Old 16th July 2011, 12:49   #16
vak
Thanked: 43 Times
Default Two alternators? Has anyone done this?
Dear All,
I am planning to upgrade the alternator in my Bolero Di 4wd. The OE one is a 55amps Bosch unit with vaccum pump. I want to fit atleast 125 amps alternator as I am fitting a winch and other accessories.
But the catch is that, the only 125amp or above alternator with vacuum pump is the Safari alternator. It is a 135amp unit but will cost Rs21,000. But a Bosch 125 amp alternator without vacuum pump is available for Rs10,000. Also a 90amps Bosch unit with Vacuum pump is available for Rs5,500.
I have two choices
1. To replace the OE 55amp unit with a Bosch 90amp vaccum pump unit .
2. To fabricate a new bracket and fit a 125 amps non vacuum unit and connect it parallel to the OE alternator. This will give me a stated output of 125+55 = 180amp. But , Is this kind of fitment electrically stable?
Your suggestions please.
vak is offline   Reply With Quote
Old 16th July 2011, 13:53   #17
jeepster's Avatar
Thanked: 1,047 Times
Default Re: Two alternators? Has anyone done this?
my suggestion will be 125+55A.
but any modifications to electrical system will void your warranty.
please do consider that.
& is there room for another alternator?
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 16th July 2011, 15:01   #18
Thanked: 826 Times
this is the right choice ,will be sufficient for winch operations
Caution : seek expert advise for this --- IMHO & AFAIK two alternators cannot be connected just like that
You can connect two batteries in parallel
Sudarshan
Sudarshan is offline   (2) Thanks Reply With Quote
Old 17th July 2011, 18:47   #19
Thanked: 1,090 Times
Default Re: Jeep/Gypsy Alternator - Options
Went through them. Thanks. Too elementary, and not really relevant to our discussion.
Is the alternator a voltage source or a current source?
Agreed. But the question is will the current exceed limits on fitting a smaller pulley.
If there is a regulator no, else yes
Alternator Fundamentals - Alternator and Voltage Regulator Operation
if there are four wires then there is a regulator, if two then not (S in the diagram is missing).
Yes. B, F, H. Relevance to our discussion?
Also yes. Also see third comment.
The rectifiers have any role in regulation?
In any case, the question was why alternators do not have current limiters like dynamos. Where it is placed is not relevant.
Rectifiers have only nominal current regulation as they may saturate at high current, but for all practical purpose no.
This alternator has a current regulator
What current limiting?
Check out the current vs rpm graph in one of your links.
Totally irrelevant to our discussion, I would think.
Remember, our discussion started with this
Sutripta
Where relevant the replies are in bold.
Back to our initial discussion. I think I got a bit confused while answering the first time. What I had actually wanted to convey is
. If the pulley diameter is smaller then the alternator has capacity to generate higher current at the same RPM.
. If there is a current regulator, it will limit the current to its design value, but this will occur at a lower engine RPM.
. If there is no current regulator the current delivered will rise with engine RPM.
. if the regulator is changed to a higher rating, the alternator will limit the current at a higher value.
In conclusion
- smaller pulley will give higher current at lower engine RPM
- the maximum current delivered by the alternator will be limited by the regulator in the alternator (if there).
Aroy is online now   Reply With Quote
Old 17th July 2011, 20:54   #20
Thanked: 2,448 Times
In conclusion
- smaller pulley will give higher current at lower RPM
OK.
But
If you are talking of the voltage regulator, then no, not quite.
Engine rpm.
And lets not get into what is it that the alternator produces - voltage or current.
If there is a current regulator, what does rpm have to do with it?
Check out the graph in one of your links.
If you increase the voltage set point, you are going to fry a lot of things in your electrical system.
Not even nominal, I would think. The V-I relationship of a solid state rectifier is exponential.
Couldn't find the current regulation part in your link!
Sutripta
Old 18th July 2011, 21:41   #21
Right. Not a good idea.
Sutripta
Old 27th February 2013, 16:00   #22
svsantosh's Avatar
Thanked: 1,449 Times
I converted my 55AH LucasTVS(Alt+Vacuum Pump) to a 90AH Bosch (Alt+Vacuum Pump), costed me 5,000Rs. More details here.
http://www.team-bhp.com/forum/4x4-ve...ml#post3052053 (2000 Armada Grand 4WD)
svsantosh is offline   (2) Thanks Reply With Quote
Old 7th March 2013, 19:43   #23
mohang_j's Avatar
Thanked: 18 Times
I have used a 90A alternator from Indica petrol. Costed 1700. Bought used one from my mechanic. Service and installation was DIY.
Jeep/Gypsy Alternator - Options-cam00408.jpg
Jeep/Gypsy Alternator - Options-cam00419.jpg
Jeep/Gypsy Alternator - Options-cam00435.jpg
mohang_j is offline   (2) Thanks Reply With Quote
Old 8th March 2013, 20:15   #24
Thanked: 826 Times
Fantastic .
perhaps ( if at all ) you have missed this thread , will be useful for you WRT fitting a RPM meter ffor your Jeep .
http://www.team-bhp.com/forum/4x4-te...el-engine.html (RPM meter for XD3P (Mahindra) diesel engine)
pls check post #4 , I have fitted a dicor alternator which has facilitated RPM meter function .
Sudarshan
Sudarshan is offline   (1) Thanks Reply With Quote
Old 9th March 2013, 11:42   #25
headers's Avatar
Thanked: 464 Times
A higher capacity alternator can be fitted to a Jeep / Gypsy but one needs to match the pulley size to the Alternator output.
What I mean is the engine pulley to alternator pulley ratio should be such that it helps the alternator generate max voltage at the normal engine operating rpm.
Also, IMO, alternators with vacuum pumps are not great in design and it is better to have a separate vacuum pump if one needs to source vacuum.
headers is offline   (2) Thanks Reply With Quote
Engine, Gearbox, Diff ratios, axles options for the JEEP Frankenstein 4x4 Technical 112 7th June 2018 23:17
Jeep Step Options & DIY Tejas@perioimpl 4x4 Technical 33 9th May 2016 15:53
Raising a Jeep's ground clearance : Options? GTO 4x4 Technical 192 22nd November 2013 20:31
CJ4A jeep : Looking for alternative petrol engine options abheekg 4x4 Vehicles 6 5th October 2010 17:20
Jeep engine packed up!! 130,000 kms up. Options? GTO Technical Stuff 86 14th July 2006 15:12
