| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| Distinguished - BHPian ![]() | It was bound to happen sooner or later. My Classic's tail gate has started drooping and it takes atleast 4-5 attempts to shut it properly. The added weight of the spare tyre has compounded the problem. What to do about it? I don't want to seal the door (some people have suggested it to me earlier). I will be adding a luggage rack in the near future to carry an ice box and jerry can. Thus, the door hinges need even more reinforcement. How to go about this? Can anyone give exact details so i can get the hinges reinforced by my local mechanic. I don't want to go in for a custom bumper with integrated tyre rack, etc. |
| | #2 |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
Thanked: 804 Times
| Why don't you put in new hinge and fix the tail gate. Then get a used spare tyre frame and fix it so that the weight is isolated from the gate. Its not a difficult job and is not costly also. Or remove the spare and put it inside on the floor, icebox etc can sit on top of it. Alternative find a heavy duty hinge, you have the contacts in spare shop so shop around. And try to add a sturdier lock system on the opening side to take the weight off, you can mount it inside if the available options are fugly. Best is to add the spare frame, since it will soon take the toll on the actual gate or the existing clamp etc ie assuming new tires are real heavy in comparison. Just curious how much of weight diff between old and new tires? shouldnt be more than a kilo right? |
| | #3 | |
| Distinguished - BHPian ![]() | Quote:
Give it a Break!!!! Now you want a MM550XD Tail Gate ![]() Check the M&M Major or the post 2002 MM550XD Tailgate and Swing Away Tire Carrier. Regards, Arka PS - Just Bolt the Tail Gate and let it be, don't spoil the orignality, besides there is a lot of scientific reasoning and engineering..... ![]() Last edited by ex670c : 12th May 2010 at 16:11. | |
| | #4 | |
| BHPian Join Date: Jul 2008 Location: pune
Thanked: 75 Times
| Quote:
If you want your tailgate to work and not rattle or wobble forget about the mahindra tailgate....you can reinforce it any which way it can only improve the problem a little. I know i have done it a number of ways, after a few otr's you will be back to square one. I will post pictures of my tailgate a little later in the day(it is incomplete and in the rough stages) It Is bolted to the chassis via a 4mm thick rectangular tube bolted at 6 points via 10mm bolts, the tailgate hinge uses ball bearings around a 25mm hardened pin. The tailgatee locking mechanisim,tyre bolting flange and the support bracket for the tailgate when closed is pending but next otr you can have look at the finished product. | |
| | #5 |
| Senior - BHPian | Can't the Jeeps Tailgate be shut permanently. Mine is closed permanently as I was told the tailgate was to give sure shot problems with the chassis bending while offroading. |
| | #6 | |
Thanked: 75 Times
| Quote:
You mean the body, the jeep chassis would not flex enough to disrupt a tailgate fixed on the rear cross member. Besides i am prepping Alfa Kilos jeep for something special... | |
| | #7 |
| Distinguished - BHPian ![]() | Motocamp, I'll check out your tailgate idea when we meet for the next recce. Arkaji, ![]() Thanks for the phone discussion. Will work on the gate rubbers this weekend and update. |
| | #8 | |
| BHPian | Quote:
Please update this thread based on what you guys discussed. 2 days of regular usage and its bugging me. Want to solve this problem right away. Cheers, Adi | |
| | #9 |
| Distinguished - BHPian ![]() | |
| | #10 |
Thanked: 75 Times
| This is what the tailgate i have designed looks like now remember it is incomplete still in the design stage. But you can see it is strong ....with ram standing on it you can easily swing it shut due to the bearings around the pin and it does not wobble or sag. |
| | #11 |
| Distinguished - BHPian ![]() | Kunal, how do you lock/secure the tailgate? |
| | #12 |
| BHPian | Yes. And how do we ensure that the new tailgate that you make won't make the same type of rattling sound? And if there's a way of solving this problem with the new tailgate, why can't we just solve it with the existing tailgate! Am a bit confused now. Adi |
| | #14 |
Thanked: 75 Times
| | #15 |
| Distinguished - BHPian ![]() | That looks like a great solution Kunal. If you guys had a CJ you would not be facing this problem ...or have i spoken too soon? |
Similar Threads | ||||
| Do not tailgate and overtake! See what happened when an Indica did this with a Palio. | clevermax | Street and Travel Experiences | 108 | 7th March 2013 17:19 |
| How to drive an unknown JEEP for 1500kms - A Travel/Photologue by a n00bie JEEP'r | dhanushs | Travelogues | 78 | 4th December 2011 14:00 |
| What Jeep??? | harjeev | 4x4 Technical | 4 | 11th February 2010 14:27 |
| 2009 Jeep J8 Multipurpose 4WD.....return of the WILLYS JEEP!!! | amit V8 | The International Automotive Scene | 14 | 27th July 2009 01:12 |
| First offroading event with my Jeep: Coorg Jeep Thrills OTR 2008 Report | Samurai | 4x4 Excursions | 115 | 21st June 2009 16:12 |
