Old 10th August 2012, 10:55   #121
Thanked: 822 Times
Default Re: New 4X4 project
Originally Posted by jyobeb View Post
== I am not quite sure how to handle the welding done in the middle. (for fitting the crossbar)
By the way, the Safari chassis ia a CinC section.
Ya Tatas are making box shape like this , seen that on sumo chassis too .
I have also encountered such problem while working on box chassis , did something that might be useful
here check this , but not So sure about the results though as I had no chance to see the chassis again ( but no complaints so far either , the vehicle is in high humidity zone now )
Name:  Chassis rust proof.png
Sudarshan
Sudarshan is offline   (2) Thanks Reply With Quote
Old 10th August 2012, 14:59   #122
Thanked: 649 Times
Originally Posted by Tejas@perioimpl
What axles are you running?
Any plan to strengthen the axles to run the 35 inchers?
As of now stock axles and diffs. Front diff is stock Dana30 and rears are 44.
jyobeb is offline   (1) Thanks Reply With Quote
Old 12th August 2012, 08:38   #123
Thanked: 649 Times
The front spacers ready for installation.
jyobeb is offline   Reply With Quote
Old 14th August 2012, 14:44   #124
svsantosh's Avatar
Thanked: 1,424 Times
can you keep one 35" tyre/rim next to a STOCK safari/scorpio (pic from side) to give me a idea of its size?
svsantosh is offline   Reply With Quote
Old 14th August 2012, 22:02   #125
Thanked: 649 Times
Some pics of the spacer and tyres.
For Santosh, comparison pics!
Old 14th August 2012, 23:27   #126
kcj3b's Avatar
Thanked: 56 Times
Originally Posted by jeepster View Post
some new pics.
rgds,
Nikhil
Dear Nikhil,
Can we please have some more details about these custom Body manufacture? Any idea if they do cj3b body tubs? Such ventures need to be encouraged for the benefit of Custom builders.
kcj3b is offline   Reply With Quote
Old 15th August 2012, 12:14   #127
AlphaKilo's Avatar
Thanked: 363 Times
Sir, i believe you had already noted, but if not, I believe that the disk with spacer picture shows the brake disk to be bent. Please check.
AlphaKilo is offline   Reply With Quote
Old 15th August 2012, 12:24   #128
Thanked: 649 Times
Its the angle bro! It looks bent doesn't it? Checked and found OK. Thanks anyway.
Old 20th August 2012, 13:00   #129
Thanked: 649 Times
Rear spacer (1.25") with collar ready.
Rear tyre fitted.
jyobeb is offline   (2) Thanks Reply With Quote
Old 21st August 2012, 13:21   #130
svsantosh's Avatar
ah, nice to see the business end of a off-roader chassis+tyre combo looks propotional... how far is the engine work?
Old 21st August 2012, 23:35   #131
AlphaKilo's Avatar
Thanked: 363 Times
Rear tyre fitted.
sir,
is that the clutch assembly lying on the tyre? One lame question, how function/useful are these "bling" rims during OTR's? Can they bear the load and abuse? can you carry spare rims in case of some issue?
Old 21st August 2012, 23:47   #132
Thanked: 649 Times
sir,
Yup! That is the clutch assembly. Not kept very properly, I know. All cleaned up now!
I really don't know about the rims. They are supposed to be quite tough. I choose them for the negative offser and also because 10J rims were not available in steel. Now, however, Viji has them.
@ Santosh. Waiting for parts to come in. I was sent the wrong type of liners and hence waiting for the right set. All other parts have reached me.
Old 6th September 2012, 19:44   #133
Thanked: 649 Times
My gear driven power steering pump is getting ready. I am using the pump off a land cruiser. The gear was too short for this and hence had to get a new gear wire cut and hardened. Installation happening soon.
Old 8th September 2012, 20:34   #134
Thanked: 649 Times
Some pics of my modified crank case, 14B engine with the new turbo and engine being assembled.
Old 9th September 2012, 21:33   #135
Frankenstein's Avatar
Thanked: 300 Times
HI,jyobeb. How did you source the ct26 turbo.
Which intercooler are you using?
Does the nippo denso pump have the boost compensator aka the alda sensor?
Are you increasing the diesel flow?
How much torque are you expecting?
What rpm does the turbo start to spool?
How big is the turbo compared to the scorpio turbo?
Guess i missed it, what axles and ratios are you using?
Do you have the ratios of the toyota gearbox?
Was the engine rebuilt using original toyota parts or taiwan parts?
There were 160pcd 10j rims on facebook last i saw.
Sorry for asking so many questions
Frankenstein is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
My New Project: The Doctor 4x4 Jaskirat 4x4 Vehicles 17 17th March 2016 14:53
Safari 2.2 - 4x4 - Offroad specific suspension modification project. jaysmokesleaves 4x4 Vehicles 21 19th October 2015 00:22
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
