Old 11th December 2011, 19:00   #76
sreejeshmp's Avatar
Thanked: 571 Times
Default Re: "Heart Over Mind" 2001 MM550 XD - Rebuild
Got the engine from the industrial My wife's zen helping My 550.
FP Serviced.
Head welded the rusted area and Polished
Pistons getting ready to work.
Engine parts
Assembling will be done by tomorrow.
Expense up to now :.
Parts - 22K
Industrial Work-7.5K
FP service -2K
Parts Changed :-
Piston - Goetze Piston
Rings - M&M
Sleeve- SLEEVE INDIA
Engine Bearings
Timing Chain
timing chain tensioner
rocker arm shaft
water pump Assembly
Radiator thermostat valve
Gasket (3Cut)
Accelerator Cable
silencer mounting kit.
- Sreejesh
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 11th December 2011, 19:35   #77
svsantosh's Avatar
Thanked: 1,392 Times
Originally Posted by sreejeshmp View Post
Attachment 854772
could you mark the area you 'welded' and say more about it... a welded head is not typically recommended by anyone, but many mechanics guarantee its welding strength...
svsantosh is offline   Reply With Quote
Old 11th December 2011, 20:38   #78
sreejeshmp's Avatar
Thanked: 571 Times
There are few rusted areas at the border of water flow path so I filled it by aluminum welding and polished .that will increase the gasket life.
- Sreejesh
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 24th December 2011, 22:43   #79
sreejeshmp's Avatar
Thanked: 571 Times
Engine overhauling done.
LSD in front .
Old 25th December 2011, 21:26   #80
sreejeshmp's Avatar
Thanked: 571 Times
Did a test to check the performance .
sreejeshmp is offline   (4) Thanks Reply With Quote
Old 26th December 2011, 10:33   #81
ex670c's Avatar
Thanked: 1,799 Times
Hi Sreejesh,
A simpler test would be to jack up all 4 Wheels a let the vehicle idle in 4wd-Lo 1 st Gear.
All 4 Wheels should rotate in the same direction.
What about emergency spares, just in case the welded front axle snaps during an OTR?
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 27th December 2011, 20:55   #82
twistwrist's Avatar
Thanked: 20 Times
Originally Posted by ex670c View Post
Hi Sreejesh,
Arka,
Yes,its very practical test for LSD differential. Once had the 550 roll forward while checking the speedometer with a new cable.
twistwrist is offline   Reply With Quote
Old 25th February 2012, 14:26   #83
sreejeshmp's Avatar
Thanked: 571 Times
After The engine rebuild The only thing makes sound in my jeep is the Gearbox so The rebuild starts.
1,2&3 Gear need to replaced TC Counter shaft Needle bearing Everything except the Gearbox&TC case need to changed. But I am sure Once I did it in the proper way with proper Original Parts It worth doing it.
- Sreejesh
Old 25th February 2012, 18:53   #84
svsantosh's Avatar
before buying the parts do the math - it may be better to buy a used GB than spend on new Gears.
Old 25th February 2012, 19:18   #85
sreejeshmp's Avatar
Thanked: 571 Times
Thanks Santhosh. But Buying a Used GB is again a problem because I don't know the condition of that Gearbox. So I Decided to rebuild it from the scratch Only taking the Best parts which is available to pick from the gearbox . I think It will be around 10-15K for the parts only.
- Sreejesh
Old 1st March 2012, 19:50   #86
sreejeshmp's Avatar
Thanked: 571 Times
Bought The Parts for the Gearbox.
MainShaft
1st Gear
2nd Gear
3rd Gear
All the Bearings
TC Counter Shaft,Bearing
and the pins,sir clips,etc.
Total Cost of the parts - 14600.00
Partes Need to Purchased - Clutch Cable , Original Clutch Cover assy for the Stepped flywheel.
Changed parts of the Main Gearbox
Complete New Assy.
Old 10th March 2012, 17:15   #87
sreejeshmp's Avatar
Thanked: 571 Times
Changed the Flywheel in to old bolero Xd3P Flywheel.
Release bearing hub grinned to increase the Release bearing play to suit with the new fly wheel.
Old Gears..
Old 12th March 2012, 12:39   #88
Rajith's Avatar
Thanked: 391 Times
Dear Sreejesh,
I would like appreciate your willpower and dedication in making your machine to its core perfection in factory specs.
Would love to see this with NGCS , OKBJ and a wider axle boss.. please do it.
Rajith is offline   (1) Thanks Reply With Quote
Old 12th March 2012, 23:18   #89
Jerrycan's Avatar
Thanked: 107 Times
Attachment 900567
Old Gears..
Does that mean it is not the original stepped flywheel. Are you using the Same Pressureplate / Cover assembly ?
Jerrycan is online now   Reply With Quote
Old 13th March 2012, 07:54   #90
sreejeshmp's Avatar
Thanked: 571 Times
yes Boss. I changed to Bolero xd3p Old model Fly wheel. Its without the step but fittings like bolt pattern are same as the stepped fly wheel so I am using the same Pressure plate.
sreejeshmp is offline   Reply With Quote
Heart over mind... ANHC wins the heart... raghu230506 Test-Drives & Initial Ownership Reports 213 13th December 2016 11:43
Jeep -Cj340. Heart over Mind beejay 4x4 Vehicles 149 14th November 2016 13:12
TATA Aria Pride 4X4 - Heart over Mind or Mind in the Right Place? EDIT : Now Sold! ACM Test-Drives & Initial Ownership Reports 322 16th September 2015 15:51
Mind Over Heart - The Corolla Comes Home! prateekm Test-Drives & Initial Ownership Reports 24 11th April 2010 17:44
