Old 11th February 2011, 13:12   #1
Default Gypsy Transfer Case Needed
Hello there every body. I'm a proud owner of a 410W. Have had it for 4 years now. But it has developed a whining noise and my mech says its due to problems with the transfer case, have tried repairing it but sound remains.
Need advice on what to do. Would be happy to get a replacement if anybody has a spare. Would also like to know the best gypsy mech in chennai. As of now I'm going to C.A.R.S. India in Adyar.
Have come to a very frustrating stage coz of the noise.Please help.
Thank you so much in advance.
Xavier
xavier.brittt is offline   Reply With Quote
Old 11th February 2011, 13:22   #2
Thanked: 30 Times
Default Re: Gypsy Transfer Case Needed
In case you are unable to get one in Chennai- please let me know -I'll send the same to you from NCR.
Thanks & Regards
Anupam
anupam00 is offline   Reply With Quote
Old 11th February 2011, 13:52   #3
ex670c's Avatar
Thanked: 1,799 Times
Hi Xavier,
Please, check the following and confirm.
1) Check if the Vehicle is in 2WD.
2) Check the Free Wheeling Hubs (Front Axle)
3) Check the Rear Propeller Shaft (Spline/Yoke/Universal Joints)
4) Check the Rear Differential (Slack/Play in the Pinion)
After you have eliminated these please check the Gear Box and then the T-Case.
Arka
PS - Contact Headers aka Vikram R. he has one of the best Off-Road going Gypsy, in INDIA.
Old 11th February 2011, 15:49   #4
Hello Arka,
1.The noise remains through all four gears on 2WD, 4wL and 4wH.
2.Mine does not have the free wheeling hub..
3. The propeller shaft is fine. Have checked and had all the star joints replaced recently.
4. will get the rear differential checked.
and will get in touch with headers.
Thanks once again Arka.
Will let you know the result on monday.
Xavier
Old 18th February 2011, 13:41   #5
Rajachu's Avatar
Xavier,
iam facing the same problem and found the Tcase bearing on the front prop shaft side has gone.removed the shaft and checked the sound is not there and now ordered for all the bearing and oil seals etc for the tcase complete overhaul.hope this will completely stop the noise.
Raj
Rajachu is offline   (1) Thanks Reply With Quote
Fraud Transfer of Money from my Salary Account of PNB: Fought case & won ddriver Shifting gears 148 11th February 2015 13:05
high and low ratios of the Fortuner transfer case? Harbir 4x4 Technical 1 29th August 2011 17:19
Cant identify this transfer case whicked wheels 4x4 Technical 4 6th June 2010 23:14
Divorced transfer case identification jyobeb 4x4 Technical 17 25th September 2009 11:56
