Old 10th October 2011, 07:40   #1
Default 1961 CJ 500 a.k.a High Roller
On the 20th of sep, me & my friend were driving in a customers Willy's, after driving it for a while he fell in love with the jeep & that's where this story begins... 23rd sep morning he calls me & as usual he drops by my garage telling me we need to search for a jeep as he is interested to pick one up immediately, after a few calls n checking out 2 jeeps we got to know there was a good condition CJ500 which was in our budget by 2 p.m we took off towards kanakpura road to check the jeep after driving it for a few min's we decided to close the deal, paid the token amount & off we were towards my garage... We took almost 2 hrs to reach from kanakpura road to HSR once we got back to the garage we asked my mech to check the vehicle & got to know the engine & GB was excellent but the body was a rust bucket, any which ways we were ready for that. What can you expect from a 61 model used by forest rangers, the next day being a Saturday & no much work happening on this day so we decided to chop all the un-necessary rods being welded inside to hold on to the soft top. Day 2 n the vehicle was looking like a jeep, as sunday was a holiday & no much work we decided to relax & monday morning we headed to J.C road to a friends shop & purchased 5 Gypsy rims & tires. Have attached a couple of pics the way how the vehicle was & is now....
madpsyntist is offline   Reply With Quote
Old 10th October 2011, 17:41   #2
BANDHAV's Avatar
Thanked: 263 Times
Default Re: 1961 CJ 500 a.k.a High Roller
This could be a very good base car, hope to see it turn out into a great off roader and great looker.
BTW, what are those tyres? what specification? Looks neat.
BANDHAV is offline   Reply With Quote
Old 10th October 2011, 21:15   #3
Shubz's Avatar
Thanked: 985 Times
Can you please post pictures of the engine bay? Also who is your mechanic etc?
Shubz is offline   Reply With Quote
Old 11th October 2011, 17:07   #4
Thanked: 18 Times
Congratulations on your jeep.But it is not a CJ500 and definitely not 1961.Its a right hand drive with an extra long body.most probably 101 inches.From what is visible in the pictures the engine is a Perkin P4. CJ 500D came with the international diesel engine.This seems to be the ones mahindra made in 1983-85 for a short while.
hps aulakh is offline   Reply With Quote
Old 11th October 2011, 17:32   #5
mitrajdeep's Avatar
Thanked: 90 Times
I love the tires. They change the whole appearance of the Jeep.
Please share the details.
Regards.
mitrajdeep is offline   Reply With Quote
Old 11th October 2011, 18:40   #6
Thanked: 4,673 Times
Originally Posted by hps aulakh View Post
Congratulations on your jeep. Its a right hand drive with an extra long body, most probably 101 inches. From what is visible in the pictures the engine is a Perkin P4. CJ 500D came with the international diesel engine.This seems to be the ones mahindra made in 1983-85 for a short while.
Dear hpsaulakh - this is a CJ500D 91" wheel base 4 Wheel drive vehicle but with 51" wheel track, Iran type axle and Iran fuel tank below the body. 101" wheel base will have a 10" separate piece between the front and rear body panels. Perkins P4 engine is correct, it could also be Cooper MVC4 made in Satara, a copy of the Perkins. The original Perkins engine was painted in shining blue color, the MVC was shining black. Axle ratio will be 4.27:1. One of the front axle shafts is not there in the hub. Axle spike arrestor must be fitted and operational, otherwise the front axle will touch the engine sump under articulation of 99 mm. As such a vehicle always existed with 48" wheel track axle only and not with 51" Iran wheel track, (there was no engineering BOM, meaning Bill Of Material), this seems to be an outside job, or it can also be one of our ex R&D Kandivli vehicles, sold in auction. We used to make numerous non-standard prototypes for R&D piurpose, most of which did not make it to commercial production for various reasons. . Also, it can never be 1961 as 91" wheel base did not exist in 1961. The vertical dimension of the 1961 CJ3B was less than that of the CJ500D. This chassis front is classical CJ500D and not CJ3B. The body dash panel is post 1980. I worked on the taper panel design in 1981 as a junior engineer in Kandivli with metal finishers Mr.Shantaram and Mr.Raghunath, mentored by Mr.Winstod D'Souza who headed the body shop at that time. We made the dash panel of RHD vehicle common across engine options. Tubular side footstep was designed in 1983.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (3) Thanks Reply With Quote
Old 11th October 2011, 19:04   #7
@ Bhandav the tires are Thailand make (Deestone) 31 10.5 15. AT.
Old 11th October 2011, 19:06   #8
Cart Wheels in H.S.R Layout..
Well the confusion what i had is the same on the RC it says Willy's owned by the forest department registered in 1961, The engine is an International Harvester ones used in tractors.
Old 11th October 2011, 20:49   #9
Shubz's Avatar
Thanked: 985 Times
Best regards,
Behram Dhabhar
DB saab - Greetings! Good to see you active on this forum again! Very good information above. In all this where does "1961" fit in then?
Old 12th October 2011, 10:57   #10
Thanked: 18 Times
DB sir thanks for all the info.I thought that P4 or Cooper came in the 101" chassis.Wasnt this engine too heavy for a jeep,and what was the rationale of using it instead of the international engine. regards, @ Madpsyntist, DB sir has clarified everything.
Old 12th October 2011, 11:19   #11
Shubhendra's Avatar
Thanked: 1,178 Times
Don't want to dishearten you, but it may be a case of 'Different paper - Different Jeep' which is very common. Verify Engine & chassis number mentioned in RC with Jeep to make sure everything is in order.
Shubhendra
Shubhendra is offline   Reply With Quote
Old 21st October 2011, 07:12   #12
Shubhendra
Sorry for the late reply Shubendra sir, i got the documents 2 days ago n checked them the Chassis # & engine # match but the RC book states its a 1961 Willy's MB, Now i also have another doubt the reg num on the rc is what is on the vehicle now but the FC done is for a different registration & that clearly says 1983 i am confused here can any one help me out????
Old 21st October 2011, 18:18   #13
Shubz's Avatar
Thanked: 985 Times
Something surely is amiss. What is the endorsement on the RC? Petrol? Diesel?
Diesel - then 1961 is in doubt.
Petrol - then a diff engine has been plonked and papers adjusted accordingly.
Sir - in no way trying to intimidate you. Just voicing opinion. Please get things verified before parting with all of the money agreed upon (that is if you still haven't)
Old 22nd October 2011, 05:35   #14
Sir it says petrol, but the guy who sold me the vehicle he has endorsed the diesel engine. I am still waiting for a couple more documents from him once I get it I will have a clear pic, in the mean while could you please give me your e-mail id so I can send you a copy of the documents so you can clarify my doubts.
A Day with a Scheid Road Roller SirAlec Commercial Vehicles 31 22nd February 2011 22:57
Any roller skaters around Indiranagar / C.V.Raman nagar in bangalore? mjothi Shifting gears 12 18th August 2010 14:37
Xenos Auto Power Windows Roller invincible7 Modifications & Accessories 10 3rd April 2009 22:41
Roller blinds for innova's rear window Somashekar.B Modifications & Accessories 5 26th February 2009 14:53
Roller Bench test for Cars mithun Technical Stuff 2 13th March 2006 06:29
