Old 27th April 2010, 11:48   #1
A-jay's Avatar
Default Gypsy 410 front wheel wobble
Hi All,
I have been faced with serious front wheel wobble between the speed of 60 and 70.
The wobble is so bad sometimes that when i apply breaks it becomes even worse.There is no wobble of any sort before 60 or after 70.
I have had this issue recently after I have put on new alloys.The alloys are of a wider wheel base and are off set by -32. Have done the wheel balancing 4 times at two different places but nothing has changed. Also the alignment is done.
What could be the problem? Several mechs have suggested different resons like the kingpin rods need to be changed, bearing issues etc.
Did any of you face such a problem after putting on wider alloys.Also suggest a good mech who would be able to trouble shoot the issue.
Do suggest a resolution.
thanx
Aj.
A-jay is offline   Reply With Quote
Old 27th April 2010, 12:24   #2
Gypsy-Boy's Avatar
Looks like your kingpin needs some work done on it.
(I seem knowledgeable on this due to Q7A with my mech )
do PM me if you want to go to my mech
cheers
GB
Gypsy-Boy is offline   Reply With Quote
Old 27th April 2010, 12:41   #3
A-jay's Avatar
cheers
GB
can the king pin be corrected? they say I need to change the two roda between the front axle.
Gudie me to your mech . location and tel number.
Appreciate it ajay
Aj
Old 27th April 2010, 12:45   #4
Rajachu's Avatar
Ajay
i had the exactly similar issues once touched 60 km speed.for my gypsy there were 2 issues.first time was the tyre and once replaced done.2nd time due to kingpin.i feel if the tyre is OK problem wud be the kingpin only.
go to some MASS and check before concluding
Raj
Rajachu is offline   Reply With Quote
Old 27th April 2010, 12:59   #5
Jaggu's Avatar
Thanked: 8,693 Times
Try any mass and they should solve this. Sounds like the king pin, ideally replace it if its not a very expensive part.
Old 27th April 2010, 12:59   #6
A-jay's Avatar
Originally Posted by Rajachu View Post
Ajay
Raj
which mech would you suggest? please give me number and location.
Old 27th April 2010, 13:06   #7
Jaggu's Avatar
Sagar near Naga Theater Ulsoor used to be good with Gypsy's. Haven't been there in a while, otherwise try Suraksha right after silk board towards hosur, we have many gypsy guys visiting them from TBHP.
Old 27th April 2010, 13:13   #8
JeepCaptain's Avatar
Thanked: 468 Times
Appreciate it ajay
Aj
A-jay, wheel wobbling can be due to several issues or can be combination of more than one.
You said you have changed to alloys recently. But What about the tyres??
These are the major reasons for wobbling
  • Faulty / Old tyres ( try swapping front and rear tyres and check)
  • Worn out/Damaged King pin and king pin bearings
  • Worn out/Damaged axle bearings
  • Faulty tie-rod ends
  • Faulty connecting rods
  • Worn out/Damaged knucke kit
But before you do any of the above take it to a good mech or MASS and ask them to to a test drive first then bring it back to garage - jack up the vehicle and run the engine in gear and check it and see exactly what is causing it.If your mech is good he should be able to diagnose the issue at this stage.
Or if they still cant identify. check all the above and may be you can just rotate the tyres between front and rear and also change the knuckle kit if its worn out .
Meanwhile check all the bearings and steering links to make sure they are in good working order. Dont just replace any working parts just bcos the mech think its faulty.
Let me know the results
Shibu
JeepCaptain is offline   Reply With Quote
Old 27th April 2010, 15:30   #9
Rajachu's Avatar
Aj/Jaggu
Sagar now Solar is where iam servicing.But recently shifted to Arayn motors in Banaswadi main road near to ITC factory seems very regualrly getting gypsies for service from defence/govt and will provide the spare parts on time and service seems good.u can call Mr Perumal on 9741164445.any problem call me will cordinate.
raj
Old 27th April 2010, 17:39   #10
satan's Avatar
Thanked: 855 Times
If you are certain that its the front wheels then the recommendations are fine, however if the driveline is shuddering leading to a wobbling effect then get the Universal (cross) joints checked. If its a 1litre it may be time to replace them.
satan is offline   Reply With Quote
Old 27th April 2010, 19:21   #11
starter's Avatar
Thanked: 327 Times
Hey Ajay,
Let me know if you plan to visit Suraksha. (the place which Jaggu has mentioned).
I get my vehicle serviced there. I know them pretty well.
I could give you the service advisor's contact number.
Cheers,
Deepak
starter is offline   Reply With Quote
Old 28th April 2010, 10:16   #12
A-jay's Avatar
Originally Posted by starter View Post
Hey Ajay,
Cheers,
Deepak
I plan to go ther on friday or sat. Please give me the advisors name who is good with gypsies .
Do guide me to the place. i know its after silk board fly over bommanahalli.
Any directions and lank mark. Also phone number.
aj
Last edited by Jaggu : 28th April 2010 at 12:15. Reason: Back to back posts, please use Multi (Quote +) instead, Thanks
Old 28th April 2010, 10:52   #13
starter's Avatar
Thanked: 327 Times
aj
Dear Ajay,
After the silk board fly-over, when you start driving further, you would find the new elevated fly-over to electronic city. Do not take this elevated fly-over, instead take the normal road and you would find a traffic signal there. Take a U-turn at this signal entering the service road on the opposite side. If you drive for about 150 metres, you would find Suraksha.
You could talk to Lokesh/Rajesh over there and they shall help you out.
Cheers,
Deepak
Old 28th April 2010, 15:19   #14
siddartha's Avatar
Thanked: 24 Times
other than what has been suggested here, please check if if the rims are bent, gypsy rims do end up getting bent if they have been used badly.
siddartha is offline   Reply With Quote
Old 3rd May 2010, 19:24   #15
nikhil1300's Avatar
Hi All,
thanx
Aj.
were you able to solve your problem ,i am also facing the same problem
nikhil1300 is offline   Reply With Quote
Steering wobble right after wheel alignment & balancing? Tamarind Tyre & Alloy wheel Section 12 26th August 2016 17:50
Gypsy 410: Maximum Load Carrying Capacity atheistrical 4x4 Technical 12 9th December 2013 23:14
Maruti Gypsy SJ 410 to be done up Mud Slinger 4x4 Vehicles 13 7th April 2011 13:37
