Old 9th June 2010, 19:49   #1
prmd_cochin's Avatar
Thanked: 82 Times
Default Help - MM 540 wobbling !!!
Hey folks.
Somebody needs to help us in this.
I was getting this wobbling feeling from my MM540. This is more when you are at the wheel or while sitting on the rear seats.
We tried out remedies.
We changed the rear housing from 2 wheel to 4 wheel drive, thus moving the rear housing from left to right side. Our idea was that since the gearbox was on the right side, the diagonal transmition of power was the culprit. But this hasnt changed anything, the wobbling continues as it is.
And one more thing we have seen is the extra wear and tear on the inside of the right rear tyre, which we think is because of the wobbling.
What would be the reason for this wobbling?
prmd_cochin is offline   Reply With Quote
Old 9th June 2010, 20:59   #2
Jaggu's Avatar
Thanked: 8,860 Times
What propeller are you using, is it a stock unit? and hope you have ruled out other obvious factors like wheels and steering before this?
Old 9th June 2010, 22:23   #3
Thanked: 82 Times
You gotta point.
We got the engine with the gear box along with it which had the joint(propeller). We gave the propeller shaft to the leth to join it. Would an improper joining lead to this?
And also will the misfit propeller shaft lead to rear wheel wearing out ?
Thanks for the time mate, really appreciate it.
And also we have got the steering and tyres checked, there are no problem with it.
Old 9th June 2010, 22:39   #4
4x4addict's Avatar
Thanked: 2,681 Times
This maybe because the 4x4 conversion of your jeep was not done properly.
4x4addict is offline   Reply With Quote
Old 9th June 2010, 22:43   #5
Thanked: 82 Times
We havnt converted it to 4*4 yet.
Old 9th June 2010, 22:51   #6
4x4addict's Avatar
Sorry, since this was posted in the 4x4 Technical section, I thought it maybe related to the 4x4 conversion.
Since the wobbling is from the rear, it is most likely either of the following:
1) Bad wheel bearings.
2) Bent Rim
3) Warped rear axles.
4) Bad Tires.
5) Hubs not installed correctly.
6) Rear diff not aligned correctly when converting to 4x4 rear axles.
Miss-aligned prop shaft won't cause wobbling of the tyres, but will cause other issues.
Old 9th June 2010, 22:58   #7
SPIKE ARRESTOR's Avatar
Thanked: 862 Times
I agree to what 4x4 addict says, also hope the LH and RH side tire size and pressures are correct.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 9th June 2010, 23:32   #8
Thanked: 82 Times
Thanks you all.
Regarding Warped rear axles, let me get this checked.
Tyres have been changed, changed the rims too when i moved to alloys.
Old 10th June 2010, 15:43   #9
ex670c's Avatar
Thanked: 1,838 Times
Default Wobble
Hi Pramod,
If there is wobble, jumping, lurching effect in 4WD.
Also Check if all 4 Tyres are the Same(Diameter).
Check the Front and Rear Differential Ratios.
If there is severe body vibration in 2WD/4WD, check the T-Case Mount & Bolt.
If tightened too much there will be vibration, same if it is loose.
And as Mr.Behram Dhabar, strongly suggest, Get a SPIKE ARRESTOR.
If the steering wobbles/wheel wobble that is another issue.
For the Rear Differential
1) Check Wheels (Balancing/Rims)
2) Check Wheel Bearing
3) Axle Key/Check Nut & Cotter Pin (2 Piece SFRA)
4) Check Body Beds
5) Spring U Clamps.
6) Shock Absorbers
Arka
Old 10th June 2010, 20:00   #10
Thanked: 82 Times
We just found out that the cross member on the chasis has come off from one side. So we are trying to get this fixed and see if the wobbling stops.
Stay tuned till then, if it doesnt get solved then would need more help.
Thanks Jeepers.
Old 10th June 2010, 20:13   #11
Thanked: 862 Times
Pramod, can you post a few pics please?
Spike
Old 10th June 2010, 21:41   #12
Thanked: 82 Times
Spike
Let me see if i can do it tomorrow. Its already dark now .
Old 12th January 2013, 13:09   #13
Thanked: 825 Times
Exclamation Re: Help - MM 540 wobbling !!!
My recent finding .( Arka's point 6 on post 9 confirmed )
shock absorbers on axles ( NOT on steering linkage ) , do have a say on wheel wobble / death wobble / king pin Wobble
I would not have believed it but a change from a totally faulty pair to new ones made a 'very' notable difference .
I could observe this as I traveled the same track with the old & new pair numerous times .
On a lighter note , came across a novice LR owner complaining about wobble on turns & tight steering ; reason found ? he was on 4 wd engaged all the time
Sudarshan
Sudarshan is offline   (3) Thanks Reply With Quote
Help needed, Wagon R dangerous wobbling 100BHP Technical Stuff 9 1st June 2010 16:30
mm 540 or the trax gurkha?? sanket12 SUVs, MUVs & 4x4s 13 22nd June 2007 12:19
Wobbling Problems humyum Technical Stuff 0 1st March 2006 19:05
Wobbling wheels on a new Viva Neel Tyre & Alloy wheel Section 1 11th February 2005 15:05
