Old 28th November 2014, 20:58   #286
DirtyDan's Avatar
Thanked: 785 Times
Default Re: Scorpio VLX 4x4 Review: 1000 kms in Lahaul-Spiti
Just to establish context, we are talking of
aren't we? (Essentially Scorpio 4X4 manual vs auto)
I didn't know this, and would never have guessed!
Sutripta
PS.- I still don't get it. If someone could please explain ...
I think your PS sums it up nicely and I think further explanations, or corrections of my mis-statements on my part are futile in this case.
Old 28th November 2014, 21:02   #287
Thanked: 2,432 Times
Will wait for other kind souls. Am sure someone will (try to) oblige.
Sutripta
Old 28th November 2014, 22:12   #288
DirtyDan's Avatar
Thanked: 785 Times
The torque converter of an automatic transmission allows much more slippage than the counterpart clutch of a manual transmission. You can, for example, be in DRIVE in an automatic, be on a steep hill facing up, and find yourself rolling backward down the slope at an alarming rate even though you are in DRIVE first gear. This slippage tends to lessen some of the effect of wind up since the post-tranny drivetrain stuff is not anchored by a manual clutch to the resistence of the fly wheel/engine to the same degree. You can still get windup damage however, if you try hard enough.
Okay, hang me.
DirtyDan is offline   (1) Thanks Reply With Quote
Old 29th November 2014, 12:57   #289
1100D's Avatar
Thanked: 2,718 Times
What I am a little confused about reading the last few posts, that to absorb the difference in rotation between the front and rear drive shafts (to prevent the so called "wind up") this device known as Automatic transmission (and its associated Torque Converter) has to sit between these two shafts and not at a point preceding this junction, what am I missing here.
In otherwords, it would be wrong to assume that even if we deviced flexible shafts on a manual gearbox, upstream of the transfercase, that would prevent drivetrain binding (or "Wind up")
1100D is offline   (2) Thanks Reply With Quote
Old 29th November 2014, 13:37   #290
4x4addict's Avatar
Thanked: 2,676 Times
DD Forget it man. If people take the time to read up on how a torque converter gear box works and how a part time 4x4 transfer case works, it will be clear.
4x4addict is offline   (1) Thanks Reply With Quote
Old 29th November 2014, 14:11   #291
SS-Traveller's Avatar
Thanked: 11,727 Times
Do I take that comment to mean that a part-time 4x4 vehicle equipped with torque converter-type automatic transmission, will not face driveline windup when driven in 4H or 4L mode on a road with curves and hairpins? Would you suggest any textbooks/articles/web links where this is explained explicitly?
Old 29th November 2014, 16:04   #292
4x4addict's Avatar
Rahul, good to know. However, when we use engine braking in 1Low this wont help as lock up invariably cannot be used in 1st gear. the lock up in first gear has to get releases at some point otherwise it ceases to become an automatic.
SS-Traveller DD never said not but reduced. Looks like this argument is going regional now :-)
Let me take one last attempt at explaining. Scorpio 4x4 with auto transmission gets driven on winding tarred raids. Front diff is open, I.e. without lockers or LSD so both front axels can rotate at different speeds but no centre diff so front and rear axles cannot rotate at different rpms so the twist gets transferred to the gear box. From here you can do the research on how a old school torque converter auto tranny works.
Old 29th November 2014, 16:10   #293
To what extent? Would be interested to know what can or can't be damaged with a torque converter auto 'box vis-a-vis a manual 'box, with the same (part-time 4wd) configuration. What happens to the transfer case? The driveshafts? The differential gears?
Please explain. What region of where?
Old 29th November 2014, 20:56   #294
Originally Posted by DirtyDan View Post
Okay, hang me.
Walking out in the middle of a game! Not done, old boy!
Let me take one last attempt at explaining. Scorpio 4x4 with auto transmission gets driven on winding tarred raids. Front diff is open, I.e. without lockers or LSD so both front axels can rotate at different speeds but no centre diff so front and rear axles cannot rotate at different rpms so the twist gets transferred to the gear box. .
Transfer case yes, gear box no.
And in the transfer case, only that part which would carry the torque from one axle to the other, not the part which transmits the torque from the main gearbox to the prop shafts.
In a normal Mahindra does releasing the clutch unwind/ lessen the windup?
Thats simple. In the blue corner are ... and in the red corner are...
Oops. red has now become blue, and ...
Sutripta
Old 29th November 2014, 22:18   #295
DirtyDan's Avatar
Thanked: 785 Times
Do you frequently talk to people you think are not there, old boy?
In a normal Mahindra does DEPRESSING the clutch lessen the windup?
Old 29th November 2014, 22:28   #296
Shouting before it became a wilderness!
In a wannabe mechanics language, one engages and disengages/ releases a clutch.
And you are the person driving in the hills. You tell me!
Sutripta
Old 29th November 2014, 23:56   #297
DirtyDan's Avatar
Thanked: 785 Times
Clutch pedal up (normal position) ---> Clutch engaged, connected to the fly wheel.
Clutch pedal down, depressed ---> clutch disengaged from the the fly wheel.
"Releasing" a clutch means foot allowing pedal to rise, engaging the clutch....'ay?
Old 30th November 2014, 11:27   #298
dhanushs's Avatar
Thanked: 4,530 Times
Sorry, I dont have much experience driving automatics, but, isnt the drivetrain wind up caused because the "transfer case" is locked, and not the gearbox?
The transfer case doesnt allow different speeds of front and rear prop shafts. and, when they try to do the same the drive train winds up?
Well, depressing the main gearbox clutch doesnt lessen the wind up. Releasing the front prop shaft drive does.
Old 30th November 2014, 18:34   #299
Thanked: 808 Times
No. De clutching dose not free wind up in any 4 WD vehicle. But if any wheel is off the road, the tyre slips and frees the windup, or if any wheel jumps due to a bump again the wind up is freed.
Rahul
Rahul Rao is offline   Reply With Quote
Old 30th November 2014, 19:33   #300
Depressing that we don't have a common language! Still unity in diversity and all that.
So which action, if any, on the clutch releases transmission windup (Manual GB with clutch)?
Sutripta
All Hail Crusoe! Fiat Linea T-Jet+ : Six years and 52,000 kms done Biraj Long-Term Ownership Reviews 276 7th July 2018 22:44
Does ABS require disk brakes on all the four wheels? abhilashvk Road Safety 26 23rd February 2010 00:36
News: Car loses all four wheels on highway DriverR Street Experiences 10 10th July 2009 13:52
Two sets of four wheels uy663z SUVs, MUVs & 4x4s 37 3rd December 2007 09:39
Four Wheels under 3 Lakhs gemithomas Hatchbacks 33 16th April 2007 13:21
