Old 21st March 2011, 21:31   #46
SPIKE ARRESTOR's Avatar
Thanked: 863 Times
Default Re: M&M Engines and Gearbox combos for JEEPs
Originally Posted by shekaran View Post
can you make something so these scraps are available to genuine wanters like us - jeepers, who search from hell to heaven, for nice items like the NGT GBs, BW TCs etc.,.
This is a case of RAC- Reservation against cancellation, Sir, you are in line.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 21st March 2011, 22:35   #47
shekaran's Avatar
Thanked: 63 Times
Wow, Hip Hip Hurray !!! i am in the RAC - pls confirm my berth soon, so i belong to be a jeeper as long as i can...Thanks Spike, by the way, are you serious about the RAC ? can i start planning my finances ? or can i start dreaming ?
Best Regards.
shekaran is offline   Reply With Quote
Old 23rd January 2012, 11:15   #48
4x4addict's Avatar
Thanked: 2,681 Times
Default Gear Ratios for MM Gearboxes
Just posting some information on gear ratios for various Mahindra gearboxes given by my cousin.
T90
3.986
1.473
1
5.315 R
KMT 90
3.986
2.368
1.473
1
5.315 R
BA 10
4.032
2.393
1.521
1
0.842
3.76 R
BA 10/5v1
3.78
2.42
1.43
1
0.79
3.52 R
NGT 520
3.787
2.09
1.38
1
0.79
3.52 R
HM 5 MX
4.12
2.23
1.46
1
0.84
3.75 R
MSG 5T (is it offered by mm?)
3.736
1.963
1.364
1
0.775
3.91 R
4x4addict is offline   (3) Thanks Reply With Quote
Old 23rd January 2012, 15:34   #49
4x4addict's Avatar
This is a good site to calculate speed at various engine rpms after a tire change.
Speed versus RPM calculator
Another good site to calculate engine rpm given various gearbox/final drive ratios/tire sizes.
Engine RPM Calculator
4x4addict is offline   (1) Thanks Reply With Quote
Old 23rd January 2012, 19:30   #50
Frankenstein's Avatar
Thanked: 302 Times
Tini , are you sure the T90 1st gear ration is 3.9?
Frankenstein is offline   Reply With Quote
Old 23rd January 2012, 22:54   #51
4x4addict's Avatar
Not sure mate. Just got this on the net.
4x4addict is offline   Reply With Quote
Old 25th January 2012, 20:53   #52
Thanked: 2,448 Times
Default Re: Gear Ratios for MM Gearboxes
Hi, Even better (as a reference post) would be an exploded view of each GB, with # of teeth mentioned for each cog.
Sutripta
Old 23rd December 2013, 18:01   #53
Thanked: 58 Times
Default BA10 Gearboxes and Color codes
On a recent BA10 gearbox hunting spree, I've seen at least three different colored badges /labels - Green / Black / Amber - curious what these color codes mean ?
My present thinking (and I stand to be corrected), is these are coded by application in the target vehicle ?
Thus, Green --> BA/10 --> would go into an Armada, Amber --> BA/10 --> would go into an early gen Scorpio
Has somebody else seen this?
lugnut is offline   Reply With Quote
Old 23rd December 2013, 19:41   #54
Thanked: 28 Times
Default Re: BA10 Gearboxes and Color codes
@lugnut
I have always seen green badges, but never thought that there were other colors as well.
Timson is offline   Reply With Quote
Old 16th April 2014, 12:19   #55
Shubhendra's Avatar
Thanked: 1,182 Times
Default Re: M&M Engine and Gearbox combos for JEEPs
Hello,
While discussing engine options to put in my SUV, my friend claimed that engine (Gear drive, non CRDe with BA10) in initial Scorpio and mahindra pickup truck was same.
can someone please confirm, whether small mahindra pickup truck (IIRC CabKing) used the same engine with BA10 (IIRC NGT was not in the market at that time).
Reason for asking this question is - there is one readily available with one of our known ones in a very very good condition and i dont want to miss this opportunity.
Shubhendra
Shubhendra is offline   Reply With Quote
Old 30th April 2014, 22:22   #56
Thanked: 22 Times
Default Difference between XDP and XD3P engines
I recently bought a MM 540 and am ecstatic about it,,love the engine note and responsiveness,,the mental acceleration specially from 60 kph to 100 kph is insane again coupled with that engine roar.
However I have never been that much a Mahindra fan which is to say I cannot rattle off engine and tech specs like I can do for TATA vehicles.
So what I want to know is basically their entire engine line up info ,,specifically the XDP and XD3P difference,,,what engines ( other than the hurricanes) did they use earlier. I have a Commander on site which has an INTERNATIONAL engine and its tractor roots are very evident with EVERYTHING low down in the rev band.
If there is any web page where all this is there please let me know ,else I guess I will have to ask the people in the know to let me know here.
Thanks ( and sorry for the trouble)
Anosh.F.Dhondy
anoshdhondy is offline   Reply With Quote
Old 18th May 2014, 14:54   #57
Thanked: 58 Times
I have a question :
Can a BA10 or Mahindra clones (NGT530 / NGT 520) be mated to the T-18 single lever transfer case?
What would the resultant advantages/disadvantages of this be?
Thanks -
Old 20th May 2014, 09:50   #58
4x4addict's Avatar
Originally Posted by lugnut View Post
I have a question :
Thanks -
BA10 & NGT520 can be mated to T-18. Advantage is 5th gear.
BA10 + T-18 is what comes in the MM550 XDB
NGT520+T18 is what comes in the Bolero DI/Pick Up/Thar DI range.
BA10 is not a very robust gearbox. NGT520 is somewhat better than BA10. Other than that, I can't think of any
Old 25th June 2014, 09:14   #59
prabhuav's Avatar
Thanked: 112 Times
Default 5 speed in a cj
One simple question.
How can we get a fifth cog in a cj?
The NGT series gearboxes are too long, shortening the rear prop shaft. Are there options out there that will let us use this setup?
Will a slip yoke eliminator help?
Confused.
prabhuav is offline   (1) Thanks Reply With Quote
Old 25th June 2014, 13:19   #60
Thanked: 106,687 Times
Default Re: 5 speed in a cj
Far from a simple task.
What are you looking for? More relaxed open-road cruising? If so, you could go for a taller final drive ratio. It will negatively affect offroading capability though.
Machismo 350 AVL Technical Specs - Engine Oil, Clutch and Gearbox Amount and Specs imbue Motorbikes 1 26th April 2011 19:59
Engine and gearbox swap for 1991 SWB Trax citron Modifications & Accessories 16 24th November 2008 22:38
Formula 1 Engine & Gearbox Specs. 50paise Technical Stuff 6 14th March 2006 13:36
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
