Old 4th June 2010, 16:19   #1
whicked wheels's Avatar
Thanked: 56 Times
Default Cant identify this transfer case
I found this divorced transfer case in the scrap yard, can't figure out of what's the make and of which vehicle it has come off. The guy tells me its of the Trax, but i dont think so. It also has a PTO attached to it. Check these pics the guys coating Rs20.000 for it
whicked wheels is offline   Reply With Quote
Old 4th June 2010, 17:40   #2
ex670c's Avatar
Thanked: 1,799 Times
Default Force Motors
Hi Wicked,
Looks like a Steyr-Puch T-Case to me.
Could be from the Gurkha/Judo or the Force EXCEL 4WD.
Arka
PS - Offer 10-12K including PTO, opens up a lot of possibilities for LWB vehicles
Old 4th June 2010, 17:46   #3
manikjeet's Avatar
Thanked: 109 Times
its not worth 20k max would be 2-3k
manikjeet is offline   Reply With Quote
Old 6th June 2010, 21:25   #4
mohan's Avatar
Thanked: 368 Times
Default @James
This is a Trax transfer case for sure.
following are the gear ratios you wanted:
1st gear: 4.695:1
2nd gear: 2.401:1
3rd gear: 1.436:1
4th gear: 1.00:1
5th Gear: 0.806:1
Reverse: 4.078
rear axle/front axle ratio : 4.9
Hope that helps you.
mohan is offline   Reply With Quote
Old 6th June 2010, 23:14   #5
Thanked: 56 Times
thanks Dr Mohan. But could you give me the low and high gear ratios of the transfer case too.
Fraud Transfer of Money from my Salary Account of PNB: Fought case & won ddriver Shifting gears 148 11th February 2015 13:05
high and low ratios of the Fortuner transfer case? Harbir 4x4 Technical 1 29th August 2011 17:19
Gypsy Transfer Case Needed xavier.brittt 4x4 Technical 4 18th February 2011 13:41
Divorced transfer case identification jyobeb 4x4 Technical 17 25th September 2009 11:56
cant identify sound in my innova Akshay1234 Technical Stuff 15 24th May 2009 10:09
