| LinkBack | Thread Tools | Search this Thread |
| | #31 | |
| BHPian Join Date: May 2011 Location: N delhi
Thanked: 11 Times
| Quote:
I got an AC fitted in the Thar and have the heater in place. Sorry guys, was wanting to get this posted earlier with the summer in full swing but did not get a chance as I did not get my membership to the forum despite two tries. I then wrote to the moderators with this post in mind and pronto - here we are. This is what was done:
I got this done from Quick Refrigeration at Lajpat Nagar, Delhi. The owner there a Sardarji has loads of experience and we have been going to him for decades. He should charge about 35K or so. The fitting of the condensor below the chassis level may not be the best for off road use, but we will resolve that in time. At least the car is bearable in the summer. Please do not hesitate to ask if you need further advice. Good Luck | |
| | (2)
| | #32 | |
| Senior - BHPian Join Date: Nov 2009 Location: Deutschland
Thanked: 467 Times
| Quote:
Spike | |
| | #33 | |
| Senior - BHPian Join Date: May 2006 Location: Greater Chennai
Thanked: 328 Times
| Quote:
And if it is dangerous, then the THAR CRDe should be factory fitted with AC and HT, so that customers are not taken for a ride! Also, if the customer does not want offroad use, one can live with it. | |
| | #34 | |
| Senior - BHPian | Quote:
Enjoy your THAR and do start your ownership thread. Cheers | |
| | #35 |
Thanked: 11 Times
Condensor below the body has been normal setup on the Gypsy for years atleast since the MFPI was introduced. I had an earlier Gypsy (1000 cc) with a condensor fitted in front of the radiator with additional cooling fans. That was a nightmare. |
| | (1)
| | #36 |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
Thanked: 957 Times
| Thanks nnn for sharing the details, though am not a big fan of underbody grill for this overheating jeep, this seems to be the best set up. If its just front cabin set up cooling would be better. How about keeping the grill at the rear area with fan set up on a front cabin only set up? Safe and secure, just wild thinking ![]() |
| | #37 | |
| BHPian | Quote:
| | #38 |
| BHPian Join Date: Nov 2009 Location: Drivers seat
Thanked: 72 Times
| For the people who definitely need an A.C. in the Thar, would do good waiting till the Company comes up with a viable solution(properly tried & tested) instead of the present one that looks nothing less than a Jugaad. |
| | #39 | |
Thanked: 467 Times
| Not needed, atleast for me. . Yes, it depends on what the usage will be like.Quote:
I agree for normal use the set up "may" be just fine, try and position it in the front, nothing like it. Spike Last edited by SPIKE ARRESTOR : 22nd May 2011 at 19:49. | |
| | #40 |
Thanked: 11 Times
| spike, Will let you known in a couple of days the make of the vehicle which uses condensor fitted in my Thar. I need to visit the guys who fitted the A/c and check from them. Maybe the condensor mounted a couple of inches ahead of the radiator grill behind the bull bar or attached to the bull bar may be a better solution. One could lower it by removing the cover on the chassis and slip it down a bit and let it protrude up a bit. As I said earlier with the summer in full swing we adopted a quick fix which we were sure would work and was possible with no discussions immediately. I am going to investigate that alternative. What are your views? The cost of the condensor was Rs. 3000 and the fan Rs. 2000 from what I remember when the owner of the shop estimated and made a quote. I did not bother to ask after the job was completed. Good Luck nnn |
| | #41 | ||||
Thanked: 467 Times
| Quote:
1. Good air flow 2. Sufficient working clearances with the "environment". Quote:
Spike | ||||
| | #42 |
Thanked: 11 Times
| Spike, The 16" fan is from a Safari (I am told). The condenser is what they fit on the Gypsy as an after market A/C fitting (I am told). I got a Travera Condenser today. We will be removing the cover over the chassis between the bumper and the radiator grill, and slipping in the condenser down to the horns and letting it come just over the bumper. The width is just about 2 mm short of the chassis opening. If required, maybe we re-locate the horn to give it just that extra space. The fan will be fitted on top of the condenser. If what we plan gets done, Hurrah the condenser will be out of harms way as the Torsion bar is there to protect the Condenser from the front. I could also put a guard below the condenser to make it good for most off-road use. I will keep you updated. This may take time as I am away for a couple of weeks on business. Good Luck. nnn Quick refrigeration have done another couple of Thar's in the meantime. |
| | #43 |
| BHPian Join Date: Jun 2009 Location: Chandigarh
Thanked: 27 Times
| A friend of mine bought Thar Crde this Monday from Swami Automobiles, Chandigarh. I had gone through this thread and got an impression that M&M would have given sufficient instructions to the dealers to fit an ac. So I also suggested him to get it fitted from the dealership itself. The dealer told us that he would fit the original ac that also comes with Scorpio and if my friend gets ac fitted from the dealership, the warranty on the vehicle will not be void. My friend readily agreed since it will be difficult to drive Thar in this heat during current month. He left the Vehicle at the dealership the next morning for ac fitting. Cost quoted was 27k which he did not negotiate at all. And after the ac was fitted (same evening) the executive very casually tells us that they outsource all the ac fitment to local ac mechanic outside the dealership, in his case, it was ,Binda AC', in sector 28. Also the compressor that is fitted is Sanden 507. And that too, i am not sure is original Japanese. The ac is grossly in-adequate and not cooling properly. And when my friend mentioned this to the dealership they told us that it will be like this only, since the vehicle has soft top. Disgusted, my friend is fitting Thar with a wooden plywood separation between the front and rear seats. I seriously suggest all Thar owners to be wary of such traps laid by rogue Mahindra dealers who lie to their customers. And they must make sure of all the components that go into their vehicles before getting the job done. And also be sure to be present during the job is being done. And I not going to even think or suggest buying a Thar unless it comes with factory ac. Period. Last edited by wanderhermit : 26th May 2011 at 21:12. |
| | (8)
| | #44 | |
I am sorry to hear what happened to your friend. This shouldn't happen to someone who has just spend 7 Lakhs OTR for a "Life Style" vehicle. | |
| | (2)
| | #45 |
| BHPian Join Date: Dec 2009 Location: Guntur, AP
Thanked: 16 Times
| BD sir/ Spike AC fitment to Thar am i to infer that the factory fitted HT is coming Plz say yes, a customer awaits ![]() |
Similar Threads | ||||
| Updated Mahindra Thar in 2-3 months. EDIT : Launched with Air-Con and immobilizer! | shireeshjacobs | 4x4 Vehicles | 350 | 13th May 2013 16:24 |
| Fitting an Air-conditioner in the Maruti 800 | navdeep | Technical Stuff | 95 | 24th March 2012 17:07 |
| Mahindra Xylo : Odometer showing distance traveled with air-conditioner | mmxylorider | Technical Stuff | 12 | 26th June 2011 19:14 |
| Best ROOM Air conditioner | Max | Shifting gears | 2 | 3rd April 2006 09:52 |
