Old 7th February 2011, 14:10   #46
gsferrari's Avatar
Thanked: 135 Times
Default Re: Maruti Gypsy MG413W - King Pin Bearing issue
Akaash - this is good to know. Let me reach out to Vijay and get his inputs on this. I would love to straighten it and do the Diff-Lock mod or just keep it as a spare.
gsferrari is offline   Reply With Quote
Old 7th February 2011, 15:41   #47
Jaggu's Avatar
Thanked: 8,693 Times
You can straighten the tube by taking it to a lathe workshop. Dont do it often though, will break crack then Gypsy this is a problem, unless the spring and shocks are set right for the torture.
Old 7th February 2011, 16:10   #48
gsferrari's Avatar
Thanked: 135 Times
So should the springs be softer than now or harder than now? I am guessing softer but I am habitually incorrect
Old 7th February 2011, 16:15   #49
Jaggu's Avatar
Softer will better dampers should take care of it to an extent. But at the end its the driver who will decide things will be broken or bent
Old 7th February 2011, 16:39   #50
gsferrari's Avatar
Thanked: 135 Times
Some pics. Doesn't look that bad here and the bend is quite gentle but it is there. I think this housing can be salvaged and kept as spare with diff-locks installed in another rear carrier.
Old 7th February 2011, 16:42   #51
Jaggu's Avatar
How about an additional reenforcement over the carrier tube to make it more stronger?
Old 7th February 2011, 16:49   #52
gsferrari's Avatar
Thanked: 135 Times
Yes Arka has suggested Axle truss. Looking into this.
Old 7th February 2011, 17:12   #53
Jaggu's Avatar
Oh darn, they already named my idea!! Just kidding, new term learned for the day, thank you.
Old 7th February 2011, 17:19   #54
khan_sultan's Avatar
Thanked: 3,872 Times
Good idea. Just make sure that welding of the truss doesn't weaken the already-not-so-strong axle tubing. I suggest going to an experienced welder for this.
khan_sultan is offline   Reply With Quote
Old 7th February 2011, 18:14   #55
Jaggu's Avatar
Yup an experienced Tig welder, was googling saw some truss which can be bolted on. Allen should be able to help you make one of those and avoid welds.
Old 7th February 2011, 18:33   #56
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
^^ Any pics of what we are talking about here?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 7th February 2011, 18:49   #57
Jaggu's Avatar
Spike
How many you want Spike? Axle truss - Google Search
Old 7th February 2011, 19:33   #58
gsferrari's Avatar
Thanked: 135 Times
Does it have to be welded on? Can't it be attached to the axle using U shackles or rings? I am guessing this won't be effective so welding will be necessary.
Anyway will try first with the straightened Banjo and then with the new replacement component. While I am at it I'll request Allan to look into the Anti-Wrap bars.
While all this is going on I'll try to learn throttle control
So much to do!
Old 7th February 2011, 21:12   #59
headers's Avatar
Thanked: 464 Times
So much to do!
Not only Throttle Control sir, but also steering handling, holding, approach to a obstacle, pre planning it in the mind, correct selection of the Gear, etc etc..
Old 8th February 2011, 07:24   #60
Thanked: 825 Times
my Landy also has a Banjo type axle housing ,the strengthening is made by the company itself (OE )
here is some clue , you will need to do it very thoughtfully ,It must be proper , not so easy as it looks
the key is the stress needs to be divided properly, otherwise you will create a 'new' weaker spot .
Front Diff
Rear diff
Sudarshan
Sudarshan is offline   Reply With Quote
Brand new MG413W. EDIT : King completes 20000 kms starter 4x4 Vehicles 301 22nd May 2018 15:39
Torque Boost for a MG413W MPFI Gypsy gsferrari 4x4 Technical 13 20th April 2010 21:48
Buying the new MG413W HT (Gypsy King): Now bought a Bolero sriku SUVs, MUVs & 4x4s 20 18th July 2009 13:16
