Old 25th January 2011, 15:45   #16
fazalaliadil's Avatar
Thanked: 626 Times
Default Re: How to stop Jeep from stalling in water?
Originally Posted by SPIKE ARRESTOR View Post
@Santosh, why is the connector welded there in the very first place? Do you think it is required there?
Spike
I too felt it should have been on or before the bend, towards the exhaust manifold side.
fazalaliadil is offline   Reply With Quote
Old 25th January 2011, 16:57   #17
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Fazal saab, exactly, there is a reason why it is provided. Have a look-Name:  20110125_165058.jpg
@Santosh, I think the position of this part in your Jeep is incorrect, please get rid of this "thingie"!
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 25th January 2011, 17:44   #18
The Wolf's Avatar
Thanked: 58 Times
Flex Pipe:
flex pipe - Google Search
The Wolf is offline   Reply With Quote
Old 25th January 2011, 18:05   #19
Jaggu's Avatar
Thanked: 8,695 Times
That "thingie" is called as a Flex connector or a Flexible bellow.
Spike
Fazal saab, exactly, there is a reason why it is provided. Have a look-Attachment 488607
Spike
Usually its held by a clamp with bolts right? And how critical is the positioning, next to manifold? I know it is a weak part which tends to break off (manifold pipe area, when connected by rigid pipe), have seen it happen. But by attaching it before the next body clamp in the exhaust system, arent we reducing the stress anyway?
Even in Thar i see there is something like that under the front floor area before the box?
So where should this flexi tube "ideally" come?
Old 25th January 2011, 19:03   #20
whitemm550's Avatar
Thanked: 68 Times
Default Re: how to stop jeep from stalling in water??
After every stall what was done to get the engine started again, this is important to pinpoint the reason?
For eg. If you needed to clean the tank, fuel line, diesel filters, then it could be water entering the tank.
fisrstly Fazal bhai, nice to hear from you,
1. first time the water entered from the air filter, whose inlet was wrongly positioned at the radiator direction, in order to suck in max air ( water too )
I rectified it later by placing the inlet of the air filter in take pipe right back close to the engine firewall, in my bolero and went through this..
2. second time the jeep was bogged down in something like sand in 2 feet water, vehicle was running for about 10 mins till a recovery vehicle could come thru, but by then, the engine gave up, and kaput!!!, i had to drain the engine and the fuel tank.
3. the third time was peculiar. i never understood how it stalled!!!
i was cruising along nicely in about 2 feet deep water, in second low, no high speed drama, and after crossing about 20-30 ft of the stream, the engine just died down, as if someone switched it off!!!. air filter was dry.
on closer inspection, afterwards , i found out that the return pipe on top of the fuel tank was a bit loose. could it be the problem? its also important to know that i had crossed another stream enroute to the one i stalled, about 500 meters before this one.
whitemm550 is offline   Reply With Quote
Old 25th January 2011, 20:22   #21
Thanked: 809 Times
The function of this part is similar to the slip joint in a propeller shaft i.e. to take up the slack / inconsistencies within the system (here exhaust). As you know, engine while running "rocks", the primary exhaust pipe which is connected to the engine becomes rigid (as it is bolted). So when the engine rocks this pipe moves along with it. As the orientation of the joining pipes may be in a different plane (bending axis is different) this mechanism takes up the oscillations and prevents / minimizes it from being transferred to the next pipe. Most exhaust pipes come with flanges at the end (which are welded ) which when subjected to torsional loads give away at the welds (weld areas are the points of maximum stress concentration).
The first bends in the exhaust pipes are the regions which get heated maximum, it is desired that this component does not foul with others (which are more prone to fire), hence they are moved as close to the exhaust primary pipe as possible. Most vehicles today have this.
Hope it is clear now.
Spike
Old 25th January 2011, 21:43   #22
Jaggu's Avatar
Loud and clear Spikeeeee! Thanks a ton again. Should be a good upgrade when i change DwArFie's pipes
Engine Stalling Problem rkkoul Technical Stuff 35 5th May 2016 13:30
Engine stalling at low revs / idle kaushik_s Technical Stuff 37 4th March 2014 16:24
Occasional Stalling ravradha Motorbikes 5 26th July 2007 10:04
STOP PRESS - Ferrari Enzo brake pads on a Jeep!!! GTO Modifications & Accessories 7 23rd February 2006 11:22
