Old 20th September 2010, 12:56   #1
pdev29's Avatar
Thanked: 258 Times
Default Engine Mods for MG 410
Hello Guys,
Monstar is done with Stage one of 4x4 mods and now i am planning for a heart transplant.
I was thinking of 1.3 Carb eng with 4 speed GB
please share your view and let me know if you have any better option in mind.
cheers
Devang
pdev29 is offline   Reply With Quote
Old 20th September 2010, 13:33   #2
Sabareesh's Avatar
Thanked: 66 Times
Hi Devang,
Whats your take on the Baleno 1.6 or Isuzu 1.8 ??. Both are good engines and would be suitable for your Gypsy.
Originally Posted by pdev29 View Post
Hello Guys,
Sabareesh is offline   Reply With Quote
Old 20th September 2010, 16:25   #3
pdev29's Avatar
Thanked: 258 Times
For Baleno it will be change of TC,GB, Diffs as well and eng itself is costly.
want to go something cheaper and better dont mind disel also.
Old 20th September 2010, 16:53   #4
ex670c's Avatar
Thanked: 1,799 Times
Default Engine.
Hi Dev,
Why do you need to change the Diff & T-Case?
You can also consider the 1.8L Isuzu from the Amby with Gearbox.
Arka
Old 20th September 2010, 17:31   #5
pdev29's Avatar
Thanked: 258 Times
Arka for 1.6 change off diff and TC required due to the difference in Gear Ratio.
it works without changing too but i think i will be very high revving engine.
isnt the 1.8 Isuzu heavy?? will it mate with 4wd easily??
what do you think about 1.3 Gypsy eng with 4speed gb??
Old 20th September 2010, 18:19   #6
ex670c's Avatar
Default Engine or Transmission
Hi Dev,
The 1L Gypsy has a Lower Diff-Ratio (4.1:1 IIRC) the 1.3L has 3.73:1.
It is desirable to have Lower Diff-Ratio in a 4x4 Vehicle.
Also the OD of the Tyre can be changed to get similar speed.
Dwarka has converted his Gypsy to 1.8L Isuzu with Gear Box and retained the Gypsy T-Case (Divorced).
1.3L+ 4 Speed, I have not seen that combination, so cannot comment on it.
You can pickup a 1.3L Engine/Gear Box and use with your Vehicle and also add the 1.3 T-Case.
Another route can be keep the 1L & 4 Speed and get a 1.3 T-Case and Put Crawler Gears.
Arka
Old 20th September 2010, 18:40   #7
Jaggu's Avatar
Thanked: 7,674 Times
If you are on a budget, just stick to some port polish, header/exhaust, air filter and an electronic engine module. If you find a crawler + locker for the 410 nothing like it.
Old 20th September 2010, 19:02   #8
pdev29's Avatar
Thanked: 258 Times
Originally Posted by ex670c View Post
Hi Dev,
Arka
i didnt get you on these two points.
1) you mean change everything except the diff??
2) Isnt the TCASE same for 1.3 and 1L?
@Jaggu,
Instead of spending on that i will try to put 1.3 with 4speed and it should be better in terms of Offroad performance.
Old 28th September 2010, 21:13   #9
Thanked: 226 Times
Devang,
There is no change in Tcase between 1ltr and 1.3 ltr. Gearbox and differential are the only change. You can mate any engine and gearbox in Gypsy because of its divorced t-case. Alteration will be required in moving tcase a bit backward, that changes even the propeller shaft length.
Baleno engine is the best fit in gypsy, check with allan.
dwaraka is offline   Reply With Quote
Old 28th September 2010, 22:32   #10
pdev29's Avatar
Thanked: 258 Times
I was thinking of 1.3 on 4 speed gb.
Old 28th September 2010, 23:04   #11
swastikviji's Avatar
Thanked: 158 Times
Originally Posted by dwaraka View Post
Devang,
Dwarak Sir,
MG 410 and MG 413 is totally Different Trancefer case Gear Ratios,
swastikviji is offline   Reply With Quote
Old 29th September 2010, 19:07   #12
JeepCaptain's Avatar
Thanked: 468 Times
Originally Posted by swastikviji View Post
Dwarak Sir,
Dwarak Sir, Viji is right. I bought crawl gear set same and Khan_Sultans and tried to install in on my Deisel MG410 TC thinking that both TC of 413 and 410 are same. But it wasn't.
Same with Differential and Diff Locks.
So my crawl gears and Diff lockers are still stored in my cupboard.
Shibu
JeepCaptain is offline   Reply With Quote
Old 29th September 2010, 20:35   #13
V-16's Avatar
Thanked: 848 Times
Then whats the verdict, as i too have a 1.0 Gypsy and want to get a heart transplant. Dwarka could you guide me to your thread if there for the 1.8 Isuzu swap? I find that interesting.
V-16 is offline   Reply With Quote
Old 29th September 2010, 21:33   #14
starter's Avatar
Thanked: 271 Times
Here it is Gogi.
http://www.team-bhp.com/forum/modifi...ol-engine.html (Gypsy Powering up with ISUZU 1800 cc Petrol engine)
Cheers,
Deepak
starter is online now   Reply With Quote
Old 29th September 2010, 22:55   #15
Desmosedici's Avatar
Thanked: 408 Times
are all these engines easy to source, the baleno 1.6 or the Isuzu 1.8? and even though many have done these conversions, wont it always be best to retain the stock engine and have add ons which might boost the overall efficiency?
Desmosedici is offline   Reply With Quote
Gypsy 410: Maximum Load Carrying Capacity atheistrical 4x4 Technical 12 9th December 2013 23:14
1993 Maruti zen MH 410 @ 1,50,000 Km:A tribute poloman Long-Term Ownership Reviews 41 20th August 2013 14:25
6 Cyl. Turbo + 410 Nm Torque + 7 Wheels = ? EDIT: Pics on page 7! raj_5004 Commercial Vehicles 302 28th May 2012 11:53
Gypsy 410 front wheel wobble A-jay 4x4 Technical 17 10th May 2010 21:51
Zen Mh 410 A/c gas availbility braveheart_77 Technical Stuff 9 9th May 2010 15:32
