Old 31st October 2011, 11:01   #181
Rajith's Avatar
Thanked: 185 Times
Originally Posted by carrot_eater View Post
Hey Rajith - Just curious - did you get a chance to notice the drop in mileage. How much is it with AC.
I've heard and noticed the noise levels drop considerably inside the cabin once the AC is installed - Did you also notice this. I mean this is over and above the noise levels that you experience with the ability to drive with the windows rolled up.
Enjoy your Thar - And thank you for posting your experience about the AC - I am still contemplating about it.
Carrot
Mileage drop not noticed.
Reg noice reduction,didnt find any major reduction.
Originally Posted by Ragul View Post
Hi Ranjith
Sorry for the OT - I am planning to add A/C to my new Gypsy in a few months time. I need feedback about We Cool - how is their workmanship? Is their execution and attention to detail good? Is there any piping or a/c related gear exposed inside cabin or is everything concealed? Do they listen to customer requirements and try to match or do they have a "this is how we do it" approach like every other shop?
Lastly how many days did they take and did you have to leave your car with them overnight? Any suspect abuse or mis-use of the car when left overnight for days?
--Ragul
Work man ship is good, they listen to customer,Mostly his customers are Merc & hi end cars.Left morning 9.30am & got back by 5.30pm same day. .
Last edited by Jaggu : 31st October 2011 at 11:27. Reason: Back to back posts, please use Multi Quote (Quote+) instead. Thanks
Rajith is offline   (1) Thanks Reply With Quote
Old 31st October 2011, 14:23   #182
Thanked: 1,451 Times
Default Re: Advice on fitting an air-conditioner in the Mahindra Thar
Dear Rajith - I saw the photographs. I do not understand why a hose must be looped around the brake booster. The AC pipes are not grommeted at the point where they pass through the holes drilled into sheet metal. The bracket used to mount the condenser has a lot of slots in it, giving the impression of a hurried aftermarket installation which is not good for appearance / performance / reliability. Also, this does not indicate good craftsmanship and these are the small things which separate a great job from just a normal job. These things don't get seen by an average customer, but to me, this is just not done. Please get these things corrected in your vehicle so as to differentiate it from the "normal" AC Thar CRDe vehicles. I know that your "AC - wallah" will rubbish all this but somebody's got to do it properly some time. The AC line pressure must measure between 15 and 20 bars at the condenser outlet position. You have indcated 23 psi, I presume you mean bar. This line pressure must be measured at 1500 engine rpm (not at 900 rpm) with AC blower set to maximum speed. The reading that you have given clearly indicates a need for two pusher type condenser fans. Please get them included in the system to ensure performance and reliability. 200 mm diameter fans should be adequate. This is exactly what we had done when we released the SOP in the system. Please see the photograph of customer car MH01VA9643 on post 1 of page 1 of this thread. This is the first car I did as per SOP and delivered to the customer on 15 March 2011 in Mumbai. Please note that nowadays there is a growing trend to do away with the condenser fan and ensure adequate performance through the main engine fan only. This is still in the development stage. A lot of work needs to be done in the aerodynamics area to achieve acceptable performance / reliability. Thar CRDe air deflector (front grille tunnel through which air flows onto the radiator) is not the best configuration from aerodynamics point of view but as Thar CRDe uses two condenser fans, it is not critical in present configuration.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (2) Thanks Reply With Quote
Old 31st October 2011, 14:54   #183
Rajith's Avatar
Thanked: 185 Times
Best regards,
Behram Dhabhar
sir,
Thanks for your valuable feedback.
i will get the slotted angle bracket, gourmet & pipe line winded thru the booster corrected.I will check the line pressure as adviced by you & update back all by wednsday
Rajith is offline   Reply With Quote
Old 31st October 2011, 17:08   #184
Thanked: 97 Times
Originally Posted by Rajith View Post
Ranjith
Did you feel reduction in pulling power with A/C on?
Behram Dhabhar
Dear Behram-ji
Is this pressure reading a function of the engine characteristics/performance of the Thar or is this a universal benchmark for any vehicle? Sorry for the noob question, but I was wondering if I will need to take similar care when fitting A/C for my Gypsy.
--Ragul
Ragul is offline   Reply With Quote
Old 31st October 2011, 19:31   #185
Jaggu's Avatar
Thanked: 804 Times
@Rajith: Few pictures for TeamBHP also would be great. Have you done any partition in the front passenger area or is the AC cooling the whole vehicle? What is the size of the compressor?
Old 31st October 2011, 19:55   #186
carrot_eater's Avatar
Thanked: 52 Times
Would this mean that there is no requirement for additional fans to be fitted with the AC.
Also - does this mean that it is not advisable to get the insect mesh installed. That should also hamper air flow - or the effect is insignificant.
carrot_eater is offline   Reply With Quote
Old 2nd November 2011, 10:49   #187
Rajith's Avatar
Thanked: 185 Times
Dear behram sir,
Condenser pressure of the AC is 18bar.
Slotted clamps are universal,supplied from Mumbai.Used in after mkt fittment of TT,SUMO,AMBY,BOLERO etc at "WE COOL" since last 20 years, felt quiet thick and strong.
Pipes are from bridgestone,getting shortned from crimping supplier in Mumbai.
200mm fan available in after mkt is from REVA - AC Kit , its 24 volt.
12 volt supplier details not available..please suggest.
Seems good to avoid insect mesh for A/C THAR, with out condenser fan set up.
Jaggu Bhai,
Pics attached with AC & CFL at Rear
Excellent cooling,no drop in pick up,No idling issues when AC ON or OFF, Ride & Handling excellent with CFL.
Old 2nd November 2011, 10:52   #188
Rajith's Avatar
Thanked: 185 Times
No partition is done inside the vehicle.Compressor is from scorpio-170 series,Delphi condenser coil,Universal RD bottle,santen - bolero cooling coil, Bridge stone pipes,Pacific thermostat,Hyundai relay & pure R132 gas.
Cooling is fantastic and mist formation is there on rear canopy laminations due to cold..using only 1/4th of thermostat movement to keep cooling in tab.
Old 2nd November 2011, 13:00   #189
SPIKE ARRESTOR's Avatar
Thanked: 464 Times
Originally Posted by headers View Post
Maybe in one year, you will get factory fitted AC and dealer fitted hard top..
LOL!
Is this pressure reading a function of the engine characteristics/performance of the Thar or is this a universal benchmark for any vehicle?l
No Ragul, they are not Thar specific. The suction and discharge pressures are determined according to the refrigerant used and the ambient conditions (temperature, humidity etc), there is a graph specifically to be used for this. Usually Ps~ 1.5 - 2.2 Bar and Pd ~ 15 - 22 Bar at 30-35 deg C is accepted as a ball park figure.
It is Ok.
pure R132 gas.
I hope it is R134a and not R12, oil specifications are different for both.
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Old 2nd November 2011, 17:33   #190
Rajith's Avatar
Thanked: 185 Times
yes spike, Gas used 1s 100% pure R134a only
Old 2nd November 2011, 18:03   #191
Dear Rajith - do I allow you to run without any condenser fan? NO! We will have to find a solution. As a worst case scenario, I recommend you use the Bolero VLX 300 mm diameter fan and move the intercooler forwards and downwards to get adequate working clearance. For one car, it is possible but it will have to be done carefully. From your comment justifying slotted brackets, I don't think your present AC fellow can handle this. Please find an alternate guy who understands and has the passion to do it properly. I need minimum 8 mm clearance between the back of the condenser and the front of the radiator.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 2nd November 2011, 18:15   #192
4x4addict's Avatar
Thanked: 485 Times
@behram:
Will the original intercooler hose fit if the intercooler is moved forwards and downwards.
4x4addict is offline   Reply With Quote
Old 2nd November 2011, 19:48   #193
Thanked: 30 Times
All,
For those who want to have a look at a SOP fitted A/C or if you need to show your mechanics or external A/C fitment workshops on what has been done and how it looks.
Please feel free to contact me on +919845530451.
Vijay
vj_k2001 is offline   Reply With Quote
Old 3rd November 2011, 09:53   #194
Rajith's Avatar
Thanked: 185 Times
Best regards,
Behram Dhabhar
sir,
Thanks for valuable guidance.
noted to get non slotted angles.
Theres 8mm clearence.
Will find out 200mm , 12 volt fan asap.
Rgrds,
Rajith
Old 3rd November 2011, 11:45   #195
Originally Posted by vj_k2001 View Post
All, For those who want to have a look at a SOP fitted A/C or if you need to show your mechanics or external A/C fitment workshops on what has been done and how it looks. Please feel free to contact me on +919845530451. Regards, Vijay
Dear Vijay - start a consultancy, you'll earn a lot of goodwill. What more can I say! HaHaHa! .
Dear Rajith - please see Vijay's vehicle.
THIS IS REAL CUSTOMER-CENTRICITY. ALL YOU CUSTOMERS ARE HELPING EACH OTHER AS BRAND AMBASSADORS. HERE'S HOPING THAT "SOMEBODY WHO MATTERS" READS, REALLY UNDERSTANDS AND DOES SOMETHING ABOUT IT SO FACTORY FITTED AC HAPPENS FAST! IT'S A TALL ORDER BUT I ALWAYS HOPE FOR THE BEST!
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Updated Mahindra Thar in 2-3 months. EDIT : Launched with Air-Con and immobilizer! shireeshjacobs 4x4 Vehicles 350 13th May 2013 16:24
Fitting an Air-conditioner in the Maruti 800 navdeep Technical Stuff 95 24th March 2012 17:07
Mahindra Xylo : Odometer showing distance traveled with air-conditioner mmxylorider Technical Stuff 12 26th June 2011 19:14
Best ROOM Air conditioner Max Shifting gears 2 3rd April 2006 09:52
