Old 10th April 2011, 12:58   #1
Thanked: 19 Times
Default Engine vibration in a '52 CJ3A Jeep with Peugeot powerplant
hi friends,
i have picked up a 1952 cj3a with a peugeot engine.the engine was
overhauled and all the mountings including the four wheel gearbox
have been changed.there was an strong vibration from the
engine even at idling which still persists.what can be the cause
and the remedy for this. suggestions welcome.there is an excessive
knocking also from the engine.it has a CAV pump which has been
serviced alongwith the injectors. suggestions welcome.
regards.
hps aulakh is offline   Reply With Quote
Old 10th April 2011, 14:04   #2
star_aqua's Avatar
Thanked: 89 Times
Default re: Engine vibration in a '52 CJ3A Jeep with Peugeot powerplant
Originally Posted by hps aulakh View Post
hi friends,
regards.
Cylinder balancing is NOT OK. get the injectors checked again for balancing and adjusted for equal pressure in all four. or if it is done recently, add some engine oil to the diesel and take it for a long drive. it will reduce knocking.
star_aqua is offline   Reply With Quote
Old 11th April 2011, 08:20   #3
motocamp's Avatar
Thanked: 99 Times
before you do anything get the pump delivery pipes to the ngine checked if your mechanic has not connected them to the cylinders in the correct order, the fuel would be deliverd to the wrong cylinder at the wrong time, which leads to heavy knocking and a lot of noise.
motocamp is offline   Reply With Quote
Old 11th April 2011, 09:53   #4
sudev's Avatar
Thanked: 2,637 Times
@motocamp: IMHO would that have been the case the engine would not start.
Check cylinder compression and injectors. If all are not equal then the engine would be running rough. Also make sure that the exhaust pine etc are properly "hung" and not touching the body.
Do post here the solution that works.
sudev is online now   Reply With Quote
Old 11th April 2011, 10:04   #5
ex670c's Avatar
Thanked: 1,820 Times
hi friends,
regards.
Hi HPS,
Please check
1) T-Case Mount (Cross-Bolt)
2) Engine/FIP Timing and Idling Speed.
Arka
Old 11th April 2011, 17:31   #6
Thanked: 19 Times
Default Re: Engine vibration in a '52 CJ3A Jeep with Peugeot powerplant
this engine originally was fitted with a MICO FIP,which was changed to a CAV FIP.i dont think that should be a cause for the knocking.any way like you suggest i am going to get the injector pressure checked.shall get back with the result.theexhaust is fitted with rubber brackets.
Peugeot ditches Gujarat Factory plans. GM unwilling to let Peugeot use its plants GTO The Indian Car Scene 47 7th October 2016 12:57
My Cj3A. And a Hello! adnan_1212 Introduce yourself 7 3rd December 2010 17:09
My CJ3A Story, Jeep Gurus please read! vinayrathore 4x4 Vehicles 12 24th December 2009 21:04
Che Jeep dream comes true with CJ3A docfreak 4x4 Technical 35 24th December 2009 08:09
Jeep CJ3A JeepCaptain 4x4 Vehicles 10 16th December 2009 10:26
