Old 23rd March 2011, 11:42   #1
LKCRUISERS's Avatar
Thanked: 45 Times
Default Bolero Load Carrier 4x4 conversion
Hi
Picked up an Insurance write off Bolero 2WD Load carrier. Planning on converting to a 4x4. Can anyone post the Rear Diff Ratio of the Bolero ?
I has got 2.5L Diesel Turbo. (Not the CRDi Version)
LKCRUISERS is offline   Reply With Quote
Old 23rd March 2011, 12:37   #2
ex670c's Avatar
Thanked: 1,821 Times
Default Re: Bolero Load Carrier 4x4 conversion
Originally Posted by LKCRUISERS View Post
Hi
Hi Sean,
IIRC the Rear Diff & Axles are Dana 44, please check on the pumpkin for an Aluminium Tag which has the Differential Ratio.
The Pickup Versions are usually fitted with.
1) 4.3:1 for MDI3200TC
2) 4.55:1 for NEF249TCIC
Arka
Old 26th March 2011, 08:53   #3
LKCRUISERS's Avatar
Thanked: 45 Times
Originally Posted by ex670c View Post
Hi Sean,
Arka
Thanks Arka,
saved me a lot of labour hours. It is a 4.3. Some Pictures attached
Old 29th March 2011, 10:37   #4
ex670c's Avatar
Thanks Arka,
He Sean,
Please tell me more about the buggy? with TSL's.
Arka
Old 1st April 2011, 19:06   #5
LKCRUISERS's Avatar
Thanked: 45 Times
He Sean,
Arka
Come over for Taprobana and see it in Action. Nissan TD 42 4.2 Diesel Turbo Charged, with "Gods Winch" with Patrol Gear. It is a fun Toy.
Found a Divorced Transfer Case and a 4.3 Cruiser Diff for the front, and Land Cruiser FJ 55 springs are close match.
Old 9th April 2011, 15:26   #6
LKCRUISERS's Avatar
Thanked: 45 Times
Took the Cabin Out. The Engine does not have any hooks or hooking points, I wonder how they put it in. Relocate the Fuel Tank. Put in a divorced transfer case. Redeirect the exhaust. And most important to relocate the hand brake to the center, as the Sarong gets entangled it.
LKCRUISERS is offline   (1) Thanks Reply With Quote
Old 9th April 2011, 15:57   #7
Thanked: 655 Times
Which divorced transfer case are you using?
jyobeb is offline   Reply With Quote
Old 13th April 2011, 18:52   #8
LKCRUISERS's Avatar
Thanked: 45 Times
Nissan 720 Which was coupled with 2.3-2.5 Litre SD23/SD25.Which can sit Nicely on the Cross bar where the Prop coupling is.
Also need to Match the PCD of the wheels if I am to retain the original Rear Axle. Why Indian Vehicles Choose 160 PCD ? Only Unique to Mahindra and Tata. Limited Wheel Choice.
Old 13th April 2011, 19:23   #9
svsantosh's Avatar
Thanked: 1,444 Times
Dear Sean,
I just had a thought, why isnt the engine/GB taken OFF the chassis before placing the whole assembly on the ground. I think it will cause unwanted stress on some chassis points and cause it to flex/bend. Would you agree?
Regd 160PCD, even TATA safari has a 160 PCD, 5 bolt pattern. But if you asking with ref to large tyres and alloyz combo then I think you will have a problem.
svsantosh is offline   Reply With Quote
Old 29th May 2011, 17:02   #10
LKCRUISERS's Avatar
Thanked: 45 Times
Dear Sean,
Chassis was bent already due to collision. If in tact yes would be a good idea.
Was not able to post further progress will do soon.
Old 2nd June 2011, 10:23   #11
ex670c's Avatar
Default Unimog
Hi Sean,
Please do post a few pics of the UNIMOG (54) and the Grand Wagoneer (IIRC).
Arka
Gypsy Diesel conversion with 4x4 GoSlow 4x4 Vehicles 182 20th August 2014 15:28
Tata Troop Carrier with Soft Top : SA 1212TC 4x4 ranjithrnath Commercial Vehicles 9 17th February 2013 02:11
Roof-mounted luggage carrier / roofbox /cycle carrier for Aveo itwasntme Modifications & Accessories 21 4th February 2013 18:39
Bolero SLX 4x4 conversion project desertfox 4x4 Technical 62 20th June 2012 09:41
Bolero Invader 4X2 to 4X4 Conversion inder_s1 4x4 Technical 19 29th November 2009 16:38
