Old 29th July 2010, 11:44   #1
genesis's Avatar
Thanked: 295 Times
Default Applying Rust Convertors on Jeep Exhausts
So the exhaust assembly of the CJ is already showing a nice coating of surface rust and some pits, which I am sure with time will go deeper.
Wanted to check if anyone had experience of applying rust convertors (you apply the chemical (essentially phosphoric acid) and it converts the red rust into a black sandable/primer ready oxide) to a jeep exhaust. Asking the question because the exhaust runs much hotter than regular surfaces.
If not what are possible alternatives for preventive maintenance for the exhaust.
ps: Examples of rust convertors are are Rustcon, Por 15 and Mar Hyde
(MAR-HYDE RUST CONVERTER - JCWhitney)
Inputs appreciated!
genesis is offline   Reply With Quote
Old 29th July 2010, 12:23   #2
Jaggu's Avatar
Thanked: 7,659 Times
Give it a good clean up like sand blasting, add a layer of good anti rust with good heat absorption capability. Thats all i can suggest.
Saw this product and looks interesting, maybe you can search for reviews.
Applying for an Infant / Minor's Passport - Details *here* ascertain Shifting gears 189 14th January 2018 20:06
Fuel-tank Rust Removal (by Electrolysis) & Rust Proofing H3LIOS Motorbikes 30 19th May 2014 14:26
Car moving faster on applying light brake f1head Technical Stuff 18 21st December 2011 11:16
Sound while applying the brakes sudheermenon Technical Stuff 11 18th October 2008 00:17
