Old 28th October 2011, 08:38   #16
mohang_j's Avatar
Thanked: 18 Times
Default re: '93 MM540 - The adventure begins. EDIT : 4x4 conversion!
Sriny
Congrats, Jeep looks good. please let me know the seller details. You can PM me. I may have some details to share.
mohang_j is offline   Reply With Quote
Old 31st October 2011, 21:43   #17
Thanked: 62 Times
Welcome to the jeep club and congrats on getting a neat mm540 a quite capable and mean machine and good luck restoring it .
A word of caution though as often pointed out by many jeep enthusiast ,go for only whats require ,I mean never go whole hog .One needs to get a feel of the jeep then start work on it.
You are doing the right thing by starting with the tinkering work.
regards
Praveen singh
blueblooded is offline   Reply With Quote
Old 1st November 2011, 14:59   #18
sriny_blr's Avatar
Thanked: 49 Times
Thanks BHPians, Mohan and Praveen singh for welcoming to JEEP thingie!
sriny_blr is offline   Reply With Quote
Old 2nd November 2011, 18:08   #19
sriny_blr's Avatar
Thanked: 49 Times
Guys,
It seems the tinkering work is nearly completed, says the Mechanic!
Waiting for installing the Windshield frame. My bro paid some advance for the mechanic to buy the same from around JC Road. He may buy install in a day or two.
The Hart top frame is removed as instructed to mechanic.
waiting for a NEW Top! DAMN still awaiting for the Registration No, which is still in progress!
List of things to do (with expected cost) before On Road Test!
1. New Battery - PZ 900 MF ~ 5300
2. Soft Top ~ 5500
3. Engine Oil: ~1400
4. Air Filter: ~350
5. Diesel Filter: ~150
6. Oil Filter: ~300
7. Greasing all four hubs
Old 2nd November 2011, 18:15   #20
sriny_blr's Avatar
Thanked: 49 Times
Sorry for Back to Back post, but I was unable to upload the PIC for unknown reason!
One question guys - There seem to be some kinda support missing for the back seat bottom supporting rods, Any clues?
'93 MM540 - The adventure begins. EDIT : 4x4 conversion!-img0038a.jpg
Old 3rd November 2011, 11:55   #21
jeeva's Avatar
Thanked: 527 Times
^^ No supporting rods come there.
Just two rubber bushes. Get two pairs of Bolero's stabilizer bar bushes. That will do.
And, why does the body appear to be tilted. Are they replacing the body mounting bushes too?
jeeva is offline   (1) Thanks Reply With Quote
Old 3rd November 2011, 12:05   #22
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
^^ Support rods are usually found near the end of seat overhangs (45-45" seats).
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 3rd November 2011, 13:23   #23
dhanushs's Avatar
Thanked: 4,117 Times
Originally Posted by sriny_blr View Post
2. Soft Top ~ 5500
4. Air Filter: ~350
6. Oil Filter: ~300
The above list is what I did to my vehicle. You might also want to add, checking the bearings, and recamber the leaf springs, and changing the bushes, if needed.
Also, what did you do with the HT?
Umm.. in my Jeep, there is an extra rod along the middle, and a couple of bushes. But everything else remains same.
Old 3rd November 2011, 13:49   #24
Thanked: 757 Times
^^ The one shown above is not an OE seat AFAIK, the backrest and frame looks different.
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Old 3rd November 2011, 16:28   #25
ex670c's Avatar
Thanked: 1,799 Times
Hi Spike,
These Rear Sets are pre-550 design. They are very good at shaking loose and rattling.
These were even used in the Earlier CJ500Ds.
Arka
Old 3rd November 2011, 17:45   #26
sriny_blr's Avatar
Thanked: 49 Times
Hi Jeeva, May be the photo is not doing justice!
Will find the bushes and install the same. Thanks
Spike
Thanks Spike!
Attachment 836465
Hi Dhanush; That is indeed a cut+paste of your list! As posted earlier Iam closely following your thread to get the JEEP on track for run in condition first !
Noted on Leaf springs;
Hard top - will be in safe storage for now!
Old 13th November 2011, 23:55   #27
sriny_blr's Avatar
Thanked: 49 Times
Hi All,
Got the new regn. number. Tinkering work completed, All Mechnaicals done and jeep is now in running condition.
Oil Filter - Rs.165
Diesel Filter - Rs. 185
Engine Oil (6 litres) - Rs.1410/-
Grease - Rs.125/-
Hub Greasing - Rs.350/-
Oil Servicing - Rs. 200/-
Day one after mechanicals took a round within city for about 50kms, noted the following :
1) Front wheel Wobbling - Wheel alignment done, however we asked him to do the wheel balancing, but guy said the rating is 145 & 175 which was abnormal hence he suggested/recommended that tyres need to be changed. To our surpise all the tyres looks good, but after going thro' old threads and found out the following :
Originally Posted by harjeev
I refused and said that the tyres I will take, the manufacturing date should under any circumstance not be older than a year. I am still waiting, though he has promised me tyres withing this week.
Do the year of the tires really matter? They are just a few years old and have not been under the weight of a parked vehicle to get deformed
Originally Posted by IronWolf
Do the year of the tires really matter? They are just a few years old and have not been under the weight of a parked vehicle to get deformed.
Of course there is a problem. Rubber is an elastomer and will change its properties when exposed to air, heat and other factors, even when not in use.
The tyre will be degraded and safety will become an issue. The rubber often hardens and the steel inside them will corrode making them dangerous on the roads
Firoz
For now planning to use the same tyres for some time. Meanwhile need a recommendation on suitable tyres with no / or minimum modifications.
2) Noted minor oil leak from Transfer case (hope, but not sure) - planning to get the oil seals and other stuff checked by mechanic
3) Temparature guage - Throughout the day the guage will be around 80, however when the headlight is on it will bounce to 120 (suspect the guage may be fault).
Day 2:
Had been on a long drive (around 225 kms) found exhaust leakage and got it welded from a road side mechanic.
On our return journey we found couple of Garages modifying jeeps exclusively for borewell installations. These modified jeeps will be used to drop/lifting the GI pipes & motors. Most of the jeeps are sourced by these people in and around Bangalore.
upon hunting with few of these garages able to find a back door for our MM540 and procured.
'93 MM540 - The adventure begins. EDIT : 4x4 conversion!-mm540.jpg
Old 14th November 2011, 08:01   #28
sreejeshmp's Avatar
Thanked: 571 Times
What is the plan for 4wd conversion ? Which GB TC combo you are planning to use ?
sreejeshmp is offline   Reply With Quote
Old 14th November 2011, 09:36   #29
sriny_blr's Avatar
Thanked: 49 Times
4WD conversion in being planned in a phased manner. first would like to get all the mechanical works of 2WD and drive around for sometime!
Old 14th November 2011, 09:42   #30
Jaggu's Avatar
Thanked: 7,654 Times
1) Front wheel Wobbling - Wheel alignment done, however we asked him to do the wheel balancing, but guy said the rating is 145 & 175 which was abnormal hence he suggested/recommended that tyres need to be changed. To our surpise all the tyres looks good, but after going thro' old threads and found out the following :.
First check if its the "death wobble", then its time to attend to the king pin. Basically ensure steering system is fine before blaming it on the tyre.
Jaggu is online now   (1) Thanks Reply With Quote
Embarking on an Adventure: My pre-owned Fiat Adventure Samar117 Test-Drives & Initial Ownership Reports 44 28th December 2017 21:26
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
MM540 2WD to 4WD - Mileage drop after conversion yamaniac 4x4 Technical 7 29th February 2012 20:02
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
MM540 to Wrangler conversion - the short, crisp and simple way!! vinayrathore 4x4 Technical 48 9th December 2009 20:00
