Old 24th July 2012, 15:51   #106
svsantosh's Avatar
Thanked: 1,449 Times
Default Re: New 4X4 project
In the pics ^ - I see the prop shaft will come above/over the cross member on its way to the rear diff, how is the OE setup in a safari? below? And did you have to reengineer the engine mounts?
svsantosh is offline   Reply With Quote
Old 25th July 2012, 09:29   #107
Thanked: 655 Times
Yes Santosh, the prop shaft will come over the cross bar. Should check to see what the setup is on the Safari. This R151 gearbox is almost 12" longer than the safari gearbox. the mounts have to be re-engineered and I will be using OE engine beds.
A few more pics of the engine after the crankcase wing was chopped off.
jyobeb is offline   (4) Thanks Reply With Quote
Old 3rd August 2012, 09:51   #108
Thanked: 655 Times
The engine gearbox combo has been fixed into place with new beds and gearbox crossbar.
The turbo manifold is being modified for fitting the Toyota CT26 turbo that comes OE on the 14BT engine.
The engine has been opened up to avoid any disappointments after the vehicle build is completed. Looks like I need a new set of liners and pistons.
jyobeb is offline   (5) Thanks Reply With Quote
Old 3rd August 2012, 10:14   #109
Thanked: 175 Times
This is an awesome project Jyobeb!! Most of the other people are knowledgeable and offering advice. I'm just a keen observer! Really facinated with your project and work!
Kudos
Can't wait to see the rest of the process and of course the finished product!
Best of luck!
thumpingheart is offline   Reply With Quote
Old 4th August 2012, 08:57   #110
Thanked: 655 Times
Kudos
Best of luck!
Thanks man! A long way to go though!
jyobeb is offline   Reply With Quote
Old 5th August 2012, 19:07   #111
Thanked: 655 Times
Some pictures of the modified manifold to fit a turbo. I am using a CT26 turbo which is huge!!!
Some pictures of my engine which is being taken apart. I am planning on modifying my timing case cover to use a gear driven power steering pump like in the Innova.
New 4X4 project-14b-gear-driven-vacuum-pump.-power-steering-pump-can-fitted-..jpg
jyobeb is offline   (3) Thanks Reply With Quote
Old 5th August 2012, 19:22   #112
Thanked: 655 Times
The pump I plan to use. (Pic for reference only)
jyobeb is offline   (2) Thanks Reply With Quote
Old 7th August 2012, 22:36   #113
Thanked: 655 Times
More pics of the engine being stripped.
Pictures of WIP for 160 pcd to 139.7 pcd converter spacer.
Old 8th August 2012, 08:26   #114
svsantosh's Avatar
planning for a 16" military rim eh? going down to 139?
Old 8th August 2012, 09:36   #115
Thanked: 655 Times
No army rims. The only 10J rims I could get were 139.7 pcd.
I needed 10J rims to suit my 35x12.5/15 tyres!!!
Old 9th August 2012, 17:36   #116
Thanked: 655 Times
The tyres and wheels that I intend to mount.
Wheels are 15" 10J negative offset and tyres are MAXXIS 35x12.5x15 Trepadors.
Old 9th August 2012, 19:06   #117
Blue Thunder's Avatar
Thanked: 336 Times
Beautiful alloys and chunky/proportionate tyres!
Congrats!
I am guessing that the mounting of the tyres would have been quite a task...hope it was done without damaging the alloys.
Blue Thunder is offline   Reply With Quote
Old 9th August 2012, 19:09   #118
Thanked: 825 Times
I can see the chassis is box/tube section & its welded in places ( for renewed mountings/ cross-members etc )
So how do you intend to treat those areas near welds for the Purpose of rust proofing ? ( I mean from Inside of the box )
Have you thought about galvanizing etc ?
Sudarshan
Sudarshan is offline   Reply With Quote
Old 10th August 2012, 09:44   #119
Thanked: 655 Times
@B-T, Yup, fitting those tyres were quite an ordeal, but Samy tyres here, are experts.
@Sudarshan. You have an eye for details don't you! Welding near the front end has been treated for rust proofing by spraying in the rust proof chemical under pressure. I am not quite sure how to handle the welding done in the middle. (for fitting the crossbar)
By the way, the Safari chassis ia a CinC section.
Old 10th August 2012, 10:55   #120
Tejas@perioimpl's Avatar
Thanked: 5,490 Times
What axles are you running?
Any plan to strengthen the axles to run the 35 inchers?
Tejas@perioimpl is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
