Old 12th January 2011, 09:23   #1
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Question What Jeep / 4x4 parts should I order from Abroad?
Most of you know that my next jeep project is starting soon.
The good news is that my brother is coming down from UK in the end of Feb and can carry nearly 25 kgs worth of stuff for me.
I need to know what i should order from there.
Don't want parts that are available here. No winches or bumpers and heavy and large parts.
Need suggestions for smaller parts and gadgets that i can get shipped to him in UK and he will carry it.
- I'm ordering a britpart snorkel head
What else. Please suggest (with links if possible).
Tejas@perioimpl is offline   Reply With Quote
Old 12th January 2011, 09:54   #2
Thanked: 825 Times
Default Re: What parts should i order from UK?
1) components for Diffs ( dif locks ,lsd ,mld )
2) split charger ( the unit used in dual battery setup)
3) car Inverter ?
4) quality switches to be used in wiring alterations & relays
5 ) F W hubs
Sudarshan
Sudarshan is offline   Reply With Quote
Old 12th January 2011, 10:47   #3
Jaggu's Avatar
Thanked: 8,693 Times
Why snorkle heads are they cheap in UK. I thought you get good quality stuff and imitation stuff easily here?
Switches i agree might be a good idea, maybe check for water proofed ones. Light and easy to carry.
Old 12th January 2011, 10:53   #4
trammway's Avatar
Thanked: 220 Times
Not sure if you can really buy something from UK as that region is always costlier for any automobile component. As far as my interactions concern with Europe Jeepers they look at Indian market for their Jeeping parts needs.
May be it will be a good idea to interact with M&M jeepers in UK or in Europe region. Just try to visit mahindra-register.org and see what is really possible in Europe Jeeping world. So you can try grabbing stuffs that attracts you.
Note: Mods, please remove this post if my reference to other forum is not allowed here.
trammway is offline   Reply With Quote
Old 12th January 2011, 11:07   #5
Already in touch with mahindra-register guys.
Britpart original mushroom type snorkel head for 17 pounds only with free shipping.
Ordered water proof aircraft style flick switches as well.
Old 12th January 2011, 11:40   #6
Thanked: 825 Times
I don't know if you are interested in this , or have immediate use for this .
1)synthetic rope for winch ( 12000 pound capacity ) new tech & very lightweight .
2) Compass for vehicular use ( liquid filled/suspended, that is not affected by the sheet metal of vehicle body ) + a meter that shows side & front tilt angle
Sudarshan
Old 12th January 2011, 12:08   #7
Winch will come from US whenever that may be.
The compass i have.
What else? Keep the suggestions coming in.
Old 12th January 2011, 13:11   #8
satan's Avatar
Thanked: 855 Times
Try and get the following, altogether should be under 25kg
1. Centerforce Dual Friction clutch.
2. IPF/CIBIE replacement headlights
3. Snatch strap
4. Rear ARB Locker & compressor
satan is offline   Reply With Quote
Old 12th January 2011, 15:40   #9
trammway's Avatar
Thanked: 220 Times
Ah Tejas, This is a good idea but hold on don't order one now. A all new hybrid Accelerometer enabled gadget from India is going to rock the Jeeping world very soon.
May be soon you will be in a position to carry the same to abroad to help jeepers outside.
Old 12th January 2011, 16:15   #10
V-16's Avatar
Thanked: 862 Times
Default re: What Jeep / 4x4 parts should I order from Abroad?
Yes, most of us do
[quote]The good news is that my brother is coming down from UK in the end of Feb and can carry nearly 25 kgs worth of stuff for me.
Only a winch would exhaust your 25 kg load capacity, it may even exceed it.
#Water proof alternator.
#Diff Locks/Air Lockers
#Water Proof lights headlights, rear tail lights and fog lights.
Ill see if i can find a website which had details of a company which manufactures LED lights. Awesome and were reasonable too.
Keep us informed about the project.
V-16 is offline   Reply With Quote
Old 12th January 2011, 19:05   #11
Thanked: 825 Times
Ha Ha Ha, but thanks . there are few more plans cooking-up though
@ Tejas ,I am trying to figure out few things but since you are building a Jeep & that too with MM parts so mechanical parts are out of question .
Only thing remains is Out door equipments ( some camping/trekking gear ? ) , accessories , & specialised electrical Items ( mentioned by Gogiji ) ,
I will like to suggest something if you are in tools ( other than surgical )
have a look these are hard to find ( you can get one for me though )
1) nut splitter/cutter ,used to open rusty jammed up nuts
Name:  nut cracker.jpg
2) ball joint separator
What Jeep / 4x4 parts should I order from Abroad?-separators.jpg
Sudarshan
Old 12th January 2011, 19:16   #12
Thanked: 85 Times
Check out which stuff for Land Rovers can be used on Jeeps. That stuff will be easily available there. If your brother has the time he can get some stuff fro the scrapped Land Rovers or Range Rovers there.
Live To Jive is offline   Reply With Quote
Old 12th January 2011, 19:30   #13
Thanked: 103,639 Times
Tejas, How about a couple of authentic JEEP badges for the rear / side of the car? They are impossible to find in Bombay and look swell on Jeeps. Other stuff you can consider:
- An air compressor
- A good jerrycan
- A tent
- Authentic rear lamps
- Offroad jack
Old 12th January 2011, 19:42   #14
Thanked: 825 Times
this wont work
1) only series Landies have very few parts interchangable & thats tricky ( I am doing this )
2) Mechanically Land Rover is close to British vehicles then American ones ( Jeeps ) ,
2) better buy new parts here for Jeeps then anywhere else ( ex diff locks , FW hubs )
3) mechanical parts are too heavy to handle ( his is 25 kg limit )
Sudarshan
Old 12th January 2011, 23:45   #15
trammway's Avatar
Thanked: 220 Times
I don't know if you get this one on UK, but my long time dream to have a 4x4 enabled seat cover for my Jeep. Very specifically from SmittyBilt G.E.A.R brand, the pictures will do the talking now.
More information on other very innovative products could be found from this site: Smittybilt Automotive- Winches, Nerf Bars, Side Steps, Grille Guards, Seats and More
But then this is a US based store, I was aware smittybilt is also available in Singapore at this u 4x4 Accessories Singapore - Home
The idea here is that find smittybilt dealer in UK and you are done, tons of offering for we 4x4ers.
Places to buy 4x4 stuff abroad Tejas@perioimpl 4x4 Technical 10 13th July 2017 21:03
Temporarily relocating abroad: What should I do with my cars? BurningHeart What Car? 64 5th May 2016 21:54
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Buying Parts & Accessories Abroad? vjoy3 Modifications & Accessories 17 9th December 2012 15:49
aftermarket parts from abroad harry15 Modifications & Accessories 6 15th June 2007 00:39
