM.
Arka
Old 23rd March 2010, 14:15   #29
adc
adc's Avatar
Hi ADC
Ha ha, mostly but for big torque difference. All the benefits of the Gurkha are lost there, my own inference and could be wrong.
As for Thar - Absolutely there's no way that is coming as OEM, and even what the OEM is and how much - big mystery still .
Anyway, another point is like only with front diff locker and rear with LSD - straight line situation okay, but what happens when making a turn in slippery mud track
But if it is a more or less straight line in ice or mud with width available, with front locked there would be more traction A front locker with rear LSD is a good start - before one gets funds for getting the rear locked?
Old 23rd March 2010, 14:28   #30
Jaggu's Avatar
Hi Jaggu,
Arka
Ayoooo! Arka i was speaking without reference to any particular model or make, i thought the question was that???
So if i have a choice of having these 2 options in any of the vehicle, which will i pick up?! and hence the reply.
Hope this clears and you will not chase me in my dreams
Diff-Locks vs LSD khan_sultan 4x4 Technical 124 2nd October 2017 07:57
Articulating on Articulation Brutus 4x4 Technical 142 7th July 2015 16:41
Mahindra Pik-up / Getaway - Export version with Diff Locks Parm 4x4 Vehicles 6 22nd April 2014 15:41
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
