Old 27th July 2010, 19:58   #1
Thanked: 42 Times
Default Rolling Armada Grand
My 4wd Armada Grand Rolls a lot.( The shock absorbers are brand new bolero's. When I was comparing the number of leaves in the leaf springs with a bolero, I found it is one less. Can somebody please tell me what is the correct number of leaves in the spring set. It is by chance the same as bolero.?
Suresh
Suresh Stephen is offline   Reply With Quote
Old 27th July 2010, 22:38   #2
Jaggu's Avatar
Thanked: 7,675 Times
Spike where are you?!
@Suresh: are you sure you are driving on the right side of the speedo, oops i meant counted the leafs on a stock Armaada
Old 28th July 2010, 14:36   #3
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Post Armada NGCS- suspension details
Jaggu bhai, Suresh Sir called me asking the same. Took time as I was compiling the information on NGCS Armada.
  • Rear spring assy- 097928 (No. of leaves= 5)
  • Shock absorber assy rear- 084837
  • Front spring assy- 084818 (No. of leaves= 6)
  • Shock absorber assy front- 084823
  • Stabilizer bar front (Tubular chassis)- 075793
Non-NGCS versions came with 9 leaves at the front (031699) and 10 leaves at the rear (073420). If you could provide me the shock absorber of Bolero I would be in a better position to comment whether the shock absorber rates are on the lower or higher side. Also, please check the shackle mountings for their inclination/misalignment this may also affect the handling. Hope this solves the mystery.
Spike
PS- IIRC MP Sreenivasan from Bangalore also owns a Armada, don't remember which model.
SPIKE ARRESTOR is offline   Reply With Quote
Rolling Rolling Rolling... BB311 Introduce yourself 3 29th April 2016 16:20
Shortened Armada Grand sumeshm 4x4 Vehicles 59 28th January 2015 23:16
Armada Grand wildsdi5530 SUVs, MUVs & 4x4s 28 17th December 2010 07:40
Armada Grand 4wd or Bolero 4wd? VEA 4x4 Vehicles 38 25th July 2010 01:50
Armada Grand 4WD Modifications 4x4addict 4x4 Technical 17 15th April 2009 12:31
