Old 22nd January 2011, 23:33   #16
Grace's Avatar
Thanked: 159 Times
Default Re: Strengthening MM540 C Section Chassis
Hi Viji, Thanks for your words, there is a learning derived in the mistakes we make. Besides I enjoyed this build backwards. Learnt, never to completely trust recommendations on service providers as it may ruin relationships.
Warm Regards
Grace is offline   Reply With Quote
Old 23rd January 2011, 00:41   #17
Thanked: 647 Times
Ok then your costs are very acceptable! Of course I remember you! My methods include a very dubious method of cutting and pasting chassis numbers! Not that I am recommending that method here!!
jyobeb is offline   Reply With Quote
Old 23rd June 2011, 17:21   #18
AVR
AVR's Avatar
Thanked: 511 Times
Originally Posted by Sudarshan View Post
5) choice of welding
a) which type of welding will be the best & who can do it (welding methods )
b ) choice of welding machine & material ( type of rods,its quality etc)
In reference to the pictures posted by Jeepster from redmm340's thread:
1) what is the kind of welding that would work best for the additional cross members?
2) What kind of pipe material should be used to make those cross members?
Some more fundamental questions:
1) What would happen to a 540 with old c-section chassis when a significantly more powerful engine is fitted?
2) What additional stresses are exerted on the chassis?
3) What are the weakpoints on the chassis under higher torque engines? 4) Does spot-strengthening suffice or do we need to have a blanket-strengthening approach like Grace has done?
Thanks,
Adi
AVR is offline   Reply With Quote
Old 24th June 2011, 12:14   #19
Thanked: 822 Times
I use a simple arc welding transformer ( 1/2 phase ) ranging from 50 to 200 Amps . I use Ador general purpose MS welding rods , Till date its successful , no problems .
I don't have any first hand experience about MIG welding as such so cant comment on that .
I personally wont choose pipes , I would choose C sections as one can weld from both sides
Also I will choose material from old Jeep / truck chassis rather than the local steel market
for the following I will try my best ( AFAIK & IMHO )
You surely are going to have problems , It depends on how much larger ( weight ) & powerful the engine is then the standard
cant comment generally ,but the engine 'thrust' side may get more hammered , expect engine mounts & areas near it to budge/ break
3) What are the weak points on the chassis under higher torque engines?
The area would be just around the GB-- specially between the engine mount & the GB cross member
this will depend on the power & weight of the engine & the terrain / duty you need,
I will put a drawing ( My Idea ) for chassis strengthening soon
Sudarshan
Sudarshan is offline   (2) Thanks Reply With Quote
Old 24th June 2011, 17:07   #20
Thanked: 822 Times
==Also I will choose material from old Jeep / truck chassis rather than the local steel market ===
===I will put a drawing ( My Idea ) for chassis strengthening soon ==
here is my Idea , I would buy an old Jeep chassis ,dismantle it completely ( to each & every piece ) , then I will choose the long members drill some big holes* in it to reduce weight & weld it in CinC fashion** , this long member will look like this
explanation
C in C fashion ** : as follows
explanation
holes* : for a 4" chassis height portion it wont be more than 1.5" dia ,These holes will also provide access for some anti rust painting after welding ( cheap alternative to galvanising ) , A total box will deny that .
Sudarshan
Old 25th June 2011, 02:50   #21
AVR
AVR's Avatar
Thanked: 511 Times
Thanks Sudarshan bhai, this is useful. Strengthening the entire chassis with the c-section addon makes more sense than additional cross members as the positioning of the cross-members may not be optimal given my limited knowledge.
Cheers,
Adi
Old 26th August 2011, 23:44   #22
Frankenstein's Avatar
Thanked: 274 Times
Sudarshan
Sudarshan, a few doubts, generally as you know in Jeeps, the area around the engine /tranny is already boxed (in a C section old chassis). The chassis from the middle till the rear is a C section , which is also reinforced by another C section from the inside. If suppose a heavy scorpio or perkins p6 engine is plonked into an old 540 , what part of the chassis will brake .
Will the middle C section part break while the vehicle lands hard?
Will the front box section crack because of the engine weight as you said?
Will the whole chassis twist and break during suspension flex because of the engine weight?
How can we make the front box section stronger?
If we add additional cross members like the cj340 pics posted above , wont the chassis crack because of the lack of flexing.( i was told that it does by local load carrying Jeep drivers who had bad results ).
The diagram posted by you shows the chassis sagging, i guess it is due to load carried by the Jeep (taxis) or is it caused by powerful heavy engines.
Frankenstein is offline   Reply With Quote
Old 27th August 2011, 11:33   #23
Thanked: 822 Times
Frank-- forget something like P6 , its way too heavy , but the scorp ? yes its possible .
I will suggest you go through my post # 7 once again . Compare the Jeep & Landy chassis , the main difference is the C & box section .
But another important feature of landy chassis is the ' Two ' Fixed cross members below the GB & bell housing ( engine flywheel & clutch area ) The old Jeep C chassis lacks strength here ,
The sag area I have shown ( in red circle ) is the inherent weakness of the 'C ' type Jeep chassis , because there is no fixed crossmember in there & the chassis also needs some more strength there .
Now with reference to your Q : even if you do all the strengthening by adding another C from inside , you will need to address 'this' particular issue . You will need to add fixed crossmembers bellow the GB & near the front leaf mounting brackets ( just bellow the engine bell housing area ) so that the flex will be controlled effectively .
Yes quite possible , expect this between the GB cross member & the leaf mount bracket . Another area will be the front chassis ' arch ' the area between the two leaf mount brackets .
Quite Possible , the thrust side of engine mounting ( RH ) seems more susceptible
Will surely develop stress with time & finally give way
IMHO adding some thicker & continious C section ( removing the original ) & most importantly adding those 'Two Fixed Crossmembers ' I have mentioned earlier --- but then you will have to remove the GB from inside the vehicle by removing sections of flooring & seats ( Just like the Landrover )
IMHO , all the load gets concentrated bellow the drivers feet here because all the other areas are ' Rigid ' now & this particular area seems the only weak link in ' That ' chassis
Not exactly , I have seen this happening in Standard Jeeps ( mostly diesels & above 80" wb ) , this is due to bad roads ( shocks ) & years of abuse / stress building up .
I am not an engineer these are general observations ,
IMHO fitting a more powerfull & larger Petrol engine will not give as many problems as any diesel will give , though it will be a gas guzzler .
IMHO , ( WRT larger & powerful engines ) the area just bellow the drivers feet will be the area where all the stresses are going to get concentrated ( engine torque & suspension stress ) till you take care of that particular area , nothing will work correctly -- Also the Engine foundations , Particularly on the thrust side of engine will need special attention while the re build
Sudarshan
Sudarshan is offline   Reply With Quote
Old 1st September 2011, 09:13   #24
headers's Avatar
Thanked: 459 Times
@4x4, grace and all posters in this thread:
I have a question -
Would not the area of the weld be a weak link on the chassis?
I believe manufacturers know the best in chassis design, strengthening and we should NOT tamper, weld anywhere at anytime on them.
Would like your views?
Old 1st September 2011, 12:29   #25
AVR
AVR's Avatar
Thanked: 511 Times
I have a question -
Headers, for a stock vehicle setup, the area of the weld or any form of strengthening will not be a weak link because it won't be required as the original chassis design should take care of all flexes/stresses.
A much more powerful/heavier engine would require strengthening as even with the factor of safety taken into account,the chassis may still be a point of failure. Hence strengthening would be required. Unfortunately people like us would have to count on our greater shared or limited individual knowledge while strengthening the chassis (whether extra-C section or cross-members)
The biggest advantage is that if we weld something onto the chassis and it breaks first then we still have the original chassis to fiddle around with next time around
Old 1st September 2011, 12:45   #26
Thanked: 822 Times
Not necessarily ; it depends on how the thing is done , I have done this twice --when my 540's chassis gave way & also when I met with an accident . I had no option
But I took care not to add gusset plates & welds to a particular spot . I took care that the load & stress will be spread evenly . All this was done in & before 1997 so 14 years on & almost a 80 K km of mixed driving the thing still holds
but what one can do if a chassis cracks or sags or if some damage is done by accidents ??
More than that-- What if we are putting more powerful engines in it & want a more " Extreme off road duty ' from the same Jeep ??
We dont have much choice WRT the duty we expect . There are only a few engines ,GBs , T cases to play with --- for chassis we actually dont have anything & till we get something , this ' Trial & Error ' will continue
Sudarshan
Old 1st September 2011, 12:52   #27
headers's Avatar
Thanked: 459 Times
I get what you are saying but nevertheless no chassis welding for me if i can help it!!
Looks like you did not have much options explored.
Anyways, glad that you guys understand that chassis welding should be restricted - not done unless beyond one's means!
Old 1st September 2011, 15:05   #28
Thanked: 822 Times
what are they ?? can you explain further ??
This will be really helpful if other Options / alternatives are available !!!
no one touches the chassis without reason IMHO
Sudarshan
Old 29th September 2011, 23:55   #29
jeepster's Avatar
Thanked: 985 Times
some pics from my side.
rgds,
Nikhil
jeepster is offline   Reply With Quote
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
Strengthening the T-BHP Community- Addition of 1 more Oil Burner drive_or_die Introduce yourself 4 29th October 2010 16:03
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
power v/s chassis and the importance of handling normally_crazy Technical Stuff 17 8th March 2006 20:51
