Old 26th November 2013, 22:12   #286
Thanked: 655 Times
Default Re: New 4X4 project
The material used for the running boards are 3/4" Transport grade, waterproof, compressed plywood. I know they look awful. Will be sandpapering it down and changing it to some other finish.
jyobeb is offline   Reply With Quote
Old 29th November 2013, 15:06   #287
Thanked: 655 Times
The almost finished rear bumper with cutouts for the jacking point.
jyobeb is offline   (3) Thanks Reply With Quote
Old 4th December 2013, 19:53   #288
Thanked: 655 Times
My front bumper with the concealed winch.
jyobeb is offline   (8) Thanks Reply With Quote
Old 5th December 2013, 20:22   #289
svsantosh's Avatar
Thanked: 1,449 Times
How will you access the clutch and ensure correct re-spooling after using the winch?
svsantosh is offline   Reply With Quote
Old 6th December 2013, 08:24   #290
Thanked: 97 Times
OT:
In case anyone here is looking for a Willys station Wagon, on a recent trip to Pune I spotted one in good nick on the Pune-Solapur Toll highway!
Just Saying!
Edmund is offline   Reply With Quote
Old 6th December 2013, 22:19   #291
Thanked: 655 Times
For you Santosh. As for the spooling I will have to be extra careful.
I don't want to have an openable cover and hence am going with this.
Old 7th December 2013, 00:52   #292
Thanked: 994 Times
Hi Jyobeb,
Dont know if you have access to a crimping place, if you do, I would suggest sacrificing a layer or two of winch cable. You lose some total distance, but getting in a bind due to bad wrapping would be less.
Cheers.
gthang is offline   (1) Thanks Reply With Quote
Old 7th December 2013, 09:31   #293
Thanked: 655 Times
I am actually giving serious consideration to plasma rope. I have already bought the rope along with the fairlead.
jyobeb is offline   (1) Thanks Reply With Quote
Old 7th December 2013, 11:24   #294
Thanked: 655 Times
After giving serious consideration to your doubts, I have decided to make an opening on top to help guide the cable.
Thank you for your concerns.
Old 7th December 2013, 13:56   #295
Tejas@perioimpl's Avatar
Thanked: 5,490 Times
Dear jyobeb, Consider fabrication of a winch cable tensioner. Very simple to fabricate. Will take care of the bird nesting of the cable whilst free spooling and re spooling. Don't have access to my comp now to post pics. Will do so on Monday. (Accessing via mobile app now).
Tejas@perioimpl is offline   (1) Thanks Reply With Quote
Old 7th December 2013, 14:52   #296
Thanked: 655 Times
Modified. Adjustment and viewing possible now.
@ Tejas, would really appreciate pics. Thanks man.
Old 7th December 2013, 17:08   #297
Got access especially for you.
Here you go:
Googling will give you more options as well.
I plan to get this made as well but will probably take some time before i get to it.
Vid:
Links:
http://towtalk.net/forum/topic/How-d...oner-work-.htm
http://www.winchbin.com/1286/how-doe...ensioner-work/
Also, if you plan to use the winch on sustained pulls you will need vents to aid in cooling.
EDIT:
Try to source a metal hawse fairlead for your rig. It will look much better than roller. (The aluminium one for plasma rope won't do).
EDIT2:
Another Suggestion: Because you can't see your drum clearly, just mark the cable when 6-7 turns are left on the last wrap of the cable on the drum. You can spray paint or put a heat resistant sleeve so you don't spool out any more rope otherwise, you will loose the grip on the drum. Minimum 6-7 wraps are necessary.
Tejas@perioimpl is offline   (2) Thanks Reply With Quote
Old 11th December 2013, 21:46   #298
Thanked: 655 Times
I decided to louvre my bonnet rather than add a intercooler scoop. Also fitted rear seat belts.
Next, the winch cable tensioner.
jyobeb is offline   (4) Thanks Reply With Quote
Old 11th December 2013, 22:23   #299
svsantosh's Avatar
I see a monster audio setup coming up?
Old 12th December 2013, 00:06   #300
Thanked: 655 Times
Nothing like enjoying good music on the move, and to drown out all the other rattles!
A ZAPCO 4 channel and a JBL Crown BPX 2200.1
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
