| LinkBack | Thread Tools | Search this Thread |
| | #106 | |
| Senior - BHPian | Quote:
Please understand what BD meant was that "YOU WILL BE TAKEN CARE ". Which way, your guess is as good as mine. ![]() Thank god I decided to dump the THAR and buy the Getaway. Thankfully I don't have sleepless nights having a vehicle which has been orphaned by its makers :P (Actually it was right from the start barring very few people like the THAR team that included BD, Spikey and Vinod) | |
| | #107 | |
| BHPian Join Date: May 2011 Location: N delhi
Thanked: 11 Times
| Quote:
What about the longer wheelbase of the Getaway as compared to the Thar for off road use. The only major problem with the Thar is the A/C (and heater) and I have got both under control. My A/C is working great. Regards nnn | |
| | #108 | |
| BHPian Join Date: Apr 2008 Location: Bangalore
Thanked: 52 Times
| Quote:
The Dealer in Bangalore - India Garage, today told me they are still waiting for the SOP from Mahindra. How can it take so long for the dealers to have the AC kit. | |
| | #109 | |
| BHPian Join Date: Nov 2009 Location: Drivers seat
Thanked: 72 Times
| Quote:
![]() Hopeless situation, I have been warning consumers about this but there were others who kept insisting otherwise. Thar is probably an abandoned product now ![]() Last edited by GTO : 21st June 2011 at 15:55. Reason: Lets avoid inappropriate language on this forum | |
| | #110 |
Thanked: 11 Times
| Dear Carrot_eater, I have not bothered to ask for the SOP as my cars was fitted with the A/C by the time M&M announced the SOP. The A/C is working well. The car does not overheat and cools adequately. Please refer to an earlier post to know what I have done. However in principle having understood the SOP as written by by Behram which started this thread, I feel that the kit advised by M&M will be effective. If I had not already fitted the A/C that is what I would do. Do not go by any fitting suggested by M&M dealers which does not conform to the SOP as that will fail. One fan is not adequate as used by most dealers. Relocating the intercooler is certainly not advisible specially when M&M do not recommend it. You will need 2 fans to keep the vehicle from overheating as described by Behram. Else ask M&M for their approval and use the fitting described by me which may be better in a way as there is no obstruction of airflow to the radiator by the condensor. Only change I reccomed from the fitting I have done is to use a Bolero compressor which is of a smaller capacity (though adequate) than the Scorpio compressor. Regards nnn |
| | #111 | |
| Distinguished - BHPian ![]() Join Date: Jul 2007 Location: MUMBAI
Thanked: 1,460 Times
| Quote:
Best regards, Behram Dhabhar Last edited by GTO : 21st June 2011 at 15:56. Reason: Quoted post has been edited | |
| | (1)
| | #112 | |
Thanked: 52 Times
| Quote:
I am only concerned is that I shouldn't be taking the delivery of the Thar and wait for 3-4 months before I get the AC. (I have booked a Thar in March and delayed delivery only because of the AC confusion). I cannot use a non -AC vehicle as my daily drive and Thar will become my daily drive. | |
| | #113 | |
Thanked: 11 Times
| Quote:
Push come to shove - Just go ahead and fit the A/C as I have done. Please enquire if a Bolero Crde compressor, cooling coil (if you do not insist on a heater) and Delivery / Suction hoses are available with the dealer. Or Ask a local after market A/C fitter and if he can source these items - will be much cheaper than M&M. Use a Superking or other cooling coil and fan in addition to the heater as delivered to work with the compressor. The important thing is not to obstruct airflow to the radiator else the car will overheat. I will send you photographs to show you my fitting if required. I am in the process of relocating the Condensor to the front of the vehicle from the bottom getting rid of the danger of the Condesnor bottoming even though it is above the lowest part of the vehicle. I use the Thar daily and enjoy it. Forget and be and clap. This life is too short for complaining as some others have been doing.Ha Ha. Regards nnn Last edited by Technocrat : 22nd June 2011 at 02:19. Reason: only 2 smilies per post allowed, Pelase read our board rules before proceeding, thanks | |
| | #114 | |
Could not agree with you more. I distinctly remember that I bought my first car in 1987 which was a NON-AC Maruti 800, after a few years I had enough savings to fix an AC on the car. I went like you said to a vendor NOT even MASS, the guy installed the AC in around 2-3 hours as the car was AC ready & I used that car for long after that. Never had any issues. The cooling was at par with company fitted AC cars........sigh !! That too in 1987 today we are in 2011 & M&M did not factor in this basic need ![]() I am on the verge of getting a thar & modifying it with a hard top & AC, BUT I still wish I could get a factory option atleast for the AC @ nnn I quite agree with your optimism !! The aftermarket Quick Refrigeration guy has been in the business of fitting AC's in cars since the time of the Fiat's & Amby's - he does know his job, there is no denying that. There have been instances of the Coil being fitted on rooftops with electric fans, that I have seen...worked great but looked - yucky.. So what are your plans, relocating the condenser inside the engine bay ? I am curious as I want to buy a THAR & modify it with a 2+2 cabin and an AC, Maxxis Bighorn / Yokohama M/T's, nice alloys & a lift kit from Ironman if they build it anytime soon... but have held off because unless the damn AC works well, there is no way one can use it in our Delhi kind of weather. @Mr Dhabhar By when can one "realistically" get an option on the AC Cheers Last edited by Ricky_63 : 22nd June 2011 at 19:59. | |
| | #115 | |
Thanked: 11 Times
| Quote:
Mount a Travera condensor behind and below the front bumper - remove the cover above the chassis - slip the condensor at an angle above the Torsion bar - One would need to remove the Horn mounting bracket and relocate the horn to give a bit of extra space. That way the condensor would not be seen, be safe from damage and not obstruct airflow to the radiator. Quick refregeration could do it easily. They have done another Thar apart from mine. | |
| | #116 |
| Senior - BHPian | I am attaching pictures of the kind of body I would want to get on the THAR as & when I buy one..would the after market AC with the Tavera Condenser serve the cabin space well or should one go for a half cabin like the rally Gypsies ? There was also someone developing a FRP top for the Thar..is it anything like this ?? Views are welcome. Would appreciate it Cheers |
| | #117 | |
Thanked: 11 Times
| Quote:
My Thar cools with the soft top in these days Delhi heat. Not Freezing but not sweating in the hot sun. Please remember that there is no insulation and the Soft top is black and absorbs loads of heat. I am getting some insulation done shortly. With an insulated body like you want it will cool well. Try Manas on 09900246668 for the FRP body. I do not know if they have completed the moulds as yet but they were working on a set. Check another thread on the Thar Hard Top on this forum. nnn | |
| | #118 | |
Many thanks for the guidance Manas did respond to my querry on the "other" thread !!Are you considering a hard top any time soon ?? Cheers | |
| | #119 |
Thanked: 11 Times
| | #120 |
| Newbie Join Date: Jun 2011 Location: Bangalore
| Last enquired, folks at Sireesh, Bangalore told me of a few A/c kits lying idle for the past couple of months still waiting for someone at M&M to guide them on the installation procedure. cost - 60k. Can someone in M&M pls send over a few folks to teach them how this is done. I have been pestering them for the A/c ever since I got hold of my Thar. |
Similar Threads | ||||
| Updated Mahindra Thar in 2-3 months. EDIT : Launched with Air-Con and immobilizer! | shireeshjacobs | 4x4 Vehicles | 350 | 13th May 2013 16:24 |
| Fitting an Air-conditioner in the Maruti 800 | navdeep | Technical Stuff | 95 | 24th March 2012 17:07 |
| Mahindra Xylo : Odometer showing distance traveled with air-conditioner | mmxylorider | Technical Stuff | 12 | 26th June 2011 19:14 |
| Best ROOM Air conditioner | Max | Shifting gears | 2 | 3rd April 2006 09:52 |
