Old 22nd June 2011, 14:25   #61
Tejas@perioimpl's Avatar
Thanked: 4,771 Times
Default Re: New 4X4 project
Originally Posted by jyobeb View Post
I am using the Safari axles. The diff ratio is 4.55:1.
Where did you get the 14B engine from? I could use a supercharger along with it. What do you think?
Allan sourced the engine for me and is doing the work.
I would anyday prefer a supercharger than a turbo so that atleast i get torque from the start. However, i don't know about the reliability of the same.
But won't the crawl with 35" tyres and 4.55:1 ratio get too fast? I know you can't go lower on the ratio since the thickness of the teeth will get narrower and may break due to the power of the vehicle and the weight of the tyres.
Tejas@perioimpl is offline   Reply With Quote
Old 22nd June 2011, 15:28   #62
Thanked: 643 Times
I will go with the 4.55 as of now. Depending on the engine and the torque and the power band, I may be forced to change.
Superchargers are available in Chennai and even Toyota 4WD boxes. Do you know if the 14B uses the same gearbox bell housing as the 4Runner or L.Cruiser?
jyobeb is offline   Reply With Quote
Old 10th August 2011, 21:03   #63
mercedised's Avatar
Thanked: 155 Times
Any updates on the current position of this project? Have you finished it yet?
mercedised is online now   Reply With Quote
Old 11th August 2011, 00:31   #64
Thanked: 643 Times
As of now only chassis & tyres are ready! Looking at a Hino 4l engine. Since Hino made engines for Toyota can anyone tell me if the W04 or the leyland equivalent (better and newer) W04CTI has a similar bolt pattern to the LC 13BT engines?
jyobeb is offline   (1) Thanks Reply With Quote
Old 17th August 2011, 00:55   #65
Thanked: 643 Times
Any help guys? Does anyone know anything about these Hino engines?
Old 17th August 2011, 12:07   #66
jeepster's Avatar
Thanked: 941 Times
contact Ashley2 , julupani , Transsenger who are active in commercial vehicles section.
they have the needed info for your query's.
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 6th September 2011, 19:44   #67
badboyscad's Avatar
Thanked: 139 Times
@ jyobeb: hope the below mentioned post helps you regarding the body for your project
http://www.team-bhp.com/forum/vintag...ml#post2489477 (Rust In Pieces... Pics of Disintegrating Classic & Vintage Cars)
badboyscad is online now   Reply With Quote
Old 6th September 2011, 20:16   #68
Thanked: 643 Times
Thanks for the lead. I hope something will work out.
Old 6th September 2011, 21:09   #69
Thanked: 532 Times
Have you made a selection of engine-transmission combo??
julupani is offline   Reply With Quote
Old 7th September 2011, 08:26   #70
Thanked: 643 Times
As of now, the Leyland w04ct engine and gearbox and TC combo off the Leyland stallion, unless I get a 14BT in good condition.
Old 7th September 2011, 08:52   #71
Thanked: 532 Times
14BT??
You mean 4BT??
Old 7th September 2011, 09:07   #72
Thanked: 643 Times
Nope! Toyota 14B(as on the DCM Toyota) turbo.
The Cummins 4B is available too but I don't know what transmission to use.
Old 7th September 2011, 09:22   #73
Thanked: 532 Times
Ok. But if you are getting one of a DCM Toyota, better make sure its in decent condition, considering those things are really really old now.
From where are you getting a Cummins 4B?? New or used??
Old 7th September 2011, 13:32   #74
Frankenstein's Avatar
Thanked: 269 Times
jyobeb
Some 4 L , 4 cylinder options
isuzu 4BD1T .. 135 BHP @4500RPM , 33KGM , 330KGS
Cummins 4BT 105BHP@3500RPM , 38KGM , 340KGS
Nissan BD30T 130BHP@3800RPM , 26KGM
How much is the cummins 4bt ? what condition.
What transmission have you planned.
Frankenstein is offline   Reply With Quote
Old 7th September 2011, 20:34   #75
Thanked: 643 Times
Where can I get an isuzu 4BD1T or a Nissan BD30T?
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
