Old 16th December 2010, 16:46   #31
MileCruncher's Avatar
Thanked: 356 Times
Default Re: Can the Thar's 4wd be fitted onto the Scorpio 2wd?
@n.devdath: Firstly the THAR is not coming with 2.6 CRDe. Its a 2498 NEF CRDe engine which in various states of tunes adorning the Bolero or the Xylo.
Understanding your requirement, your BOM for this operation along with approximate prices would be
  1. Scorpio 4WD Chassis - 60-70K
  2. Borg Warner Transfer case - 80K
  3. L & R Lower Arm -4k
  4. L & R Upper Arm - 4k
  5. Scorpio 2.6 CRDE Front Differential - 25-30K
  6. L & R Axle Shaft - 5K
  7. L & R Wheel Hubs - 10K
But the only problem in this case is M&M or its dealers doesn't sell chassis to individual customers, unless and until the vehicle had a severe accidental damage. Getting your chassis number punched is also not an easy job and especially if the vehicle is financed, getting it endorsed on the RC will be next to impossible. The resale value will also go for a toss.
My 2 Cents: If you don't want to spend 13Lacs for new VLX 4X4, wait for a 4x4 in the used market.
This exercise is just not worth it.
MileCruncher is offline   Reply With Quote
Old 20th December 2010, 08:57   #32
Rajith's Avatar
Thanked: 391 Times
Dear 4x4/Spike,
Thainks for a moment that ,if i get 4wd Thar, remove the body and put Bolero vlx shell, is it a perfect fit ???
Rajith is offline   Reply With Quote
Old 20th December 2010, 09:05   #33
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Rajith, Thar is 95.5" WB, Bolero WB is longer, IIRC 105" (min). Anyhow, clever idea I must say!
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 20th December 2010, 10:46   #34
Rajith's Avatar
Thanked: 391 Times
so i am going to wait for 4wd VLX bolero with IFS.With ABS , AIRBAG then 100% perfect
Old 21st December 2010, 13:45   #35
wanderernomad's Avatar
Thanked: 787 Times
Can a 2wd scorpio slx 2007 be converted into a 4wd? If yes what would be the critical changes/modifications involved?
wanderernomad is offline   Reply With Quote
Mahindra Scorpio CRDe - 2WD to 4WD conversion suhasd75 Modifications & Accessories 8 3rd November 2009 18:02
Can Indica Xeta foglights be fitted onto an OHC? Dippy Modifications & Accessories 16 8th January 2007 22:03
Can the Cup Console in Newer Zens be fitted onto the Old ones raghuram.cg Modifications & Accessories 11 17th June 2006 16:40
4WD Vs 2WD - The Difference !!! FrozEN_BHP Technical Stuff 9 16th February 2006 02:30
