Old 10th April 2012, 16:00   #91
sreejeshmp's Avatar
Thanked: 571 Times
Default Limp Riser for My MM550
Got a set of Limp Riser From Our vijay.. Decided to install it My self.. I love DIY..
Toos..
Drilled holes on Glass Frame & Fender
Fixed the mounts..
Done it..
sreejeshmp is offline   (3) Thanks Reply With Quote
Old 10th April 2012, 16:30   #92
svsantosh's Avatar
Thanked: 1,392 Times
Default Re: "Heart Over Mind" 2001 MM550 XD - Rebuild
Sreejesh - nice DIY - I love the joy of DIY;s
PS - how much did the army type pintle hook holder (4mm Plate) on the front bumper cost you? where did you get it? Isnt it designed for the rear 550 bumper?
svsantosh is offline   Reply With Quote
Old 10th April 2012, 18:00   #93
sreejeshmp's Avatar
Thanked: 571 Times
Thanks Santhosh.. Yes its the Rear Plate of post 2001 model 550XD. Its available at Moovattupuzha Kerala 1500.00.Let me check Calicut also it may available some times..but the price will be little more ..
- Sreejesh
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 10th April 2012, 18:41   #94
lifeat100k's Avatar
Just loved the way you have built your jeep. Very tastefully done & the colour is super! My uncle in bangalore had a grey MM540 hard top which was the only one in that part of bangalore that time. The snorkel is very well finished.
I know this might be amateurish, but just wanted to know if MM550 available for the public on made-to-order basis? And whether it had an all time 4x4?
lifeat100k is offline   Reply With Quote
Old 11th April 2012, 07:45   #95
sreejeshmp's Avatar
Thanked: 571 Times
MM540/MM550 is no longer available as a brand new vehicle. You can Buy Thar CRDe / Di. There are few difference between civilian MM550/MM540 and Army MM550DX. Ex-army MM550DXs are available through some army Jeep/Scrap dealers and few restores who makes running condition jeeps and makes money
All the models of MM 4WD Jeeps came with a manuel/Electronic 4WD transfer Case not All time 4x4. I hope you got some idea . Go through the technical section under 4x4 section you will get lot of valuable information regarding 4x4s Jeeps,Gypsy etc..all most all questions about Jeeps are answered buy the Tbhpians in different restoration threads go through that you will be bitten by the BUG.
- Sreejesh
sreejeshmp is offline   (2) Thanks Reply With Quote
Old 11th April 2012, 17:26   #96
lifeat100k's Avatar
- Sreejesh
Thank you very much.
Old 12th April 2012, 22:41   #97
sreejeshmp's Avatar
Thanked: 571 Times
Default Custom Steering Damper for MM550
Installed a Steering Damper for my Jeep yes this also a DIY.
Old 13th April 2012, 07:37   #98
svsantosh's Avatar
something is not right, post more pics from a fronter/wider angle please... is the 1 end on the axle housing? why?
Old 13th April 2012, 08:23   #99
sreejeshmp's Avatar
Thanked: 571 Times
Snthoah Check this..
The Mountings.
Expecting open opinion and suggestions for improvement .
there is a particular reason behind this (fitting on axle tube will post once I got the disadvantages) I need to test on trials.
- Sreejesh
Old 13th April 2012, 12:19   #100
svsantosh's Avatar
when your right wheel is flexed in and left wheel inside a rut - this setup will not allow the shock to turn/rotate on axis and will break the mounts, thats why the company setup is on the chassis - let me post a pic...
scratch that ^
This setup will still work with a SMALL but IMP mod - on the axle housing side mounting, instead of the bolt being north-south, make a juggad so that bolt is horizontal (front back) - in that case the shock will pivot freely when the axle goes up and down - hope i am able to be clear here...
Sorry head is fuzzy - scratch #2 - go back to drawing board with #1 - in your current setup - all road vibrations, axle movements will be translated to this new damper unnecessarily - thats why the chassis-to-tierod connection is good and free from any unwanted shocks from bad roads... with me?
Old 13th April 2012, 21:15   #101
sreejeshmp's Avatar
Thanked: 571 Times
scratch that ^
Please post the pic I didn't understand .
In this case both the tie rod and the axle tube moves up and down together right ? that means both the end of shock will move up and down with respect to the up and down movement of axle tube and tie rod. In MM OEM set up one end is fixed to the chassis so the other end should pivot freely when the axle goes up and down but in my case both ends moves up and down. and its the OEM set up for CJ7 - Wrangler
In my case the problem is the sudden return of steering in off road because of the front LSD I know I can't do any thing to prevent that steering behavior. but by this set up I can prevent a little of that immediate return before it gets in to the steering that means the shocks gives a support to the tie rod and It works too I tested in real life situations and want to test in offered to check the reliability.
- Sreejesh
Old 10th May 2012, 20:41   #102
sreejeshmp's Avatar
Thanked: 571 Times
Finally All the Mechanical Works are done.
Changed the Clutch Cover Assy,Clutch Plate.. Fixed the rear Door with new Original Hinges From Thar CRDe .
Old 12th May 2012, 19:23   #103
svsantosh's Avatar
how much did the cluch cover assy and friction plate cost you? its for a XD3P right?
Old 13th May 2012, 11:37   #104
dhanushs's Avatar
Thanked: 4,119 Times
Sreejesh, how is the performance of front LSD, in any case, have you felt it could be manually controlled lockers?
Please share.
Old 13th May 2012, 17:58   #105
sreejeshmp's Avatar
Thanked: 571 Times
It is the normal Clutch assy & pressure plate used in armada & old Bolero. but not the original one used in MM550 XD. it costs me 3900.00 with tax original MM from authorized dealer.
Please share.
For the money and effort front LSD is the cheapest option if you want more traction. But is really hard to keep the jeep on track. But on rock it performs like a dream but in sticky mud/slush it Drives the jeep.
Heart over mind... ANHC wins the heart... raghu230506 Test-Drives & Initial Ownership Reports 213 13th December 2016 11:43
Jeep -Cj340. Heart over Mind beejay 4x4 Vehicles 149 14th November 2016 13:12
TATA Aria Pride 4X4 - Heart over Mind or Mind in the Right Place? EDIT : Now Sold! ACM Test-Drives & Initial Ownership Reports 322 16th September 2015 15:51
Mind Over Heart - The Corolla Comes Home! prateekm Test-Drives & Initial Ownership Reports 24 11th April 2010 17:44
