Old 6th March 2010, 17:21   #1
khan_sultan's Avatar
Thanked: 3,872 Times
Default Spacers & OffSet Wheels for putting in bigger tyres | Pro's and Con's
Got the spacers installed today and sometime later will get the tyres installed also. There is a noticeable difference in the stance of the Gypsy -- because of the wider track and looks cool even with 235/75/15 Maxxis :-)
Here are some pictures.
Difference between OE studs and extended studs
Spacers & OffSet Wheels for putting in bigger tyres | Pro's and Con's-img0200a.jpg
The spacer mounted on the rear wheel with extended studs
Spacers & OffSet Wheels for putting in bigger tyres | Pro's and Con's-img0202a.jpg
The original/without spacer picture showing the rear tyre.
Spacers & OffSet Wheels for putting in bigger tyres | Pro's and Con's-img0204a.jpg
The picture showing the rear tyre with the spacer -- notice that the tyre is jutting out now :-). This will prevent any rubbing/scuffing of the bigger size tyre that I will be putting on soon.
Spacers & OffSet Wheels for putting in bigger tyres | Pro's and Con's-img0208a.jpg
khan_sultan is offline   Reply With Quote
Old 7th March 2010, 14:23   #2
Salikt's Avatar
Thanked: 33 Times
Originally Posted by khan_sultan View Post
and 1" spacers for a wider stance. The track width now should be ~53.6 inches.
Helo Khan bai,
How much cost those spacers? Off the shelf or custom made??
Thanks,
sadiq.
Salikt is offline   Reply With Quote
Old 9th March 2010, 18:21   #3
ladak.imran's Avatar
Khan bhai,
Will these studs be strong enough to survive otr's ?!
I've always been under the impression that spacers=no-no ..
Looking forward to your reviews soon!
ladak.imran is offline   Reply With Quote
Old 19th March 2010, 15:26   #4
Gypsy-Boy's Avatar
Khan
In the spacer as you have mentioned, the bolts are the weak point.
You will need to make a spacer like the attached image in Stainless Steel.
You will have to use the original bolts and bolt it onto your drum/disc, There will be an additional set of bolts set in the spacer to which you can fix the wheel.
I had used this method in my drag car setups, after tearing through some of the extended bolts.
Gypsy-Boy is offline   Reply With Quote
Old 23rd March 2010, 11:46   #5
Thanked: 66 Times
hey Shanawaz,
must warn you though that gypsy axles have a weakness with spacers on
the front axles just snaps,
have broken three axles already while testing my green spos gypsy,
lots of guys abroad swap toyota axles and get spacers on them,
regardig the fused wheels, for the flight of the hawkz, was runnning three spoke alloys as the fused ones were not tesed yet,
have put them on now, shall pm you results soon
regards,
Allan
(why the geolander m/t.......not good tyres in my opinion)
xtreme power is offline   Reply With Quote
Old 23rd March 2010, 18:58   #6
Originally Posted by xtreme power View Post
hey Shanawaz,
Oh man, don't sacre me now.
But, I see lots of Gypsy/Samurai with -ve offset wheels. So what's the difference in having a 1" spacer or a 1"-ve offset wheel? Why should it break the axle with spacers and not with -ve offset wheels?
YES. I am looking forward to some news from you on this front. Been long time now.
Got them cheap -- that why I put them on.
Originally Posted by Red Liner View Post
You dont get get Maxxis beyond 29 inches?
Yes you get, but I got these at pretty reasonable prices so went for them.
Old 24th March 2010, 13:46   #7
ex670c's Avatar
Thanked: 1,821 Times
Default Weight
Hi Shahnawaz,
The Spacers put additional weight on the axles.
If each Spacer weighs 1Kg then 1 X 4 X No. Wheel RPM (For Road Speed) = Additional Work.
Also in your spacer the wheel studs are too long, and they will carry all the load and bear the brunt of wheels jumping up and down (OTRs).
It is preferable to bolt the spacer to the original hub and then bolting the Wheels onto the spacer.
Arka
Old 24th March 2010, 17:16   #8
Originally Posted by ex670c View Post
...The Spacers put additional weight on the axles.
Agree on additional weight part but shouldn't the alloy wheels be lighter than say steel wheels? So even if we have 1kg spacer put in, it should be lighter than steel wheel thus resulting in total weight on axle being less than before?
100% agree and an aspect of my setup I am not 100% satisfied about. This longer stud is a short term solution and I am in the process of going in rectifying it soon.
Can you PM me the price or better still, I'll ask you over the week-end unless you're campaigning for the JDS (which is what I last heard from the grapevine!)
Yeah, I am one of the criminals that JDS has given a ticket to, hoping that I will 'reform' the society. So, that also means I will not be attending the night OTR
Old 24th March 2010, 17:23   #9
Samurai's Avatar
Thanked: 15,775 Times
I feel the additional stress is due to cantilever effect (the load has moved further out), the reduced weight of alloys doesn't compensate for it. Anyway, let's listen to pros instead, I last studied structural mechanics 22 years back.
Old 24th March 2010, 18:54   #10
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Post
Samurai you are right, it is this extra leverage which creates stresses due to bending moments ultimately leading to shear (remember BM and SF diagrams?) This is also called as Offset swivel, i am attaching a pic for more clarity. Negative offset alloys will partially negate this effect, although not fully.
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Old 24th March 2010, 23:13   #11
Thanked: 7 Times
Spike
In simple words, the spacers provide the wheels with the leverage required to snap your axles
@Khan_sultan :This will probably happen sometime when you're "pushing it" on rocky terrain. Further, Spidey's ultra-low rock-crawling ratio and lockers will make it more likely. Any plans for a FFRA mod? Besides make chances of failure less likely, in case it does snap 1) It will be far safer & 2) You won't be stranded in the boonies, you can atleast be towed back.
@Spike : How will the effect be negated with the wheels being off-set Vs spacers? Will the forces exerted behave differently?
Best regards to all.
'72 Bullet is offline   Reply With Quote
Old 25th March 2010, 08:45   #12
Thanked: 809 Times
Addition of spacers make the offset positive, hence inorder to partially negate this effect negative offset wheels may be used.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 25th March 2010, 11:45   #13
Thanked: 7 Times
Spike
Thank you
Old 25th March 2010, 16:39   #14
Rehaan's Avatar
Thanked: 25,043 Times
Agree on additional weight part but shouldn't the alloy wheels be lighter than say steel wheels? So even if we have 1kg spacer put in, it should be lighter than steel wheel thus resulting in total weight on axle being less than before?...
In theory, possible. In reality - less possible.
When most people opt for alloys they generally upsize on many accounts - larger rim (more metal rim as opposed to rubber sidewall), wider rim (more metal again) and wider tyre (more rubber + radial belt weight).
Depending on the extent of the upsize, the end result could quite possibly be a heavier tyre + wheel combo!
That put aside, its the law of moments (leverage) that puts more stress on the suspension et al than the weight.
cya
R
Old 25th March 2010, 16:54   #15
Shan2nu's Avatar
Thanked: 89 Times
This reminds me of Chop Shop. Man those guys use such huge spacers. Scary stuff.
Its always best to maintian recomended wheel offset/position.
Shan2nu
Eicher introduces 3 reefer trucks - Pro 1059XP, Pro 1100XP and Pro 6025 Aditya Commercial Vehicles 0 22nd December 2015 18:01
Eicher launches Pro 8031XM, displays Pro 6025T trucks at EXCON 2015 Aditya Commercial Vehicles 0 26th November 2015 14:40
Suspension Spacers or Tyres with higher profile? Which is better?-Speed breaker issue WhiteKnight Technical Stuff 56 27th November 2012 12:00
Lease or loan? Pro's and Con's of each. Rtech Indian Car Loans & Insurance 16 4th October 2006 16:50
