Old 29th November 2011, 16:33   #181
ex670c's Avatar
Thanked: 1,820 Times
Default Tricks
Exactly. If you consider the basic physics, the rotational momentum of the flywheel is directly proportional to the mass of the flywheel. I think it also depends on the radius of the flywheel, but my science gets shaky at that point. So my point is, if you have bigger/heavier flywheel combined with higher revvs, you may not have to pump/modulate the A-pedal to maintain the flywheel momentum. The lighter flywheel or lesser gear ratios (say 4.27) may need the modulation/pumping action. Newton's first law actually.
Not really, I have climbed with constant throttle in really long inclines in Munnar, Coorg, Beltangady, etc.
Yes, it is neither obvious or visible. So I wonder whether this effect exists.
Yes, pumping will work in every gear. But constant throttle won't work beyond 2L in a 5.38 ratio axle.
This probably explains why Peugeot at 5.38 ratio may not need modulation in 1L or 2L.
What I am saying is simple. Constant throttle works if you are at 2L or below in a 5.38 ratio diesel Jeep. In Jeeps with lighter ratios or lighter flywheel, pumping/modulating might be necessary.
Thanks, as I mentioned before I don't know what Prado did, let's hope somebody else will pitch in with the details.
Hi Sharath,
This is a trick not some hard and fast rule.
I will answer, try to explain in points.
1) Pumping the throttle is a trick it
i) Prevents extra torque at the wheels where it will again start slipping.
ii) Allows you higher engine RPM without sufficient speed gain.
iii) Allows you to drive a higher RPM, with out redlining the engine.
2) The effect exists because the Entire Mass (especially concentrated at the belt of the tyre) of the Tyre speeds up and slows down in Fraction of a second, this is obvious in muddy terrain where this technique allows the MT Type tyres to self clean.
3) Depends on what constant throttle is if you again aim to hold a steady 1100-1200 rpm with the A-Pedal input you will achieve similar results to pumping the throttle.
4) Throttle Modulation is trick not a necessity.
5) Try the throttle modulation especially on a CJ500D and the results will surprise you.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 29th November 2011, 20:16   #182
Samurai's Avatar
Thanked: 15,755 Times
Default Re: Avalakonda OTR 2011 : A Late report
Originally Posted by Jaggu View Post
Theory aspect i could also relate but what am talking about is what happens in real life, since flywheel weight is just one of the many factors.
But whatever happens in real life should have a theoretical explanation. That is what I am seeking.
How can you say that the other method is NOT more efficient?
In the initial days of getting my Jeep, I did try the pumping action since it was fresh in my mind from the training. But I didn't gain any extra advantage, so I left it alone. The only times I pumped and found it useful was in 1st High. That is probably because 1st high is a lighter gear than 2nd low. That is I why came to the conclusion that 2nd low can maintain flywheel momentum without pumping in my Jeep.
And wont the revs vary inspite of steady throttle from you, based on the traction offered? So modulation of rpm is anyways happening.
No, when I say constant throttle, I mean constant rpm. Constant/steady rpm means constant flywheel speed.
The CJ3B manual should have some facts researched to mention it right?
Sure, I want to understand why.
On the contrary with modulation you would have superb capabilities at low speed crawling, especially on rocky terrain.
Never had issue in low speed crawling until now.
When you have barely enough traction, if you pump, won't you lose traction?
Automatically taken care in 5.38 ratio. And thanks to heavier flywheel, the momentum is not lost easily.
This may be true. But I have never redlined so far.
Still having hard time with this one.
Obviously I mean rpm. Hmm, what else can I mean? When the Jeep bouncing and bobbing, there is no way I can manage to keep my foot angle on a-pedal absolute. I use the engine noise to gauge the rpm and maintain that noise volume. I don't even have a tacho meter.
Thanks, that is what I am trying to say.
I won't be surprised. Doesn't CJ500D have 3.73 axle ratio? While climbing at low speeds, there is no choice but pump that A-pedal. If not, it might just stall within seconds.
Old 29th November 2011, 21:29   #183
Jaggu's Avatar
Thanked: 8,670 Times
Thanks for agreeing, thats where it started. Santhosh was given a "trick" to conquer an obstacle. Trick is not evil, its just another smarter approach.
Maybe you can try it in your backyard this weekend and update us if this really helps, atleast you are lucky to have such an area right where the jeep is parked.
Old 29th November 2011, 21:53   #184
Samurai's Avatar
And I only said it depends on the vehicle. Check the first post on this thread, which started it all.
Arrey boss, I am not unfamiliar with the technique. Arka taught that to me in rocky terrain of Kellambakkam four years back, I have used it in MM540 and even in 1st low in my Jeep. And I know it is very useful Gypsies since I see Sachin always pumping the A-pedal. But I find it useless in 2nd low in my Jeep, that's all I really wanted to say. And 90% of my of offroading happens in 2nd low. Check my first post in this thread. There I have also mentioned constant rpm at least twice.
I guess you have to drive my Jeep in 2nd low while climbing to understand it. For example, I didn't pump A-pedal while climbing Robi point in Avalakonda. I know you were right there, what problem did you see in my climb?
Old 29th November 2011, 22:25   #185
Jaggu's Avatar
Agree it depends on the vehicle! and it will work in almost ALL vehicles also! in different situations with varying results.
What made you think that i have NOT driven such a combination? Had the exact combo (not exact it was a 3 speed) in the LHD Willy mentioned in the DwArF thread opening post. Drove it for years, why do you think i never was keen on diechel CJ's and opted for a petrol?
Still i would definitely take up your offer and try out in one of the OTR's.
I was on top (IIRC) and very honestly dont have a clear memory of your climb. But i really want to understand why you are so hell bent on thinking that i believe your climb or technique is wrong or does not work?
When did i ever say that?!!
All i am saying is maybe you can try some other techniques also, instead of repeating again and again that its not needed or its absolutely useless, maybe in your CL but works wonders in most of the other vehicles.
Maybe we can have a one on one challenge next time, your vehicle same obstacle same gear but different driving style he he he
One of the topple at that very exact spot was a result of a pointless constant rpm climb, and i guess thats when the marshals decided to step in and prompt the drivers. Oh by the way, we had one another thing which we were watching, which tyre the vehicle were running.
EDIT: In my endeavor to find the truth, i used google to find this from guruji!
Old 29th November 2011, 22:59   #186
Samurai's Avatar
Not the same. Lighter flywheel, in fact 1/3rd times lighter. It will lose momentum lot faster. Now, who has a diesel SWB with 5.38 axle ratio and open diffs in BODA? Try with that vehicle.
Well, you keep saying modulation is always the better technique. And I am saying it depends on the vehicle and gears. That's the difference.
I only said it is not needed in 2nd low of my Jeep. When did I say it is absolutely useless? I do use it in higher gears and would use it in other Jeeps.
Sure, I have driven my Jeep enough to know what works in 2nd low.
Now constant rpm is a pointless thing? See what Arka said a while back:
He feels steady rpm is same as pumping the throttle. So where does it put us?
And what does Arka say there? Use Throttle Modulation to achieve high flywheel speed. That is the objective, flywheel momentum.
Old 29th November 2011, 23:50   #187
Jaggu's Avatar
Arre it was a diesel motor only! Only the box was 3 and iirc yours is 4 speed, same diff ratio.
Yup and i really dont have more science right now to prove it, so let it be.
Thanks for clarifying
Goodie it would be a great challenge for me to see if the belief holds up.
Now constant rpm is a pointless thing? See what Arka said a while back:He feels steady rpm is same as pumping the throttle. So where does it put us?
you are becoming like indian journo's. He said constant rpm at around 1100-1200 RPM also. When i meant constant RPM i never said the rpm, am not that good to figure out the rpm standing below a climb, but am sure it was much higher. Atleast sounding much much higher, and i guess your CL was also in a higher RPM on that climb? 1100-1200 in 2L in CL = what kind of speed?
Yeah and your jeep holds high RPM in 2nd gear so far. I guess you are good enough driver to always be in the right gear.
Old 30th November 2011, 00:38   #188
Samurai's Avatar
Default Re: Off Road Driving Techniques
I think we are coming to some kind of consensus, so let's take it.
BTW, it is true that my Jeep holds pretty high RPM in 2L gear. Pumping led to too much harshness in 2L, that is why I stopped trying it. Also, I have no idea what rpm, I don't have a tachno meter. My ears just know by the loudness of the engine.
I have very few videos of my climbing. This is my typical style of driving on slippery trail:
Old 30th November 2011, 10:20   #189
Frankenstein's Avatar
Thanked: 300 Times
The 3 speed gearbox + 5.38 combo does not give so much torque like a KMT90+5.38 or that matter KMT90+4.88.
The ratios in the 3 speed 1st and 2nd gear are tall.
I tired pumping on climbs , but lost momentum and had to go full throttle .
Pumping helped me in slush .
The older Di engine which has one of the heaviest fly wheel , you dont need to rev more or pump , where in our XD3p,G1/307 we need to pump and rev more.
The Hurricane is a different story, you can pump when required and go steady throttle too , since it has very linear power from low down.
Frankenstein is offline   (1) Thanks Reply With Quote
Old 30th November 2011, 10:43   #190
Thanked: 825 Times
This May be
But IMHO Listening can be quite deceiving ---I have experienced it twice , first when I started using external RPM meters for petrol & diesel engine jobs & the second instance was when I fitted an On-board meter on the Land Rover . what I mean is there can be a Huge error on the same engine .
But one cant offroad while looking at the RPM meter ( even if its on-board )-- its finally the experienced & seasoned Right Foot that keeps the engine from dying & stalling , and also keeping from over revving to avoid slipping of wheels
Sudarshan
Sudarshan is offline   (2) Thanks Reply With Quote
Old 30th November 2011, 11:58   #191
Samurai's Avatar
Originally Posted by Frankenstein View Post
The 3 speed gearbox + 5.38 combo does not give so much torque like a KMT90+5.38 or that matter KMT90+4.88.The ratios in the 3 speed 1st and 2nd gear are tall.
That's interesting. What are the ratios of the 3-speed gearbox?
For my XDP engine CJ340 with 12kg flywheel, these are the crawl ratios in descending order:
1st Lo - 52.75 - Don't need to pump A-Pedal to maintain flywheel momentum
2nd Lo - 31.34 - Don't need to pump A-Pedal to maintain flywheel momentum
1st Hi - 21.44 - Need pumping to maintain flywheel momentum
3rd Lo - 19.49 - Need pumping to maintain flywheel momentum
Let's not worry about the rest, they are no good for offroading.
Absolutely, it helps the tyres from getting stuck in pasty wet mud. I do use pumping in heavy slush, but I switch to 1st High in such cases. My 2nd low is not really pumping friendly. I had to do it in Somwarpet this time.
XD3P with what axle ratio?
Originally Posted by Sudarshan View Post
This May be
That may be, but I am not aiming for a particular rpm value. I know at what engine loudness I can safely avoid stalling, so I stick to that. I really don't know what is that rpm value.
Old 30th November 2011, 12:00   #192
Thanked: 66 Times
and for jeeps with lsd's pumping also helps in the clutch working,
this from my personal experience
xtreme power is offline   (2) Thanks Reply With Quote
Old 30th November 2011, 12:13   #193
Samurai's Avatar
You mean the clutch inside the LSD, interesting to know. Thanks...
Old 30th November 2011, 16:30   #194
Thanked: 300 Times
The 3 speed ratios are
1ST GEAR , 2.9:1
2ND GEAR, 1.5:1
3RD GEAR, 1:1
So the crawl ratio in 1st gear is 37.4 with 5.38 ratio.
XD3P with the standard 4.88 in the MM550.
Frankenstein is offline   (2) Thanks Reply With Quote
Old 26th March 2012, 23:16   #195
kshivaa's Avatar
Thanked: 32 Times
I tried to attempt a mini OTR kind of driving over small stones on the empty stream-bed near Puthur. While I switched over to 4WD H, 1 Gear and started the drive
in the middle, got struck at one point, with a big rock below my left rear tyre - see photo below:
I tried to switch to 4WD Low, 1st Gear and tried to accelerate. This only resulted in the front wheels spinning and getting into the gravel:
Finally, I reversed the vehicle, and then went further straight ahead of the rock that was getting below the left tyre and then moved out.
I believe that it is something with the technique, due to which the vehicle did not climb over that rock & the wheels spun.
can someone please comment on what would have been the right way to tackle this position?
I am planning to re-visit the same place in April 21/28, and would try out whatever is recommended.
thanks
Siva
kshivaa is offline   Reply With Quote
OTR & Paragliding: Palakkad Off-Road Adventure's "Off-Road Extreme 2013" JeepCaptain 4x4 Excursions 7 2nd March 2013 12:45
Drift Techniques !! varun_patra Indian Motorsport 8 7th April 2010 14:50
Any new techniques for the old gashes Speedme Technical Stuff 3 12th January 2007 19:52
Launch techniques v1p3r Technical Stuff 29 9th July 2005 22:11
rally driving techniques manticore Indian Motorsport 29 26th May 2004 17:45
