Old 29th June 2011, 19:45   #16
fazalaliadil's Avatar
Thanked: 624 Times
Default Re: Differential Guards for the 4x4s
Originally Posted by V-16 View Post
Will these fit OE on the CJ3B too?
Will the body of the diff be the same or will there be a difference? I plan to take both the Jeeps for the Examm and AKC so better to equip both of them with protective gear.
Gogi bhai,
In all probability, the pumpkin size should be the same, Sir Behram's, Arka's and Spike's would be the final word on it.
If they are the same which they should be, get 4 No.s for front and rear on both Jeeps.
Immediately called Viji and ordered the 2nd!!
Santosh,
Lucky me, Vijji advised me to get two from the beginning, thank God! I missed the kiss.
fazalaliadil is offline   Reply With Quote
Old 29th June 2011, 22:37   #17
Thanked: 113 Times
Yes, the powder coating does take up a millimeter of bolt space and I had to drill all the 5 holes again. Bolts - just get same OE spec just 1/2 inch longer.
Originally Posted by ex670c View Post
Initially the holes appeared cross drilled, but actually it is the Synthetic Powder coating, which reduced the diameter of the mounting holes.
Arka
Maybe you can tell Viji to powder coat it after screwing a bolt into each hole, then unscrew it after the process is done?
--Ragul
Ragul is offline   Reply With Quote
Old 6th July 2011, 01:55   #18
V-16's Avatar
Thanked: 848 Times
Fazalbhai, have you installed the diff guards? Can we have a pic of the installation if you dont mind? Thanks in anticipation.
V-16 is offline   Reply With Quote
4x4s in the Indian Army Parm Commercial Vehicles 130 6th December 2016 10:19
Bumper Guards amohit Modifications & Accessories 29 15th June 2011 10:08
Checkered Aluminum Plate for 4x4s Tejas@perioimpl 4x4 Technical 15 23rd March 2010 20:42
180 bhp Mahindra 4x4s to bow in USA Ram The International Automotive Scene 47 3rd August 2007 14:46
