Old 24th March 2010, 20:38   #1
abheekg's Avatar
Thanked: 173 Times
Default can a battery short circuit in Gypsy fry the Clutch ?
I recently had a situation during one of my jungle sorties in my gypsy when I had hooked up my spotlight to my battery terminals using crocodile clips and inadvertently failed to notice the absence of insulation on one of the clip terminals.
The result : 5 kms into the jungle , I noticed a bright red spot on my bonnet which was a result of the crocodile clip coming in contact with the bonnet after hitting a pothole. Immediately the headlights shut down. I had the presence of mind to switch off the engine immediately and raise the bonnet, but in hurry touched the red hot terminal with my bare hands which resulted in a small burn on my forefinger tip.
After sorting out the mess when I started my gypsy , I immediately noticed that the clutch had become very hard to engage and was engaging with a slight grinding feeling.
I had changed my clutch when I had done the initial work on my vehicle 8 months back and the new clutch has run for about 15000 kms till now.
It was all smooth and easily engaging till before this incidence .
My question is what happened to my clutch during the battery short circuit ?
Has anyone ever experienced something similar ?
What are the situations when the clutch can fry like this ?
What possible steps can I take without dismantling my clutch assembly to check the integrity of my clutch ?
Expecting inputs from the gurus as always .
Please let me know if you need any more information on the behaviour of the clutch for the diagnosis part.
regards,
Dr. Abheek Ghosh
abheekg is offline   Reply With Quote
Old 24th March 2010, 21:09   #2
Check your clutch cable. Possibly shorted somehow and the liner melted.
Dont know how likely it is but worth a check before dismantling the clutch.
My bonnet release cable once had this problem as it had managed to continuously rub itself onto an open terminal. Eventually all the insulation wore off and the cable shorted.
Leop is offline   Reply With Quote
Old 24th March 2010, 21:20   #3
Jaggu's Avatar
Thanked: 8,671 Times
Very weird issue, might worth checking the cable, pedal and springs first. Then the cable attachment which sits on the gear box. If all these are clear then you have no choice but to open the clutch assembly and inspect.
Old 24th March 2010, 23:07   #4
jav
I don't think the clutch has fried, even i feel its the cable which has been affected.
Without dismantling the clutch the sure way of knowing if clutch has worn/burnt is if the rpm rises without speed increase during acceleration and or excessive vibrations/judder during clutch release especially in first gear and reverse.
jav is offline   Reply With Quote
Old 24th March 2010, 23:20   #5
star_aqua's Avatar
Thanked: 89 Times
Here you will find some answer http://www.team-bhp.com/forum/4x4-te...-too-hard.html (Clutch of my MM540 is too hard...)
star_aqua is offline   Reply With Quote
Old 25th March 2010, 09:36   #6
Gypsy-Boy's Avatar
Abheek
The clutch cable passes quite close to the battery in the Gypsy. In all probability, the heat got transferred to the cable and the inner has melted, making the "clutch" hard.
Try changing the cable first.
GB
PS - please fix this before you use the gypsy for long drives as you will end up actually frying the clutch, due to the cable being unable to release the clutch fully.
Gypsy-Boy is offline   Reply With Quote
Old 25th March 2010, 12:57   #7
abheekg's Avatar
Thanked: 173 Times
Thank you everybody. I will replace the clutch cable and get back to you with the result tomorrow.
regards,
Dr. Abheek Ghosh
Old 25th March 2010, 14:03   #8
Rehaan's Avatar
Thanked: 25,037 Times
I cant think of a single reason why you would have to open up the actual clutch assembly.
As everyone else has said, its probably the cable.
Goodpoint!
cya
R
Old 31st March 2010, 19:07   #9
abheekg's Avatar
Thanked: 173 Times
Thank you everyone for your inputs. The change of clutch cable solved this problem. the inner liner had been damaged because of the battery short circuit.
This problem was an eye opener for me. Ihad never imagined something of this sort to happen.
Electrical short circuit in an accident? vina Technical Stuff 6 18th March 2013 12:38
Driving the Ford Fiesta dual-clutch Automatic on the Buddh International Circuit benbsb29 Test-Drives & Initial Ownership Reports 31 19th April 2012 16:17
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Beijing menu: scorpion fry, seahorse kebab mjothi Shifting gears 59 21st August 2008 13:25
Did I Fry my Esteem Clutch?? ad75 Technical Stuff 19 28th November 2007 12:07
