Old 3rd October 2011, 08:26   #61
mohang_j's Avatar
Thanked: 18 Times
Default Re: "Heart Over Mind" 2001 MM550 XD - Rebuild
Shreejesh,
Please let me know what is the issue. As i am also doing the same snorkel will help if i have to make correction. posting a pic of wip snorkel
mohang_j is offline   Reply With Quote
Old 3rd October 2011, 13:27   #62
sreejeshmp's Avatar
Thanked: 576 Times
It was a Mistake while installing the snorkel the snorkel pipe was disturbing the air flow from the Snorkel head. I cut the pipe and fitted the snorkel back It works fine without any breathing problem.
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 15th October 2011, 07:23   #63
sreejeshmp's Avatar
Thanked: 576 Times
"Heart Over Mind"  2001 MM550 XD - Rebuild-315524_230204610369120_100001387483305_592583_1211375566_n.jpg
My first Jump at Kakkabe OTR.
Old 15th October 2011, 19:35   #64
sreejeshmp's Avatar
Thanked: 576 Times
Default Update :- MM550 with Armada dash & Meter Console .
Fitted ARMADA dash and meter console
"Heart Over Mind"  2001 MM550 XD - Rebuild-295967_2292952077523_1060664399_2578612_946949928_n.jpg
"Heart Over Mind"  2001 MM550 XD - Rebuild-305397_2292953037547_1060664399_2578613_1589351015_n.jpg
"Heart Over Mind"  2001 MM550 XD - Rebuild-319514_2292953437557_1060664399_2578614_1401012853_n.jpg
Old 8th November 2011, 18:06   #65
sreejeshmp's Avatar
Thanked: 576 Times
Now time for Mechanical Modification.
Problems Found :-
1. Air Bubbles in the Radiator :-
Time to change the Head Gasket.
2. Gearbox Need a Complete Rebuild
:- I need help to Decide.
Gearbox
Option 1 : Completely Rebuild the KMT90+T18.
Option 2 : Get a Gearbox with Brog Warner Manuel TC
If I go for Option 2 what are the things I need to change and which one ?
Gearbox Options ;-
(My Usage is 60% Onroad and 40% Offroad.)
1. KMT90 + BW Manuel TC
2.BA10 + BW Manuel TC
Then I need to change the Differential to the central aligned Diff from armada/bolero/pik-up 2wd/4wd.
In this case is it possible to keep the LSD ?
If I use the BA10 BW do I need any Modifications on the Prop Shaft
etc ?
Can I retain the the 139 PCD ?
Expecting suggestions .
Old 8th November 2011, 21:59   #66
Jaggu's Avatar
Thanked: 8,693 Times
Attachment 820255
Attachment 820256
Where is the pipe ending? It should be above the slit right? so that water escapes through the passage provided at the bottom.
Also why there is a added rubber pipe given?
Image from Safari site.
Jaggu is online now   (1) Thanks Reply With Quote
Old 9th November 2011, 01:05   #67
k_shanz's Avatar
Thanked: 64 Times
congratulations Mr.sreejesh you jeep looks killer . I always wanted something like this.
k_shanz is offline   Reply With Quote
Old 9th November 2011, 19:51   #68
V-16's Avatar
Thanked: 862 Times
Shreejesh, your Jeep looks killer. Was the Armada dash a direct fit? What mods did you have to undertake to fit the Armada dash on the MM550? Do all the meters work fine?
Although it looks like it does open, is the front windscreen tiltable with this dash. If yes, any mods undertaken to ensure tiltability?
Im askig because im looking at putting an a?c on my 550 and with the Armada dash it will only be to easy as all vents etc are there.
V-16 is offline   Reply With Quote
Old 12th November 2011, 08:51   #69
sreejeshmp's Avatar
Thanked: 576 Times
Armada dash is not a direct fit It needs some cut at both sides and rear. All the meters works fine with out any mod. You need to make a hole on the dash frame for the speedometer cable.Windscreen can be opened (No mod). But the main thing is you need to increase the height of the steering road otherwise it will foul with the meter console.
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 29th November 2011, 19:45   #70
sreejeshmp's Avatar
Thanked: 576 Times
Did a short discussion with Pratheesh, Rajith, Rohan and Arka, I understand spending money to make things complicated is not a good idea . Decided to keep the KMT90+T18 Combo.
We opened the engine Head for changing the Gasket and found, First the Engine need a Rebuild .
Engine rebuild started.
Now thinking of LSD in Front Diff .
Old 3rd December 2011, 19:22   #71
sreejeshmp's Avatar
Thanked: 576 Times
Default XD3P - engine overhauling.
Hanged but will reborn like a phoenix bird.
disassembled and checked all the components.
Fuel Pump :- Lucas-TVS XD3P2A
Loaded in to My brother-in-law's CJ500D 4WD.
Which is the best Piston rings and sleeves available in market ? My mechanic told me to use IPL But its not available in Calicut.
What is the part number of MM550XD XD3P clutch & Clutch cover assembly ?
expecting Help .
- Sreejesh
Old 3rd December 2011, 21:10   #72
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Sreejesh, please use IPL pistons only
Dug this out for you.
Piston- 9420001172
Piston ring set- 9420001228,
they have a "special" purpose in XD3P engines. Also, the step is genuine, the Pressure plate looks suspect. Hope this helps.
Spike
SPIKE ARRESTOR is offline   (3) Thanks Reply With Quote
Old 8th December 2011, 23:22   #73
Jerrycan's Avatar
Thanked: 107 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
Jerrycan is offline   Reply With Quote Received Infraction
Old 10th December 2011, 23:43   #74
Jerrycan's Avatar
Thanked: 107 Times
Sreejesh
IPL Pistons and Ring Sets are Available at George Oakes, Coimbatore and Speed A Way P Ltd., Coimbatore.
T. Lingavasu is the Sales Representative of IPL. His Contact No is +919842353965, mail id vasu.iplsales@gmail.com, linga_vasu@yahoo.com.
He says the supplies were stalled during the Last 6 months , but have resumed from last Week.
Old 11th December 2011, 10:34   #75
sreejeshmp's Avatar
Thanked: 576 Times
Originally Posted by Jerrycan
Sreejesh
Thank you jerrycan,
I already bought Goetze Pistons and m&m rings. Can you tell the price of the pistons ?.
Heart over mind... ANHC wins the heart... raghu230506 Test-Drives & Initial Ownership Reports 213 13th December 2016 11:43
Jeep -Cj340. Heart over Mind beejay 4x4 Vehicles 149 14th November 2016 13:12
TATA Aria Pride 4X4 - Heart over Mind or Mind in the Right Place? EDIT : Now Sold! ACM Test-Drives & Initial Ownership Reports 322 16th September 2015 15:51
Mind Over Heart - The Corolla Comes Home! prateekm Test-Drives & Initial Ownership Reports 24 11th April 2010 17:44
