Old 1st August 2011, 20:48   #1
catchkumar's Avatar
Thanked: 44 Times
Default Project Land Rover
Hi All,
I have paid advance to pick the Land rover of pictures below -
The vehicle is in the North & by mid month it should be in Bangalore.
My plan is to cut the chassis & make it look like a Defender 90.
I am a complete newbie to the technical side of things.
Any help / suggestions & advices will be highly appreciated.
Thanks & regards,
Kumar
catchkumar is offline   Reply With Quote
Old 1st August 2011, 21:49   #2
Thanked: 661 Times
Default Re: Project Land Rover
This is a series III, the 109 wheelbase one.
Oh! boy its in pretty battered state.
However old maybe, cutting LR chassis is not an easy affair. Also you need a very competitive MIG welder to wield the body work, as its aluminum all the way.
What engine does it have.? how much did you paid for it.
If you need technical data you can PM me your mail will send you stuff in pdfs.
PS: why don't you create a four door crew cab instead. I have similar plans for a LR but have lot of other works at hand currently. hence no time for hobbies.
Old 1st August 2011, 21:58   #3
IQBAL VEERJI's Avatar
Thanked: 291 Times
Originally Posted by catchkumar View Post
Hi All,
Thanks & regards,
Kumar
Our most respected Landy lover, restorer,know every things about Landy is our beloved Sudarshan ji from pune.
He will guide you in all respects and will also help you to solve many problems you will aalso face problems with parts which will be solved by him .He has a landy in pune. Am I right sudarshan ji?
Last edited by GTO : 2nd August 2011 at 14:51. Reason: No need to quote images please
IQBAL VEERJI is offline   Reply With Quote
Old 1st August 2011, 22:08   #4
catchkumar's Avatar
Thanked: 44 Times
Hi Sir Alec,
It has a Parkinson diesel engine.
The gear box is missing hence a MM550 gearbox with 4x4 transfer case is put in the load bay so.. not fitted on the vehicle.
I would need all possible help & pdf's to bring this dream back on track.
I have seen a video of complete restoration of a 100" wheelbase range rover to defender hybrid.
I don't mind a 100" as well but a 90" will make it a dream come true.
I have sent a PM to you with more details of this vehicle.
Sudarshan sir has also mentioned that its a very very difficult job to shorten the chassis.
I have started to wonder if am doing the right thing by picking this vehicle now.
Please advice.
Kumar
Old 1st August 2011, 23:03   #5
Thanked: 661 Times
Hi Sir Alec,
Please advice.
Kumar
So its not in an original state. i suspected that
i have seen the video. It a conversion of 100 inch Range Rover to Defender. and not a series to defender. which is unique in its own right as Defender comes in three wheel bases 90, 110, 130 but not in 100.
Believe me you will never go wrong when you pick a LR. They say 75% that ever came out of Solihull are till on roads". Its the question of time and patience that you have to spare.
Like i said making it into a crew cab would be a viable option. With big bull bars at the rear. i am planing to do the same.
Some examples.
Name:  lr crew cab.jpeg
Name:  lr crew cab1.jpeg
Name:  lr crew cab2.jpeg
Old 1st August 2011, 23:05   #6
svsantosh's Avatar
Thanked: 1,449 Times
PERKINS, you mean?
Well, when it comes to jeeps, landies, jongas - one can never go wrong. Your spirit is commendable...
Beware, this project can really give you Parkinson's!!! You are a sucker for jeep trouble, if you get my drift...
svsantosh is offline   Reply With Quote
Old 1st August 2011, 23:07   #7
Thanked: 661 Times
no there is a less heard company Parkinson.
Old 2nd August 2011, 06:55   #8
Thanked: 826 Times
Exclamation Re: Project Land Rover
Originally Posted by IQBAL VEERJI View Post
Our most respected Landy lover,== Am I right sudarshan ji?
Sirji , thanks for the compliments , this is more than I actually deserve , thanks again .
dont put that engine on the landy Its an old timer P 4 engine which used to come with the Mahindra FC , its a load carrier engine very noisy & much vibrations , also you will need a different bell housing to go with mm GB
Options
1) give the engine back to dealer & get rebate
2) get a XD 3 P engine 2400 cc approx ( peugeot --larger than the XDP 4.90 --2112 cc engine ) this will suit with the MM gear box
3) get an original LR engine + Gearbox ( difficult to find )
Have seen it also , see it again . Check out the workmanship involved , its not that easy to get it done here by ' our ' mechs .This was done abroad (UK ) where they get any part easily
This IS THE BEST that can be done with rhis vehicle
PERKINS, you mean?
A P4 engine used to go on MM s FC . Load carrier very rough engine
My Suggestions ( if its your first L R & you are Novice )
1) Forget the cutting & re welding the chassis , alterations with the body is another -----
2) get rid of the P4 engine , get a peugeot along with KMT 90 gear box & T 18 transfer case will be easy for parts & all
3) crew cab conversion is the best in current scenario ( as suggested above )
A Landy chassis is a box section & its not uniform in shape like the old Jeep C section so repairs arnt easy will need a very very expert hand + a workshop that has the necessary infrastructure & most importantly ' Interest & time for you --- you will get ripped
The Body is aluminum , with rivets all over Very tricky to weld & get in to original shape & strength if damaged
Sudarshan
Sudarshan is offline   Reply With Quote
Old 2nd August 2011, 13:05   #9
Thanked: 826 Times
for reference the chassis drawings of 109 " wheel base Landy , tell me where to cut , to reduce the length
this is a 88 " wheel base chassis ( for comparison with the 109" )
Sudarshan
Sudarshan is offline   (1) Thanks Reply With Quote
Old 2nd August 2011, 23:35   #10
catchkumar's Avatar
Thanked: 44 Times
Hi All,
Thanks a lot for all your valuable inputs.
Am in a BIG state of confusion now my main objective to pick this LR was to convert it into 90" WB & my biggest mistake was not to have checked with the experts here like sudharshan ji, Sir Alec & all the others who are a treasure trove on land rovers.
I wanted a SWB so that i can use it as a daily drive too & the 110" is practically an over kill for this purpose in Bangalore hence if i cant cut it short then i will have to shelve the plan sadly.
What do i do now is a big question mark which i guess i will have to sort out between my heart & mind.
There was only 1 person who said the chassis cut job is doable in the right hands & my only last hope is to see how feasible this would be & discuss the costs involved in case i decide to do it.
The last thing i can do but sadly is to let somebody who is a LR enthusiast & wants to have a series 3 to pick it.
Guess its going to be a week of decisions & discussions with a lot of people.
Thanks sudharshan sir & sir Alec for your inputs - I will update this thread & send a PM to all updating the plan of action.
Kumar
Old 3rd August 2011, 13:29   #11
Baburajs's Avatar
I also think that cutting the chasis and making it to 90 may be an idea that may not be practical because of the lack of skilled man power and parts in this part of the world .
Best thing to do it to wait for getting one( i know it may take forever ) or get it and keep it the way it is . As Sudarshan said get a good XD3P engine ( or a Scorpio turbo engine - dont remember the technical name ) and a compatible gear box (BA-10 will be good ) and transfer case and rebuild it as it is .
Babu
Baburajs is offline   Reply With Quote
Old 6th December 2011, 16:50   #12
voodoochild's Avatar
Thanked: 175 Times
Hello catchkumar,
Sorry to bump the thread, but what's the status of the project? Seems like quite a tedious project, but very very interesting!
Lets hope you've had some significant breakthrough.
Rahul
voodoochild is offline   Reply With Quote
Old 24th December 2011, 10:32   #13
binu balan's Avatar
Thanked: 11 Times
Thumbs down Re: Project Land Rover
Originally Posted by voodoochild View Post
Hello catchkumar,
Its scraped due to the complications and reliability of a cut chasis
binu balan is offline   Reply With Quote
Old 24th December 2011, 11:58   #14
Anupam's Avatar
Thanked: 38 Times
Hi All,
Hi CK, did you finally pick the car? if not then can you please PM the details
Anupam
Anupam is online now   Reply With Quote
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 38 4th May 2011 17:06
Land Rover To Mark 40th Anniversary Next June With The Unveiling Of The Range Rover L AyAn! The International Automotive Scene 4 2nd September 2009 02:09
Land Rover Unveil 2010 Range Rover Sport with all-new 510hp V8 Engine hanmust The International Automotive Scene 2 8th April 2009 20:53
Land Rover unveil the LRX - to be badged Range Rover Tstag The International Automotive Scene 26 14th March 2009 16:17
