Old 8th February 2011, 08:09   #61
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Default Re: Maruti Gypsy MG413W - King Pin Bearing issue
@Sudarshan, your axles are much stronger than the Gypsy ones with those added reinforcements. Some nice design cues there.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 8th February 2011, 19:53   #62
headers's Avatar
Thanked: 457 Times
The axle truss shown in the pics from the post of MOD Jaggu give some nice ideas too.
http://www.google.co.in/images?q=Axl...w=1280&bih=933
My doubts are where the load is going to be distributed and how?
Nevertheless, it would be worth a try for GS's style of driving
GS, go for it
Old 8th February 2011, 20:48   #63
Thanked: 2,130 Times
Almost all the pictures show the truss to be on the upper side. (unlike Sudarshan's setup). Considering the clearance issues it will invoke, wonder why. (Lower side would of course reduce ground clearance, but still, as a manufacturer, shouldn't I make both, and let the customer decide? )
Sutripta
Old 8th February 2011, 20:59   #64
Thanked: 757 Times
Dada, how to decide whether to go for a tie or a strut (member under tension or compression)?
Spike
Old 8th February 2011, 21:05   #65
Other things being equal, I prefer (thin long steel) members under tension.
Which side does the tube bend? And why?
Sutripta
Old 8th February 2011, 21:54   #66
Thanked: 822 Times
Sutripta
IMHO Land Rover chose the lower ones because the lower side hits the obstacle . This works both ways 1) creates a crumple zone kind of thing 2) + the regular function of strengthening the axle
they have lost a 1.5" of clearance but this is with 7.50 X 16 tyres where the lowest point of diff has 9'' ground clearance.
Sudarshan
Sudarshan is offline   Reply With Quote
Old 8th February 2011, 21:56   #67
Thanked: 757 Times
Will this have effects?
What happens in case of an SPOA, increased weight, considering the axle to be simply supported.
Spike
Old 8th February 2011, 22:12   #68
The diagram shows all possibilities. Do all of them happen in a Gypsy, or only one for all practical purposes?
When these housings are straightened, where exactly is it supported, and where exactly is the restoring force applied?
Diff tube bending used to be very common amongst rally Gypsies. Can someone post some pictures. Also, did any Indian team use a truss?
Sutripta
Old 7th March 2011, 20:29   #69
gsferrari's Avatar
Thanked: 131 Times
This is a picture of the bent housing. Just got my Gypsy back today with the new housing fitted. They've replaced everything from KP bearings, shims, oil seals etc. Only the axles and the knuckles are from the old setup.
Cost me Rs.14000 including labour. Parts cost was 11000. This includes the front axle housing (Rs.4200) and some other stuff like window beadings etc. which I needed to get done. Job took 1 months and 3 days to complete...long wait for the parts to show up.
Would have been cheaper to get this done outside M.A.S.S.
gsferrari is offline   Reply With Quote
Old 7th March 2011, 21:01   #70
starter's Avatar
Thanked: 269 Times
Hey Guru,
Good to know that the Gypsy is back.
Sounds crazy that it takes a month to get a new axle housing.
Din't you try to get the bend in the housing removed? Wasn't it possible?
Hopefully, you don't encounter any more broken kingpins.
Cheers,
Deepak
starter is offline   Reply With Quote
Old 7th March 2011, 21:31   #71
gsferrari's Avatar
Thanked: 131 Times
I didn't want to repair the housing and use it so I asked for a complete replacement. This took 3 weeks to get in as well as some of the other parts. I guess they get an order, put it into the production numbers and once it is ready they ship it out. Not sure if they stock something like this. All I can say is the part quality isn't up to snuff...the metal used is waaay too soft. This makes it less brittle but being malleable isn't that attractive a proposition either.
I will try to straighten the bent housing at a lathe over the next few days and if it is true, then I will build a beta "truss" on it, install a rear diff housing and add diff-locks. Only thing I am not sure about is that the spline count is different for front and rear axles and the front axle is FFRA...rear is SFRA so will the rear axle fit the front housing?
Have to check this out...
Old 7th March 2011, 22:04   #72
gsferrari's Avatar
Thanked: 131 Times
No...it won't work. I'll have to order a diff-lock with 22-spline carrier spider gears. Not sure if Lockright do that.
So yeah...straighten it out and keep it as a spare!
Old 7th March 2011, 22:11   #73
Thanked: 822 Times
IMHO - your suspension is too stiff , shock is not 'soaked up ' , check that . you may end up in bending another one
Sudarshan
Old 7th March 2011, 22:35   #74
gsferrari's Avatar
Thanked: 131 Times
Will do Sudarshan...I am planning to revert (upon Arka's advice) to stock shackles and drop a leaf from the front/rear leaf-spring set.
Old 8th March 2011, 06:30   #75
headers's Avatar
Thanked: 457 Times
Why GS? What did Arka advice? And what leaf count are you running front and back? What does Allan recommend?
Brand new MG413W. EDIT : King completes 20000 kms starter 4x4 Vehicles 294 17th February 2017 13:43
Torque Boost for a MG413W MPFI Gypsy gsferrari 4x4 Technical 13 20th April 2010 21:48
Buying the new MG413W HT (Gypsy King): Now bought a Bolero sriku SUVs, MUVs & 4x4s 20 18th July 2009 13:16
