Old 23rd June 2013, 10:35   #241
Thanked: 92 Times
Default Re: New 4X4 project
This is one project I've been following from even before I became a member. It's extremely humbling for me to see the patience, dedication and effort you've put into this project, and the end result looks mouth-watering. Tell you what- you should bring this vehicle to Delhi/NCR and just drive around. Just the high from seeing every single vehicle clearing way for you would be amazing
HighwayofLife is offline   (2) Thanks Reply With Quote
Old 24th June 2013, 11:25   #242
Thanked: 647 Times
I am in the process of setting up the steering linkage, front and rear prop shafts and the radiator connections.
Will keep you guys posted with pics.
The roll cage will be fabricated soon as I get my truck in a driveable condition.
jyobeb is online now   (1) Thanks Reply With Quote
Old 25th June 2013, 19:51   #243
Thanked: 647 Times
Using and adapting an Indica Top hose with an additional water outlet for turbo cooling.
The steering link has been completed by connecting a Safari star joint and shaft to the Pajero collapsible steering.
jyobeb is online now   (3) Thanks Reply With Quote
Old 25th June 2013, 22:32   #244
mercedised's Avatar
Thanked: 161 Times
Project is at crawling speeds! Needs alot of time and effort, great going.
Don't you think that the wheel well clearance is way to little, which suspension set-up will you be using, ofcourse you will have to lift up the vehicle.
Old 25th June 2013, 23:49   #245
Thanked: 647 Times
Actually after the new rear springs and the front torsion bar lift, the clearances are more than enough.
However my upper arm is now sitting on the limit stoppers. I am planning on cutting the stopper rest bracket and lowering it by 1 inch. Any advice or opinions against are most welcome. I will post pics of the upper arm resting on the limit bush if anyone is interested.
jyobeb is online now   Reply With Quote
Old 26th June 2013, 11:17   #246
AVR
AVR's Avatar
Thanked: 511 Times
John,
Please post pics. I want to know how/why the limit stoppers are in contact with the upper arm. You really tempt me to cannibalize my old 4wd Safari and make something mad like what you do
Cheers,
Adi
AVR is offline   Reply With Quote
Old 26th June 2013, 11:33   #247
Thanked: 647 Times
I will post pics in the noon. The upper arm needs more space for downward movement and hence my thought of lowering the limit bush bracket.
Old 26th June 2013, 18:37   #248
Thanked: 647 Times
The right side arm resting on the stopper.
Another view of the right side arm resting on the stopper.
Left side upper arm.
Another view.
jyobeb is online now   (5) Thanks Reply With Quote
Old 29th June 2013, 15:09   #249
Thanked: 647 Times
The plumbing work continues.
Pics of the prop shaft links and my trailer.
Old 12th July 2013, 09:14   #250
Thanked: 647 Times
A few pics of the intercooler and intake hose.
I am also planning a hitch for my montero. The pics show the original tow hooks and pipe which I have strengthened with a 1" MS rod. Now to fit the tow hitch and ball.
jyobeb is online now   (4) Thanks Reply With Quote
Old 18th July 2013, 11:13   #251
Thanked: 647 Times
Just as we were getting ready for starting the engine, a small issue cropped up. When we filled the cooling system with water, one of the damned dummy plugs on the block sprung a leak. We had to remove the injection pump to get at it. Replacing all four plugs just to be safe.
Old 18th July 2013, 21:54   #252
Thanked: 647 Times
Fixed the dummys and started the engine. Extremely satisfying and the roar sounds very impressive.
I think this engine will give me all the power I need.
jyobeb is online now   (6) Thanks Reply With Quote
Old 20th July 2013, 21:57   #253
Thanked: 647 Times
jyobeb is online now   (2) Thanks Reply With Quote
Old 20th July 2013, 22:19   #254
svsantosh's Avatar
Thanked: 1,392 Times
Dear beboy
The video is private, you may need to change to public.
svsantosh is offline   (1) Thanks Reply With Quote
Old 20th July 2013, 23:12   #255
Thanked: 1,507 Times
Beboy
Those (rear) wheel arches dont seem to suit the vehicle as it looks now - perhaps you have more exterior work planned that will make them belong more.
Steeroid is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
