Old 8th October 2013, 17:19   #271
Thanked: 649 Times
Default Re: New 4X4 project
Thanks for the encouragement Anupam. The sidesteps will be covered. The square pipes are only a base support. Since they will be exposed to the elements I am planning on using Chequered plywood sheet, automobile grade. (the type used for bus flooring).
As for the rear arches, the recessed holes are going to be fully covered to give a smooth appearance, Hopefully that will make it look more in sync!
jyobeb is offline   (1) Thanks Reply With Quote
Old 8th October 2013, 20:20   #272
Thanked: 974 Times
Originally Posted by jyobeb View Post
I got hydraulic struts fitted onto the hood.
Hi @jyobeb,
As usual, the slow and purposeful progress is keeping the anticipation for the final product high.
Good idea on the hydraulic struts. One word of caution. Please have a mechanical backup fabricated in case of strut failure. Even if one fails, the hood will not stay up. Have experienced it in both the Qualis and Innova rear doors.
Cant wait to see the finished product. Good job and Good Luck!!
Cheers.
gthang is offline   Reply With Quote
Old 9th October 2013, 19:08   #273
Thanked: 649 Times
Thanks man! Will keep that in mind. Infact I should just retain the original propping rod, right?
jyobeb is offline   Reply With Quote
Old 20th October 2013, 11:31   #274
Thanked: 649 Times
I was a little apprehensive about using the 90bhp Safai axles with my 140bhp Toyota engine. I managed to get a differential assembly off a 2012 2.2. Dicor ABS model (with the sensors). I replaced the crown and pinion assembly with mine (since mine was LSD) and the ratio was 4.56:1 against the 4.1:1 that came on the 2.2 dicor.
Despite my crown ring and pinion gear being 14 years old, it was in remarkably good shape so retained the same. Tata definitely over engineered some parts.
The brake drums were also considerably larger and were self adjusting too.
jyobeb is offline   (6) Thanks Reply With Quote
Old 20th October 2013, 18:34   #275
Thanked: 28 Times
Beboy Sir,
Great build, does the differential tube have a slight bend or are those link clamps creating an illusion in the pic.
Since itís been such a long build canít wait to see the final outcome. Great Job Keep it coming!!
Timson is offline   Reply With Quote
Old 20th October 2013, 22:41   #276
Thanked: 649 Times
Hi Timson, thats just the bracket for the link rods giving that optical illusion.
Old 21st October 2013, 23:39   #277
prabhuav's Avatar
Thanked: 112 Times
Beboy, that is a full floating differential. Is that with 30 spline axles sir ?
If yes , then it is a brilliant combination.
prabhuav is offline   Reply With Quote
Old 22nd October 2013, 00:30   #278
svsantosh's Avatar
Thanked: 1,425 Times
Prabhu - got a doubt. Whats a FFD? Heard of FF Axle but D?
And all Safari sumo genre came with SFRA (even the axle in pic is a sfra). There is no FFRA in Tata family of passenger cars till date IIRC.
svsantosh is offline   Reply With Quote
Old 22nd October 2013, 09:42   #279
prabhuav's Avatar
Thanked: 112 Times
Prabhu - got a doubt. Whats a FFD? Heard of FF Axle but D? And all Safari sumo genre came with SFRA (even the axle in pic is a sfra). There is no FFRA in Tata family of passenger cars till date IIRC.
Good catch mate..saw it on the phone and thought that was full floating .. On further research found that thee is no dana 44 with 30 spline in full floating .. Period..
Even the load carriers are running SFRA with 30 spline these days.. From both tata and mahindra stables..
prabhuav is offline   (1) Thanks Reply With Quote
Old 20th November 2013, 20:18   #280
Thanked: 649 Times
Started working on the swing away tyre carrier. A few pics of the fabrication in various stages.
I managed to procure a lock and carrier plate assembly off a Toyota Surf.
jyobeb is offline   (5) Thanks Reply With Quote
Old 22nd November 2013, 20:52   #281
Thanked: 649 Times
Some more pics. Experimenting on the hi-lift mounting also.
jyobeb is offline   (4) Thanks Reply With Quote
Old 24th November 2013, 21:17   #282
Thanked: 649 Times
Next is the exhaust shield. I plan to fabricate a kind of skirt that will have 2 holes for the Remus pipes alone.
Old 24th November 2013, 23:16   #283
Thanked: 1,592 Times
Saar, finish the Jeep fast. Have to see Beboy in a hat, driving this on the road....
Steeroid is offline   (1) Thanks Reply With Quote
Old 24th November 2013, 23:53   #284
Thanked: 649 Times
Why in a hat?
The delay was mainly because I was looking for tinker who would understand what I want. Finally found him and progress should be much faster now!
Old 26th November 2013, 21:20   #285
Thanked: 649 Times
A few more pics of the running board and hi-lift mount.
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
