Old 25th August 2012, 07:00   #106
DirtyDan's Avatar
Thanked: 750 Times
Default Re: Tata Sumo four-wheel-drive
Any vehicle sales brochure available in the showrooms with dealers contains some vehicle dimensions. In your opinion, which of these dimensions is the most relevant to what we are talking about?
Best regards,
Behram Dhabhar
Ground clearance. Sumo does not have the best GC. About 185mm if I remember correctly. Distance to chassis is not so good....but, there could be a remedy.
Of course, a Sumo would challenge the Thar for roominess but another Jimny-like entry from Tata could challenge on the other vector, downsized and fuel efficient.
DirtyDan is online now   Reply With Quote
Old 25th August 2012, 10:39   #107
Thanked: 4,682 Times
Originally Posted by DirtyDan View Post
Ground clearance. Sumo does not have the best GC. About 185mm if I remember correctly. Distance to chassis is not so good but, there could be a remedy
Dear Ken - thanks for your reply. There can be no incorrect answers to such a question because it is the debate which is important. Please read my comment carefully, the key words are "which of these dimensions is the most relevant to what we are talking about".
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 25th August 2012, 12:35   #108
Thanked: 123 Times
I would say wheel base.
chandras1 is offline   (2) Thanks Reply With Quote
Old 25th August 2012, 14:45   #109
DirtyDan's Avatar
Thanked: 750 Times
Best regards,
Behram Dhabhar
This thread, like most threads, meanders a bit. I don't know what you mean exactly by your question but not knowing what someone is talking about does not always stop me from expressing an opinion.
On the job I'm a lot more careful. On the job I would have asked you for an amplification and clarification. This alone can get you branded a "trouble maker and bad arse". But I can afford to live dangerously here and plow ahead.
We have a standard old joke in I.T. On the first staff meeting before we even have a general idea of what the Specs are on a new project, somebody often shouts out, "Okay then, righty-right, lets start coding!"
It brings the house down. Alpha Geek humor.
Getting a user to tell you exactly what he wants you to do is one of the hardest things in I.T. The second hardest is a year later when the brown smelly stuff has hit the electrical cooling device and you have to tell the user that, although our programs don't do what he wants them to do, nevertheless, they do exactly what he told us to do.
I have some experience with this vehicle. If it was a 4x4 I would like to see improved G.C. No major dialectical inferences are purported beyond this.
DirtyDan is online now   (4) Thanks Reply With Quote
Old 28th August 2012, 19:58   #110
condor's Avatar
Thanked: 4,562 Times
Not a straight answer to pick out any single dimension, but ... can we have a lower CG, please ?
But if I were to answer DB sir's question more directly, the dimensions I would pick (in priority) are:
1. WB: increase by 100mm. Gives a balance towards better stability & not adversely affect maneuverability much.
2. Weight: 1800 kg kerb (for the Victa TCIC GX) is high. A Scorp manages it in a little more. The 1600 kg (approx) of the Sierra was a good value.
- or increase the power !!
3. GC: is not on top of my list because the 4x4 version already has better clearance than the 4x2's. But it will be good to have more clearance for the 4x2 also. For me, better GC is a good to have feature.
I have no complaints with the length / width / track etc. But a combination of 1 & 2 above will make a difference in the way this truck behaves.
Old 28th August 2012, 20:44   #111
svsantosh's Avatar
Thanked: 1,392 Times
Do anything but stay close to a CJ like BOA/App-Dep Angles.
svsantosh is offline   (1) Thanks Reply With Quote
Old 28th August 2012, 21:03   #112
condor's Avatar
OT: can I convert my TCIC 4x2 into a 4x4 ?
Old 28th August 2012, 21:10   #113
AVR
AVR's Avatar
Thanked: 512 Times
Can? Yes. Should? No.
AVR is offline   (2) Thanks Reply With Quote
Old 28th August 2012, 22:52   #114
1100D's Avatar
Thanked: 2,391 Times
The Army Sumo 4X4 benefits from bigger wheels, higher GC than their civilian counterparts.
Coming to dimensions, Sumo's Wheelbase is already shorter than Thar's,
Sumo - 2425mm
Thar - 2430mm
The rear overhang can be reduced and with it, will go, the necessity for the raised roof, thus lowering CoG.
But then, I guess the Thar man could have joined the other company that takes inspiration from the other legend, the G-Wagen and coaxed them to offer their version of the "G" with the OM611 engine they have fitted on something called ForceOne.
1100D is offline   (1) Thanks Reply With Quote
Old 29th August 2012, 07:48   #115
DicKy's Avatar
Thanked: 640 Times
, well the Bolero and Sumo both are inspired from THE Wagen.
Even then Force won't have the expertise and product launches o maybe Tata motors., but still look forwards to the next gen Trax.
DicKy is online now   (1) Thanks Reply With Quote
Old 29th August 2012, 11:08   #116
1100D's Avatar
Agreed, but, you will also agree the level of inspiration is different in the case of the Trax/gurkha platform, which is derived from the G.
Old 31st August 2012, 09:22   #117
Coming to dimensions, Sumo's Wheelbase is already shorter than Thar's, Sumo - 2425mm Thar - 2430mm. The rear overhang can be reduced and with it, will go, the necessity for the raised roof, thus lowering CoG.
Dear Anirban / Chandras - your answer is correct. Can you now build your comments around this dimension? By the way, Sumo 4WD wheelbase is 2435 mm.
Best regards,
Behram Dhabhar
Old 31st August 2012, 10:26   #118
ringoism's Avatar
Thanked: 1,398 Times
I'm here in Manali (HP) - I saw an otherwise normal-looking Sumo 4x4 taxi here a few years back (with the telltale 4x4 hubs up front), and I've been told by dubious sources that even the Spacio can be special-ordered with it now, though probably not by anyone who's actually done it. I think the above is the only non-government one I ever saw. BRO (Border Roads Organization) has one here in regular service with a local HP58 registration, white with the 207-style fender flares. Army ambulances pass through from time to time and they might even keep one in the camp up at Palchan. But they are extremely rare overall and must be a complete nightmare when it comes to sourcing spares. Perhaps even more importantly considering the thrust of this forum, a recently retired IA Brigadier-General I know says the Army Sumo 4x4's struggle a lot with climbing. That is no surprise if they're using the Victa turbo engine, which has no low-end torque whatsoever and in my personal experience has proven an immense pain to drive in the hills (though once you get up around 2500rpm and beyond the turbo lag, it's lively enough). Seems like a case of a turbo unit that is mis-sized / mis-specified for the given engine. The Sumo platform is okay... millions of taxi-wallah's can't be too wrong. Kind of rattley bodies and front suspensions can and do bend / break. Biggest trouble is that Tata knows they can keep selling millions of these soul-less vehicles regardless of whether they really upgrade it or develop it properly or not.
ringoism is offline   Reply With Quote
Old 31st August 2012, 10:33   #119
Thanked: 123 Times
Dear Sir,
I am complete novice when it comes to all this, still I think the wheel base determines or has an impact on the amount of GC needed and therefore affects the COG of the vehicle. Hence I thought this is more important.
chandras1 is offline   Reply With Quote
Old 31st August 2012, 11:51   #120
1100D's Avatar
Best regards,
Behram Dhabhar
Okay, for a start, the shorter the wheelbase, the better the breakover angle will be.
In the Sumo's case its already almost at Thar level. But then, I am not sure of the height the lowest object between the wheels (assuming that would be anyway higher than the GC).
But what the Sumo (or other Tata UV's) is plagued with are bad front and rear overhang. Something that can only be tackled by raising the body or bigger wheels (as in Spacio or the Army spec Sumo 4x4)
1100D is offline   Reply With Quote
Tata Sumo Gold - Refreshed Sumo! safari_lover The Indian Car Scene 466 5th June 2017 14:00
Ferrari Four (4 Wheel Drive) launched: Pics on page 2 theragingbull The International Automotive Scene 75 8th March 2012 13:39
SCOOP! New Tata Sumo Picture. EDIT : Now launched as Sumo Grande MillionSwords The Indian Car Scene 217 26th October 2009 20:16
Tata Sumo Victa GX IDI Turbo or Sumo Grande GX drmessiah SUVs, MUVs & 4x4s 11 20th April 2009 18:16
Repainting & "Sumo to Sumo victa" conversion. Advice needed. nitrous Modifications & Accessories 0 21st November 2005 12:57
