Old 19th January 2014, 13:30   #196
4x4addict's Avatar
Thanked: 2,513 Times
Default Re: Thar Hardtop Design
Originally Posted by DirtyDan View Post
The rear metal/glass door eliminates the need to fight thru a filthy hard to operate zipper and filthy fabric rear flap. You can now access the rear of the cabin without having to wash up afterward.
Absolutely Dan !!
Besides safety, the dust is what gets very annoying. Everything in the jeep is covered in dust that enters through the rear opening.
4x4addict is offline   Reply With Quote
Old 19th January 2014, 18:28   #197
Thanked: 381 Times
Default Re: Finished Semi Hard Top
Adding a few pics of my finished semi-hard top.
Looks very neat. But what is a "semi hard top " ?
girimajiananth is offline   Reply With Quote
Old 19th January 2014, 19:08   #198
4x4addict's Avatar
I have metal enclosure only on the sides and rear door. The top is just the original insulated canvas to keep the weight lower than a complete hard top with sheet metal on top also.
4x4addict is offline   (1) Thanks Reply With Quote
Old 20th January 2014, 09:37   #199
Thanked: 381 Times
What about the strength of the roof ? Will it be reliable enough ? Suppose you remove the canvas and go on a highway drive will there be lot of rattles and squeaks from the the side metal enclosures ?
PS: Sorry I was unable to see the pics you had uploaded before . The office proxy server was blocking a few images . Those pics were very clear.
Old 6th June 2015, 19:35   #200
wanderernomad's Avatar
Thanked: 787 Times
Guys can someone please post some detailed pictures of how an FRP top is secured on the front windshield frame. I am trying to mount a first generation roplas top on my cj500 and I want it to be a removable top. Need advise on securing the top with screws or an alternate latching mechanism that is easy to operate.
wanderernomad is offline   Reply With Quote
Old 16th June 2015, 19:34   #201
renegade's Avatar
Thanked: 36 Times
Thought i would share what i fabricated,the purpose was to lock the luggage while travelling and a two seater since nobody wanted to sit at the back,so removed the rear seat and made a short hardtop with lockable storage bays.
renegade is offline   (8) Thanks Reply With Quote
Old 23rd December 2015, 13:59   #202
The Iceman's Avatar
The rear door on your semi-hard top looks like a single unit, not a FRP top half attached to the metal bottom half. How did you do that?
The Iceman is offline   Reply With Quote
Old 23rd December 2015, 15:47   #203
4x4addict's Avatar
The rear is a full sheet metal door. Hence, the top half is welded onto the existing door.
Old 26th December 2015, 09:37   #204
Pjango's Avatar
Very well executed Sir 👍
I'd request for a few WIP pics if you can post here ! Especially the central boot lid. Would give a better idea how ws this achieved. Cheers ☺
Pjango
Pjango is offline   Reply With Quote
Old 10th May 2016, 14:55   #205
Dr_MNC_SK's Avatar
Thanked: 217 Times
Hi there, That is a neatly finished soft looking hardtop. I was wondering of doing the same with mine so had a few queries.
1. What thickness material steel did you use? is is welded to the original frame of soft top?
2. Windows were sourced from which vehicle?
3. How did the soft top cover join the window metal area? or is it left free? Doesnt things (read debris) go between them.
4. How is the rattling? How is the soft top flapping noise?
5. Was it easy to put the soft top back over this metallic frame?
6. Wanted to see the interiors once
7. Doesn't water seep in between the rear door and frame?
Thank you in advance
Dr_MNC_SK is offline   Reply With Quote
Old 11th May 2016, 21:03   #206
4x4addict's Avatar
Thx
Don't recall the exact thickness, but I think it is standard 2mm sheet used for body work. It is welded/spoted on to the frame of the of the soft top. You can see my work in-progress pictures which is a couple of posts before the finished pictures.
It is the last window of the tempo traveller bigger version.
The soft top is cut in the same shape of the window. It is then stuck to the metal using rexine paste and the window beading goes over it. It is a tight fit so no leaks in the window beading.
No rattling or soft top flapping noise.
I used a CRDe top which is tight to begin with so it was a damn hard fit.
Will post pics.
. If you use the existing door, it will leak with any hard top. The only way to avoid this is to build a full door with water channel. I have put a rain channel outside along the top part of the door, so it is reduced to some extend, but it does leak..
The most practical & best looking Hardtop - Mahindra Thar Monster_BHP 4x4 Vehicles 249 23rd October 2017 21:17
Pics : Yellow Hardtop Porsche Boxster v12 Super-Cars & Imports in India 49 1st August 2010 00:29
Modding a HardTop Gypsy Vineshway Modifications & Accessories 2 17th December 2007 20:11
Well BMW has done it again. Spoilt another car (All new 3 series HardTop Convert Rel) 1Day The International Automotive Scene 16 31st October 2006 23:03
