Old 9th February 2009, 15:39   #76
DirtyDan's Avatar
Thanked: 787 Times
Originally Posted by Red Liner View Post
If I get a 4wd cheaper than a 2wd, I am not going to say no.
I would also be quite keen on to know on retrofitting the Power Steering option. Can someone throw some light on this?
I am pretty sure it's doable especially in Bangalore where you have some good mechanical support. There are a few ways of going about it. One is to take the PS stuff out of a wreck, say a Pajero or up market vehicle. Another is to go with Mahindra parts since they have Boleros and other vehicles with PS. Another way is the use of after market parts such as Koyo out of Japan. This has good reviews on this forum.
Old 9th February 2009, 16:45   #77
Red Liner's Avatar
Thanked: 1,520 Times
Thanks Dan. Going with Mahindra parts would make a lot more sense, simply so that they can be fixed later to perfection, and spares are never an issue with Mahindra. hell, I can order the whole PS unit through the dealer and set it up. If the Invader came with PS (the AC add on is not tough), I think it will get a lot of buyers.
Red Liner is offline   Reply With Quote
Old 10th February 2009, 11:54   #78
Red Liner's Avatar
Am cross posting my query from here: http://www.team-bhp.com/forum/what-c...ml#post1165320 in the event more people whose suggestions I expect are lurking on this thread.
Dan, thanks for your PM.
Old 11th February 2009, 21:35   #79
Blue Thunder's Avatar
Thanked: 336 Times
Lightbulb
...to wait for the Tata Xenon launch to see what price point they launch it at. I saw the vehicle and it is years ahead of the other 4 Door Indian pick ups.
I am sure the price will also be light-years ahead of other pik-ups .
Blue Thunder is offline   Reply With Quote
Old 11th February 2009, 22:04   #80
4x4addict's Avatar
Thanked: 2,681 Times
They launched the Sumo Grande at a decent price. I think given that these two vehicles share 90% of the chasis power train and similar amount of sheet metal, I don't see any reason to price the Xenon far higher than the Grande. Except ofcourse the additional cost of the 4WD system.
4x4addict is offline   Reply With Quote
Old 11th February 2009, 22:16   #81
Red Liner's Avatar
I expect the xenon to be pegged at between 9 and 10l. Now dan, the xenon is 16 feet long. How long is the camper? Are you serious about hauling a long load bed behind you and still be a nimble little mountain goat?
Old 12th February 2009, 09:58   #82
Thanked: 336 Times
... I don't see any reason to price the Xenon far higher than the Grande. Except ofcourse the additional cost of the 4WD system.
...and the lower volumes, and niche-market strategies etc. etc.
Old 12th February 2009, 11:19   #83
Spitfire's Avatar
Thanked: 709 Times
The point is it wont be "cheap".
Spitfire is offline   Reply With Quote
Old 21st November 2009, 11:28   #84
fireblade007's Avatar
Thanked: 57 Times
The invader 4x4 ( mdi 3200) price in thrissur, kerala is 5.70 lakhs on road.
fireblade007 is offline   Reply With Quote
Old 3rd April 2010, 14:19   #85
Thanked: 12 Times
Can anybody please give me some insight into the type of axles used on a bolero invader?
conjon is offline   Reply With Quote
Old 3rd April 2010, 14:32   #86
ex670c's Avatar
Thanked: 1,840 Times
Default 30 Spline
Hi Conjon,
The current M&M Bolero Invader is
Dana 44 30 Spline 1 Piece SFRA
I'm guessing the older ones with XD3P had a Dana 44 19 Spline FFRA.
Arka
Old 3rd April 2010, 16:27   #87
Thanked: 12 Times
Thanks Arka.
I presume mine is a FFRA because its a 2004 mdi 4wd (non t/c).
Old 4th April 2010, 11:32   #88
ex670c's Avatar
Default FFRA Hub
Thanks Arka.
Hi Conjon,
Post a Pic of your Rear Wheel Hub, if it has a projection with 8 Bolts and 2 Pins its is FFRA.
Pic of My FFRA Hub from a Bolero 53" FFRA with Armada 98 Hub. (pic is with out Axle)
Arka
Old 4th April 2010, 14:28   #89
Thanked: 12 Times
Thanks again Arka.
Currently I'm not in india so cannot post a pic of my invader.
I shall put a photo of a similar looking invader.
This is the closest that i can find.The rear hub looks same on my vehicle as well.
Is it possible to change the rear axle to FFRA from the mahindra pickup truck if the invader is not FFRA?
Old 5th April 2010, 10:28   #90
ex670c's Avatar
Thanks again Arka.
Hi Conjon,
The Above 2 pics shown the 30spline Dana 44 1 Piece SFRA.
It is possible to convert(replace) the SFRA to FFRA, You will have to swap in a Bolero Rear Axle.
1) Check the Diff.Ratio and change if needed.
2) Check the Diff Pumpkin Off-Set and switch the Arms around if needed , depends on T-Case Output.
3) Align the Diff. Pinion Angle.
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
Mahindra Invader: Why is it not a 4x4 favorite DRC 4x4 Vehicles 33 28th September 2009 15:44
Mahindra Bolero Invader 4x4 - To buy or not to buy ?? Sabareesh SUVs, MUVs & 4x4s 11 3rd October 2008 11:29
4WD in bolero invader mandeep 4x4 Vehicles 4 11th May 2007 17:56
