Old 9th March 2011, 09:57   #91
ex670c's Avatar
Thanked: 1,795 Times
Default Re: FIP Flop
@Arka: What about the rest of the scans? And a thread on governors.
Hi Sutripta,
Will post the remaining Scans over the weekend.
wrt. Thread on Governors, I would suggest you or Star_Aqua to start it, I don't know anything about them.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 13th March 2011, 11:30   #92
ex670c's Avatar
Default Governors - Part2
Hi Sutripta,
A few more scans on Mechanical Governors - Minimum-Maximum Speed Governors.
Arka
Old 13th March 2011, 20:37   #93
Thanked: 2,047 Times
Default Re: Governors - Part2
Thanks. How many pages left?
Sutripta
Old 14th March 2011, 10:41   #94
ex670c's Avatar
Hi Sutripta,
Actually how many Technical Manuals Bulletins on FIPs & Fuel Injections left
For the VKD-04200 14 sides left.
Arka
Old 26th March 2011, 19:53   #95
Hi Arka,
Next batch due.
Sutripta
Old 28th March 2011, 15:58   #96
ex670c's Avatar
Default Re: Governors - Part3
Hi Arka,
Next batch due.
Hi Sutripta,
Please do tell us your interpretations or understanding of this Technical Bulletin so far.
Arka
Old 29th March 2011, 20:37   #97
Originally Posted by ex670c View Post
Hi Sutripta,
Arka
Unable to read the text inside the graphs/ diagrams, either on screen, or printed.
Going through the text, interesting and informative, but no 'Aha' moments.
Used to have the manuals for some of the Woodward governors (PGA and PSG), but I'm sure will also be available on the net somewhere.
Do you have the details of the Bosch VE?
Sutripta
Old 30th March 2011, 10:21   #98
ex670c's Avatar
Sutripta
Hi Sutripta,
If you click on the pics/scans they will enlarge.
Arka
PS - I think I have a Tech Bulletin for Bosch VE
Old 30th March 2011, 13:59   #99
Yes. Guess I'll download the jpgs, and print at some legible scale.
Sutripta
Old 2nd April 2011, 17:07   #100
Does anyone have a list of what governor was used in which vehicle?
Had 2 P3s with a pneumatic governor. Also I believe the Matador came with one. Any others?
Can someone help me with a basic question? If I were the engine designer, what would govern my choice of governor?
Sutripta
Old 2nd April 2011, 17:25   #101
Thanked: 822 Times
P6 ( Perkins )
Sutripta
wild guess
1) load carrier or passenger carrier
2) genset engine or vehicular
3) altitude ? ( area of operation )
4) turbo or NA
Sudarshan
Sudarshan is offline   Reply With Quote
Old 2nd April 2011, 20:29   #102
Originally Posted by Sudarshan View Post
P6 ( Perkins )
Application?
'If all you have is a hammer, everything looks like a nail.' The P3, P4 and P6 were India's hammer till I guess the mid 80s.
Functional requirements can be matched quite easily. But on what basis do I choose amongst mechanical, pneumatic, hydraulic, or electronic?
Sutripta
Old 3rd April 2011, 18:09   #103
headers's Avatar
Thanked: 449 Times
Sutripta
If the engine has a capable ECU as well as reserve capacity to take in additional inputs, then I'd choose electronic.
I would choose hydraulic if it is possible to monitor the governor parameters using hydraulics [which i am not sure about ]
I will stay away from pneumatics unless the engine has a compressed air storage tank.
Guess the easiest is the mechanical governors that have been in use for ages.
The fastest response will be electronic and the slowest mechanical with hydraulics and pneumatics falling in between.
Old 3rd April 2011, 18:20   #104
Thanked: 822 Times
@ Sutrpta
another wild guess .
1) cetane No.
2) compression ratio
3) emission requirements
but why do we need a Governor if we have a max rpm stop screw in first place ? ( & a Idler too )
Sudarshan
Old 3rd April 2011, 19:17   #105
Sudarshan
Diesels need a governor. It is even mentioned somewhere in the scans which Arka has posted.
Pre CRDi, it is built into the FIP.
Originally Posted by headers View Post
If the engine has an ECU, you can bet there is a governor built in. It is just a software routine.
I was talking of non ECU engines.
The governor is selfcontained, and draws its power (and monitored speed) from some rotating shaft. The electronic one needs external electrical power. Having a non- self contained governor is an invitation to disaster, or a maintenance (and downtime) nightmare.
If I remember rightly, the VE had a hydraulic component. Waiting for Arka's scans.
Not as simple as that! Though discussing that here would be way off topic.
BTW, why is on the road performance of HPS better than EPS?!
Sutripta
Flop cars in our market bhp The Indian Car Scene 474 1st July 2017 15:22
The "FLOP SHOW" is over R.I.P Jaspal Bhatti adg_andy Shifting gears 38 2nd February 2013 23:32
Flip Flop between Bajaj Auto & Renault Nissan on small car RemingtonSteele The Indian Car Scene 6 16th July 2011 11:19
Acura accepts RL is a sales flop amit The International Automotive Scene 8 9th March 2006 06:44
