Old 4th March 2011, 22:25   #1
Default Mahindra Peugeot XDP diesel engine rattles suddenly
I own a CJ500 with peugeot engine. Very recently I had the diesel pump overhauled and replaced the injector nozzles. Engine runs normally but sometimes all of a sudden there is a sudden "rattling" noise from the engine as dies down as the engine revs up (the noise is similar to single cyclinder diesel ape auto). It is also similar to petrol engine misfiring. The exhaust smoke is also dense during this time.But later engine behaves normally as though nothing has happened.Any idea whats wrong.
satish.rpr is offline   Reply With Quote
Old 5th March 2011, 08:29   #2
fazalaliadil's Avatar
Thanked: 624 Times
Default Re: Mahindra Peugeot XDP diesel engine rattles suddenly
Originally Posted by satish.rpr View Post
Get your fuel pump checked, it looks like a supply problem.
fazalaliadil is offline   Reply With Quote
Old 5th March 2011, 16:39   #3
Thanked: 822 Times
@ Satish , please check the nozzles , for pressure equality among them & also for cleanliness .( you will need to check them at the authorised shop )
also I suspect water in diesel , check in that direction too
Sudarshan
Sudarshan is offline   Reply With Quote
Peugeot ditches Gujarat Factory plans. GM unwilling to let Peugeot use its plants GTO The Indian Car Scene 47 7th October 2016 12:57
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
Mahindra MM540 SDP? EDIT : XDP yamaniac Modifications & Accessories 130 12th June 2013 13:19
Peugeot XDP oil change interval satish.rpr 4x4 Technical 7 4th July 2011 20:51
MM550 XDP - Found it. GO or NO-GO? (Now bought MM540) Scion 4x4 Vehicles 19 31st December 2008 00:53
