Old 16th April 2010, 10:02   #16
Thanked: 12 Times
Originally Posted by ex670c View Post
SPOA will always improve the ride.
Arka sir,
Is this because the leaf springs are under compressive load normally on road rather than tensile load as in a sping under axle setup?
conjon is offline   Reply With Quote
Old 16th April 2010, 18:47   #17
ex670c's Avatar
Thanked: 1,821 Times
Originally Posted by diesel_maniac View Post
Hi Arka,
For a layman like me going for SPOA setup on a vehicle means it will increase the overall height. Since I have no experience or knowledge about the effects of a SPOA job on a vehicle's ride and handling. Please elaborate what benefits can one expect from a SPOA setup. This information will be very educative and inspiring to upcoming Jeepers like me.
regards
Originally Posted by conjon View Post
Arka sir,
Hi Guys,
I'm not thorough with the tech stuff on this. But it as the Axle Center will change relative to the Leaf Spring Eyes (Triangulation) also the Leaf Spring will pivot on the Axle Tube.
I think Spike Arrestor can make a better and more elaborate explanation.
Arka
Old 22nd October 2010, 10:33   #18
Tried out SPOA on the CJ3b. The handling, don't even want to talk about it !
Undoing it now.
jagat nanjappa is offline   Reply With Quote
Old 22nd October 2010, 11:13   #19
headers's Avatar
Thanked: 464 Times
That was fast Jagat. I was expecting the handling to go for a dive..Thanks for the reassurance.
Ride and handling are two different parameters and one should strike a balance [read as compromise during OTR].
Old 22nd October 2010, 19:24   #20
Jaggu's Avatar
Thanked: 8,694 Times
Jagat did you try wider axles? SWB taller you go, wider track will help compensate the handling issue to an extent.
Old 6th December 2010, 00:02   #21
svsantosh's Avatar
Thanked: 1,444 Times
Default SPOA Jeep - A Pictorial
Originally Posted by livyodream View Post
saw this SPOA'd jeep in coorg OTR. not sure of the model though
Attachment 326609
Attachment 326610
Attachment 326611
Attachment 326612
Attachment 326613
Originally Posted by krishnathanthri View Post
I had seen this Jeep in a Garage in Mysore. It was there for quite a few months
I happened to come across a SPOA Jeep, coincidentally in coorg. More coincidentally done up in Mysore.
This is owned by a estate owner, has participated in OTRs and more relevant, used as a daily drive. Necessity for the MOD was daily drive around the unforgiving paths/tracks around coffee estates around Coorg.
He said a few things that should sum up any questions from prospective modders...
1) Very easy to do, only need a competent garage/mechanic
2) no failures/breakdowns so faar due to increased joint angles
3) BAD shift in C.O.G on normal roads - something what Jagat said a few posts ago. This owner also was a rally'ist in the past.
Notice, no traction bar - and no failures till date with daily offroading activity around tracks. Of course none so demanding that may warrant a axle wrap prevention mod.
PS - Guess the vehicle
Njoy the pics... notice the experimenting with Rear Shocker mount on/off axle, reverting to u-bolt plate (whats that called).
svsantosh is offline   Reply With Quote
Old 6th December 2010, 10:11   #22
jeepster's Avatar
Thanked: 1,036 Times
its a 540/550 with NGCS setup.
jeepster is offline   Reply With Quote
Old 6th December 2010, 15:10   #23
svsantosh's Avatar
^^ Huh, not even close, on both fronts
I can understand the 5x0, but how did you relate to NGCS? No M&Ms IIRC are offered as SPOA.
Old 6th December 2010, 15:26   #24
offroad_maniac's Avatar
Thanked: 41 Times
Is it the first lot of Commander 750 series having BOX section rails?
I think those chassis were on few LWB Mahindras. They are same like older C sections but are boxed having tubular cross sections??
I think Invaders/ Strikers are offered with rear SPOA setup stock from factory.
offroad_maniac is offline   Reply With Quote
Old 6th December 2010, 15:57   #25
fazalaliadil's Avatar
Thanked: 626 Times
The rear differential has been tilted upward by 3" to minimize the tilt of the rear shaft, the front differential being in the stock position has the front shaft tilted at a ridiculous angle, subjecting the joint/ cross to extreme stress, wear and very good chance of breaking at the stress point.
Apart from the above, this 540 with a later model (tubular cross members) chassis loses on stability due to the body raise resulting in higher center of gravity.
fazalaliadil is offline   Reply With Quote
Old 6th December 2010, 18:26   #26
ex670c's Avatar
Default Guess
Guess the vehicle
Hi Santosh,
This looks like a pre 1998 Armada.
Peugeot Engine with Spike Arrester.
Arka
Old 6th December 2010, 18:49   #27
svsantosh's Avatar
Hi Off_Man, Fazal, Arka,
The vehicle was a 750 commander. Chassis# was CDR750..., I would have never guessed it, looked like a 540, but very purpose built for estate/farm use. The owner Harsha uses it for daily use, and has had no issues till date. Am surprised the front joint hasnt broken at such angles.
Arka - Can you help me identify the shocker on this, it is a silver painted gabriel gas-filled shock. I couldnt identify the part# under the dust and grime.
Thanks in advance...
Old 6th December 2010, 19:10   #28
jeepster's Avatar
here is a NGCS 650.
i guess both 750 & 650 use same NGCS setup.
Old 6th December 2010, 20:16   #29
sreejeshmp's Avatar
Thanked: 576 Times
Santhosh,
This type SPOA set up came as OEM for mahindra CL series type 4WD pik up
with DI engine.
sreejeshmp is offline   Reply With Quote
Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now.. khan_sultan 4x4 Technical 239 3rd February 2011 15:06
My New SPOA'd 550 xtreme power 4x4 Vehicles 156 20th March 2010 03:13
Xtreme Power's Spoa'd Custom Crawler(Gyspy No.2) xtreme power 4x4 Vehicles 22 4th January 2010 23:17
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
